Question about Ace Hardware InSinkErator Badger 5, 1/2 HP Garbage Disposal
Leaking our disposal is only 3 years old, this the sencond one in 7 years,disposal leaks out of bottom of unit
  • 123 Answers
First check and make sure that the water is not leaking from the hose connection to the dishwasher or the drain fitting itself. If neither of these is the problem and it is definetly leaking from the housing then replace. I recommend the Badger series disposal with a 5 or 7 tear warranty I have installed them for years and never had a single problem.
Posted on Jul 31, 2009
Testimonial: "Actually the plastic case was cracked, so I did need to replace it. This was very helpful, thanks."
Garbage disposer leaking at bottom
Since you have checked all pipes and see no leaks next please check the area around the top and bottom of drain housing. If that's not leaking there is a gasket inside the disposal that could fail and cause water to leak into the motor area and then leak through the bottom of the unit. Generally in my experience replacing the whole unit is a time saver because access to that gasket is a pain and finding the right gasket can be timely. Depending on how old the unit is I would just replace it.
Jul 06, 2017 | Electrical Supplies
Garbage disposal leaking on the bottom?
DO NOT RUN THE UNIT UNTIL YOU STOP THE LEAK!!!
Either the sink seal is leaking or the internal motor shaft seal is bad. If it is the motor seal and the unit is more than 5 years old, replace the disposal. Replace the seal only if you have the appropriate skill.
Oct 04, 2014 | Electrical Supplies
How does the bottom plate come off a badger garbage disposal
Hi, the only plate that should be removed on the bottom is for wiring the power cord to the unit. If there is water leaking, specifically from the bottom of the unit, it's leaking through the enClosure assembly which is not serviceable. If the unit isn't that old it might just be leaking from the sink flange or mounting gasket at the top of the unit which at times can be difficult to detect. Or possibly the gaskets at the drain assembly for the unit. Hope this helps ;)
Feb 01, 2013 | Ace Hardware InSinkErator Badger 5, 1/2 HP...
Badger 5 leaking from body middle connection
1) Copy following link for troubleshoot and parts resources, and manuals with warranty information:
http://waterheatertimer.org/How-to-repair-and-install-Garbage-disposal.html
2) New unit would be best solution. And possibly cheapest solution. Otherwise you might be installing and un-installing more than once or twice ... which is fun if you have time, and other housemates don't mind kitchen project tools, water and mess.
3) If you can disassemble the disposal, you might be able to make your own gasket using kits and sealant from local auto parts .... assuming the metal was not mis-cast during manufacture and is warped so it never seals.
Dec 12, 2012 | In-Sink-Erator InSinkErator Badger 5 1/2...
Garbage Disposal Leaks from the bottom.
Hi GF,
Unless there is a leak at the sink gasket that makes it appear that the unit is leaking from the bottom, it's probably the main seal in the unit. It's generally not worth it to attempt disassembly and repair, especially if the unit is 10 years old or older.
Just remember to make sure the power is off before you attempt any
troubleshooting or replacement.
Be safe...
Aug 18, 2012 | GE Continuous Feed Garbage Disposal...
My badger 5 plus 5/8 HP HD insinkerator is leaking from the bottom of the unit. It is dripping from the reset button and one other metal tab location. It is at least 10 years old. Can it be repared?
Sorry to read about your problem, I hope this helps you out.
sorry no it is rusted out, even if you could take apart, after 10 years 1/2 the parts will be rusted..
I tried to help you. Please help me and Rate/Vote on my response. We take the time to answer your question's. take the time to rate us.
Thanks and good luck. you are looking around $90.00 for a new unit
4 Thumbs - Very Helpful
3 Thumbs - Helpful
Jan 05, 2011 | Ace Hardware InSinkErator Badger 5, 1/2 HP...
Water has begin to spray/leak when using the
Here is a tip that I wrote about how and where a garbage disposal will leak and what can be done to fix it.
Garbage Disposal Leak from bottom of motor
heatman101
g
May 15, 2010 | Ace Hardware InSinkErator Badger 5, 1/2 HP...
Water leaking out of bottom of unit, near reset
heatman101
p
Nov 11, 2009 | Ace Hardware InSinkErator Badger 5, 1/2 HP...
Ace Hardware InSinkErator Badger 5, 1/2 HP Garbage Disposal Logo
382 people viewed this question
Top Ace Hardware Electrical Supplies Experts
handygirl911
handygirl911
Mike
Treefrog15
Treefrog15
Are you an Ace Hardware Electrical Supply Expert? Answer questions, earn points and help others
