Question about Frigidaire FGB24S5A Gas Single Oven
I need to change my oven ignitor and I need a diagram to show where it is located. I have a Frigidaire model FGF353BADB. Free standing gas stove/oven.
    President:
  • 704 Answers
Here's a diagram of the oven along with the Oven Ignitor (Part #19 on the diagram) and the Broiler Ignitor, (Part #26 on the diagram). They are located behind the gas deflectors located at the top and bottom inside the oven compartment, accessible from inside the oven, but you'll need to remove the rear panel at the outside back of the stove to disconnect the terminals tha supply voltage to the ignitors.
Be sure to turn the breaker off and/or unplug the range from the 220V-AC outlet first.
http://www.searspartsdirect.com/partsdirect/getSubComp.pd?modelNumber=FGF353BADB&productCategoryId=0124002&brandId=1428&modelName=FRIGIDAIRE-GAS-RANGE---5995274411&diagramPageId=00003&componentDescription=BURNER&documentId=Y2702738&backToLink=Return%20to%20Sub%20Components%20list
Hope this helps you complete your repair. Best Regards!
Posted on Jul 31, 2009
I have a Frigidaire model FGFL87DCE gas range and the oven will not work. It doesn't light and the gas doesn't come on
the first thing to check is the ignitor.turn the oven on and look to see if the ignitor is getting hot if it not you will need to check the power to the ignitor.if there is power to it then you may neeed to replace the ignitor.
If the ignitir is not drawing enough current then it will not open the gas safety valve
Dec 11, 2010 | Frigidaire Ovens
I have a frigidaire gas oven Model Number FGF366ECC. The oven does not get hot.
9 times out of 10 the oven ignitor is the problem see if the ignitor glows when you turn the oven on it should be a bright yellow glow and not a dingy orange glow if it does not glow at all the ignitor could be burned out
Nov 18, 2010 | Frigidaire Ovens
Frigidaire oven will not ignite
The ignitor is not working right and is going bad....
have the repair man replace the ignitor, or DIY....
Check out this tip about your problem...
Oven not Working or Oven not Heating
http://www.fixya.com/support/r3663023-oven_not_working_or_oven_not_heating
heatman101
Jul 23, 2010 | Frigidaire Ovens
Won't get hot, smells like gas
Most of these new fangled gas stove feature a silicone carbide ignitor to light the oven. Older stoves used a standing pilot light. As silicone carbide ignitor age a little they tend to get weak and fail to open the gas safety vave sufficiently enough for ignition. Take a look
Jul 06, 2010 | Frigidaire 30" Self-Cleaning Freestanding...
Where is the oven igniter located at in a Frigidaire single gas oven located if I need to replace it?
remove the oven racks, in back there will be two chrome screws, remove them. Lift the lower oven panel out by pulling up from the rear. Remove the screws holding the flame spreader and remove the flame spreader. Now you will see the burner and igniter attached to it. There are 2 quarter inch hex screws holding the ignitor on. GE likes to put them on an angle, so it is easier to remove the burner tube. Remove the bottom drawer and remove the screws securing the burner to the back wall. There should be one in the front too. The burner will now lift up and you can get at the screws. The new ignitor should come with ceramic wire nuts. Just cut the old igniter, strip the ends of the wires going to it and wire nut the new one on. Reverse the rest of the steps. There is also a video at www.appliancehelponline.com/servicemanual.html that walks you thru testing this part. You can also enter your model # for diagrams and illustrations.
Apr 09, 2010 | Frigidaire FGB24L2A Gas Single Oven
Hello when i put my temp for my gas stove on say 350, the pilot is glowing but it doesnt seem to flame/heat up, and i get a somewhat odor of gas, could the therometer need replacing or maybe the ignition...
Your glowbar ignitor part must be replaced, Unplug the range and turn off the gas. Remove yje oven racks, The oven base pan. Then remove the flame spreader. You will see the glowbar ignitor attached to the side of the bake burner. Remove it and replace it with a new ignitor. Replace all the range parts.Turn on the power and turn on the gas supply.
Copy and paste this site for the location of the ignitor you can also purchase the part from them.
http://www.appliancepartspros.com/partsearch/model.aspx?model_id=111359&diagram_id=362260#d362260
Jan 01, 2010 | Frigidaire FGB24T3A Gas Single Oven
I have a Frigidaire stove, model fgf316asa, and the oven does not heat. The ignitor still glows but does not ignite the gas. I cannot hear the gas coming from the line. What's wrong?
Hi, You should change the ignitor. Even tho it glows, the ignitor is to weak to open the gas valve. UNPLUG the oven. Remove the floor panel in the oven and you sill be able to see the ignitor. This is very common with gas stoves.
I hope this helps you. Please let me know if I can assist you further.
Vic
Jun 14, 2009 | Ovens
Frigidaire FGF326ASA gas oven
If both the broiler ignitor and the bake ignitor are not working it is unlikely they are both bad. You may have another problem. Need to check voltage to the ignitors to be sure.
Apr 09, 2008 | Frigidaire FGB24S5A Gas Single Oven
Frigidaire oven
Your oven valve won't open all the way
Aug 15, 2007 | Frigidaire FGB24S5A Gas Single Oven
Frigidaire FGB24S5A Gas Single Oven Logo
1,038 people viewed this question
Top Frigidaire Ovens Experts
Dan Webster
Dan Webster
Oloyede Monsuru
ashburton
Are you a Frigidaire Oven Expert? Answer questions, earn points and help others
