SOURCE: I have a Seth Thomas Sonoma chime clock and no instructions
there should be a key to wind in hole in face
SOURCE: I have a 34 year
You got it, the problem is the gears within the chimes. Apply a singer oil lubricant or any other lubricant can help fix the problem.
SOURCE: i have my mother's seth thomas mantle clock
If your clock has a small hole between 4 and 5 then you can turn off the quarter hours chimes using the small part of the key. If your clock does not have that small hole you can not turn off the quarte hor chimes.
SOURCE: us navy seth thomas clock runs slow?
You can speed up or slow down the clock by adjusting the length of the pendulum. This link will walk you through the process.
http://usedclockparts.com/9-clock-case-repairs/31-how-to-speed-up-or-slow-down-your-clock-using-it-s-pendulum
The next time it chimes multiple times turn the hour hand clockwise until it is pointing at the number of times it gonged. Next take off the dial nut off (make sure to put it in a plastic bag because they can be hard to replace) and turn the minute hand until it chimes signaling 15 minutes after. Now put the minute hand back on pointing to 3 o'clock and replace your dial nut and you are all set.
Fix Clock That Gongs Wrong
