Question about Garden
Hi, My question involves a:Honda GCV160 5.5Chore Master 2400 psi Model CV-2400=4MHC I have very little use on it. I broke the sprayer hose on it the other day and ordered a new one for this model. I connected my water supply, turned it on, started the machine but have VERY little pressure. What do you feel my problem is and how can I remide it? Thank You! Louie Lchampa@frontiernet.net Boundary Waters Taxidermy, Ely Mn. 55731218 365 6310e
  • 90 Answers
  1. put in your garden hose
  2. turn on the water
  3. leave it to run for one min.
  4. kink the garden hoes
  5. connect the hi pressure hose "the one you ordered"
pull the trigger then start
if this don't work start the machine without the hi pressure hose.
no pressure machine needs valves.
Posted on Jul 31, 2009
Water will not shoot out....took the hose off and it still doesn't work
If this model has a quick disconnect coupling for the pressure hose opposite of the sprayer wand at the pump, remove with a wrench. Hook up the water hose, turn on he water , but don't start the engine. If it has a clog this will flush out the clog. Replace the coupler and hose, turn on the water first before starting the engine. If the pump builds pressure it will make the motor bog down slightly. If there's no change in the sound of the engine with water turned on, the pump will be damaged. If the motor bogs off and on and water sprays on and off, means there is an air leak in the pump. If the pump does not work at all with the water turned on, the pump will be burned up. Please don't take this in offense; but I've seen many power washer pumps damaged because the water was not turned on before starting the engine. Try these few steps and let me know if you get any pressure at all, if so it's probably an air leak. Good luck!
Jun 21, 2011 | Mi T M Mi T M CV 2400 Cleanmaster 2400...
Honda pressure washer 2400 psi worked fine yesterday, today the pressure is low, seems to work fine except the level of press sure is low any suggestions?
Check for an inline filter on the water hose connection, the low pressure side. Depending on your water quality and if any spiders made homes inside your hose, they can get clogged pretty easily.
Jun 07, 2011 | Garden
My Honda 4.0 1800PSI Power washer only has hose pressure when it should have 1800 PSI
hi spray some silicon oil in inlet and outlet then run attach hose back do this everytime you store the washer away it is because the seals dry up always lube when storing.
Jan 15, 2011 | ALL POWER AMERICA LLC AllPower America...
Airless sprayer, paint comes out like silly string
In order of ease/cost to fix: First, check your spray tip. Most of them are reversible to help spray out any debris that may be lodged in them. Next, check that all of your filters are clear and let paint flow freely. Depending on your model there are up to three, one filter in the spray gun, usually in the handle, another filter is at the pickup tube and some sprayers also have another filter on the machine where the hose hooks up. Another cause may be because your paint is way too thick or not mixed well. A highly recommended paint additive for airless sprayers is Floetrol, it makes the paint flow extremely well. If none of these fix your problem you may well have a worn packing or diaphragm, again depending on your model, and the machine isn't developing enough pressure to atomize the paint. If you have the means put a pressure guage in line with the hose at the machine and turn it on. You need at least 1200 to 1800 psi for most latex paints, a little higher for enamels and thicker paints.
Dec 17, 2010 | Campbell Hausfeld Air Tools & Compressors
Honda 2400 psi before it went out i cold tap the end of the wand on the ground and the pressure would return now when pull the trigger there is no pressure only a fine spray .its a karcher with a honda...
hi,
there is a small ball bearing inside the nozzle on the end of the lance , this can get jammed or missaligned and the nozzle orifice can get blocked , clean this or replace the whole lance with another 200 Bar lance .
hope this helps
Feb 01, 2010 | Honda Karcher G2400HH-R Pressure Washer
My high pressure 2400 psi hose blew out.
Hi cwsales:
Sorry, the pressure will be too much for a your mend to work. You will just get wet. A professional hose repair shop is your best bet, or a new hose.
Jul 14, 2009 | Campbell Hausfeld Garden
Husky 2400 psi honda engine ran fine all day
It sounds like the bypass valve is stuck. Do you have a parts diagram?
Jun 27, 2009 | Honda Garden
Rear window sprayer does not work on honda CRV 2003
On my 2007 CRV, I have to hold it long. Since I hardly use the rear sprayer, there is no liquid in the hose and it does take a little while before I get enough liquid in the hose to get the pressure going.
Dec 10, 2008 | 2007 Honda CR-V
Garden Logo
215 people viewed this question
Top Garden Experts
Dennis Key
Dennis Key
roeb
john h
