Question about Dryers
I have a Fisher& Paykel dryer ED56 auto senser multi temperture.when plugged in it beeps as it should do,but when I start the dryer it runs for a couple of s econds beeps (different beep as on start up)and stops.
  • 1 more comment
  • ria2633 Jul 31, 2009
    Hi there,I checked all 4 relays ( i could not work out wich one You ment) the resistant was all about 270 ohms.
    I dont known if you received my first message,I checked all 4 relays they were all about 270 ohms, what can I do next.
  • ria2633 Aug 05, 2009
    Hi Benjamin,I did all the test You mentioned they were all ok. This is a electronic dryer those not have a timer but an PCB.
  • 3,037 Answers
Usually it can be the motor relay which is on the control panel next to the switch. To trouble shoot the relay ,with a ohm meter, check for continuity across the coil of the relay, if infinite resistance, then it is bad and needs to be replaced. Let me know what you find.
Benjamin
Posted on Jul 31, 2009
  • Benjamin Patri
    Benjamin Patri Jul 31, 2009
    Alright, sorry for taking so long
    Next check the heating element, if it has infinite resistance it is bad and also check the motor for voltage going to it, if no voltage when trying to run the dryer, then I would say that the timer (dial) is bad and should be replaced.
    I am assuming that the above no start happens on all different cycles
  • Benjamin Patri
    Benjamin Patri Aug 05, 2009
    Well, the PCB is probably bad then and should be replaced. I don't believe www.repairclinic.com carries this model as I would advise you to order the part there and return it within the 30 days it gives you if replacing it wouldn't work. Otherwise you will need to go through the place you bought it.
Fisher and Paykel ED56 dryer won't run.
Glad to got it taken care of. Next time be a little more careful, I usually recommend using a leaf blower.
May 10, 2015 | Fisher and Paykel Dryers
Fisher paykel dryer ed56
Could be the door switch or temp sensor. To check the door switch put pressure against the door and see if it stops. Check the slot the door hits to see if there is anything loose in there.
Jul 20, 2013 | Dryers
F&P ED56 has 2 problems
Yes, (2) certainly sounds like the start/run capacitor has failed. You will see it has a split or bulging case, or a displaced end cap. Replace it with one of the same voltage rating and capacitance.
I can't advise you on (1)
Jun 20, 2013 | Fisher and Paykel Dryers
Fisher & Paykel ED56 not working
Replace (repair) the exhaust sensor this looks like a transistor with the middle leg cut off. it is situated below the lint filter but can only accessed by removing the back panel, top panel (or rear screws to allow the removal of the drum). drum and then front panel to remove the connector from the mainboard. If you follow the exhaust tube once the back is off you will see a single phillips head screw that is the sensor. check the wires to the circuit board are not broken or dry joints or just replace it. sorry i had a spare machine i scavenged from to fix my problem so i dont know where to buy new.
Mar 06, 2010 | Fisher and Paykel Dryers
Fisher & Paykel Auto Sensor Dryer stops & beeps constantly
Hi emkboyce
my Fisher Paykel auto sensor dryer keeps stopping and beeping, i have to stop it and and re start.
I had the same problem. I took it off the wall and vacuumed up all the lint from everywhere including around the back and including taking off the back and vacuuming everything I could reach inside. I then used a damp cloth to get rid of the rest of the lint/dust.
I thought I was wasting my time but guess what, the problem has gone.
Sep 30, 2009 | Fisher and Paykel DEGX1 Electric Dryer
Fisher & Paykel Dryer model ED56 constant beep
Diagnostic Mode
Entering the Diagnostic Mode
(a) Turn the power supply to the dryer on.
(b) Press and hold the Auto Dry down button, then press the Power
button.
The dryer is now in level 0 of the diagnostic mode. After initial entry into the
diagnostic mode, the Start/Pause button operates the dryer as normal. Press
the Auto Dry up or down buttons to scroll through the fault levels.
There are several levels of diagnostics, most of which are used in
development and production. These levels may bring on various LEDs, but
the level of use for the service technician is that of the last fault.
Last Fault
To enter the last fault diagnostics, enter the diagnostic mode as described
above, then press the Auto Dry up button three times. The last fault will be
displayed on the drying progress LEDs.
The manual is here
Sep 08, 2009 | Dryers
My fisher and paykel dryer ( mod# ED56 ) wont start, power is on
I had this same problem with my Dryer. It is making the few quick beeps because it thinks the door is still open. Near the bottom of the opening to the dryer there is a sensor switch that gets pushed in when you shut the door. Try holding the switch in with a knife or something and then start the dryer with the door open to check if that is the problem.
After i did this, i closed the door and my dryer started as normal.
Aug 11, 2009 | Fisher and Paykel DEGX1 Electric Dryer
Dryer tries to start - then stops and beeps PLEASE HELP
Check the exhaust hose. If the dryer isn't venting properly it will either stop or the heater will turn off and the clothes will remain wet. If the hose is not clogged check the wall vent tube.
Apr 29, 2009 | Fisher and Paykel Dryers
Dryers Logo
Top Dryers Experts
