Try running it without the battery but with the ac adapter only, if that works the battery is the obvious problem, if not the solder joints on the charging adapter connection may be broken
Does the laptop start up with power adaptor plugged in? If yes then battery may be dead, you can check for a replacement online, battery model may be AA-PB2VC6B but check the battery label to ensure you note the correct battery model.
If the laptop does not boot with the power adaptor inserted, remove the battery and try booting with just power supply inserted and see if laptop boots.
If still not booting then it is a hardware fault, either battery, power adaptor or internal part possibly motherboard, you will have to contact Samsung for repair.
you posibly have a SHORT in the wire for AC power- try another power adaptor./ the other cause could be a bad power jack on the laptop- not an easy fix.
Sounds like you killed the motherboard. Find a local repair shop or someone on craigslist who will diagnose it for free. Wait while they do it, should only take 5-10 minutes to confirm your worst fears.
According of your description, If you already changed the power suply, and the battery, and still no signs to power on, your laptop has some issue at power connector in the motherboard and need to be serviced.
connect to the external monitor through the vga port of the laptop, check the display, if the display is there then its the problem of your laptop screen
like the soluton or not rate it please
