Question about Smartpool Above-ground Pool Eye
I have a 21' round above ground pool and the wall is slightly pushed in at the base of 4 of the support post. What could be causing this?
  • 162 Answers
Mowing while intoximicated...
angry woodchucks....
the pool boy..?
No wait....
the neighbors kids....that's it...
Blame the neighbors kid's .. lol
Posted on Jul 31, 2009
How can we take it apart after we drained the pool?
Question:
How do I properly remove my above ground pool?
Answer: by Osko Pool n Spa Onground Pool Removal Guide
Recently, a reader of one of my other articles asked the question;
" How do you take down an above ground swimming pool to move it? I can't seem to find anything to help me. I read your article on replacing a liner but I need to know how to move the entire pool".
Well, (I thought to my self), this is a very good question. So, here is a basic step-by-step guide on the basic proceedure: ( You'll need at least three people, to help with your wall).
1) Drain all water out of pool using a sump pump.
2) Remove skimmers, returns, lights etc.
3) Remove old liner, (use a razor knife and cut into manageable folded pieces). You'll need a new liner if your going to reinstall the pool.
4) Remove Top Seat Ledge covers
5) Remove Top Seat Ledges.
6) Remove Top Rail and Joiner Plates.
7) Locate Wall Bolt Joint on the Pool Wall and remove the corresponding Upright.
8) Now, get some help and remove all Wall Bolts and associated hardware.
9) Next, start pulling the wall out of the bottom rail (track). And roll the wall up as you remove it from the bottom rail. When finished, duct tape the wall so it does not unroll.
10) Pull the uprights, bottom rail and bottom rail joiner plates out of the ground in sections.
11) Remove uprights from bottom joiner plates.
12) Make sure to separate all components and save all hardware!
That's it!
Hope this helps!
Apr 09, 2016 | Intex 32 x 16 x 52" Ultra Frame...
Swimming pool
NOT from Outside.
If Possible empty pool now with a Controlled drain...
Peel back liner and clean area real good. Sand or steel wool to remove rust. Then Paint using one of those "Rubber" based leak sealing paints found in your local DIY warehouse store.
Then place a piece of Thin sheet metal against the wall after paint dried. Replace liner, coping strip, ridgidizing metal bar, and top rail.
Refill.
or if you're lucky...
Patch the liner. When all is dry, use 3 applications of Epoxy Putty like JB Weld. Place a small covering over the DRY area with the hole. If possible, force some into the hole.
Once dried and cured, place a 2nd patch, slightly larger over it, and then repeating a 3rd time, again slightly larger.
Not as good as First method, but may still work?
If left unattended...
The water pressure in the pool, will push the liner right thru that hole - like a hernia, and will burst thru releasing all your water and possibly collapsing the pool? This will be an "Uncontrolled" drain vs. the controlled drain above.
I guess you can choose which way you want to drain your pool?
Weld 8265S Original Steel Reinforced Epoxy Twin Pack 2 oz
Jun 14, 2015 | Pool & Spa
How much salt is needed for a 30 ft diam pool with 54 in side walls?
23,790 gallons if you fill it to the very top.
Calculate the volume of a pool you need the radius^2 times pi times depth times 7.48 to come up with gallons.
Radius = 15ft
pi = 3.14
depth = 4.5ft
15^2 x 3.14 x 4.5 x 7.48 = 23780.79 or 23,781 gallons.
So the salt you need is 640 lbs @ 40lbs each = to 16 bags
I don't think Mike's figures are correct according to my research. You can ask at a pool supply shop, who will also sell you the salt. It certainly is going to be 32oz to make a saline pool. Remember the salt is doing the job of chlorine to kill bacteria.
May 09, 2015 | Intex Automatic Salt Water System for ...
How to fix a hole in a swimming pool liner
  • Get some food coloring...
    • Squeeze bottle works best
    • Or pool leak detection Dye
  • get some good goggles...
  • get in the pool, start at one specific area...
  • and take a deep breath...
  • Now follow all the seams 1st, squeeze some dye in a suspected area and watch. If the dye gets sucked in, there's a leak! If it just puddles and hangs around, keep checking somewhere else.
  • Once a lead IS found, vinyl liner pool patch! Can even be used under water.
Amazon com Vinyl liner pool patch Patio Lawn Garden
Leakmaster Pre Filled Dye Tester For Finding Pool Spa Leaks
Oct 15, 2014 | GLI Pool Liner 050012rdlucub52 12 Round,...
How much salt do i need for a 24 ft round pool
depending on the salt system you are using, the amount of salt will vary. the owners manual should have a salt table with a recommended value. most salt systems will require somewhere close to a 3000 ppm level. to get this, you will need approximately 140 kg of salt. (65 lbs)
Sep 08, 2014 | Intex Automatic Salt Water System for ...
My pool rover goes one way but wont turn around just keeps pushing against the wall
Hello Kathy,
I have the same problem. Do you already have a solution?
Regards,
Bob from belfium
Jun 10, 2012 | Aquabot Pool Rover Above Ground Robotic...
How salt to use for start up for a 22 x 52 above ground pool
You need to know how much salt is currently in pool...
then what is total gallons of your pool?
Round pool? 22' round?
52" walls?
Use only Pure Pool Salt, NOT Softener salt!
2700 ppm to 3400 ppm is the range for ideal levels in your pool.
check out this link...
http://www.conelyco.com/images/saltchart.jpg
btw... Your pool, if what I asked above is correct, has 11,400 gallons
May 31, 2012 | Intex Automatic Salt Water System for ...
Is the Hayward s210 pro series 21" top mount above
Thank you for posting your question here on Fixya.com.
32' round by how deep? Flow rate is how you size a filter so with total gallons you can calculate how many per minute will add up to the whole pool being turned over is 6-8 hours. The pump and filter are then sized for that required flow...Assuming the pool is an above ground ~4' average depth then total gallons would be about 24,000 gallons. For an 8 hour turnover you would need about 50 gallons per minute. The 210T, T for top mount, is designed to handle up to 44 gallons per minute and turn over a 21,000 gallon pool in 8 hours or a 26,000 gallon pool in 10.
What that basically means is that using a 210 on a pool 32 x 4 would be pushing it. It will work but you will end up backwashing more frequently which raises the overall cost of running the pool. If it is not to late a 24" filter would be better; especially if you have periods of time in your pool season where heavy amounts of debris such as pollen get into the water. A 21" filter won't handle any over a normal filtration load.
If this answer does not fix your problem, please comment with additional details prior to rating the answer. You may also contact me thru our website at www.arrowpools.net. Positive feedback is appreciated once your problem is solved!
Apr 28, 2011 | Hayward Pro Series 21" Above Ground Pool...
My above ground pool vacuum does not move. It sounds like it is working, but it just sits in one spot.
With these pool cleaners, the common cause of this problem is issues with the flapper. With the pump off, remove the cleaner from the pool and check the flapper for any signs of damage or debris that could be causing problems with movement. It should move freely and their should be no obvious stones, twigs or other debris clogging this area. If you see debris, simply remove it. If you see debris that can't easily be reached with your fingers, you will need to remove the plate where the debris goes when vacuuming. Use a small flat headed screwdriver to push on one of the two tabs located on the side of the base plate. Release the plate, remove the flapper, and remove the debris. Reattach your plate and try your cleaner again.
Aug 19, 2010 | Dirt Devil POOL CLEANER FOR ABOVE-GROUND...
Smartpool Above-ground Pool Eye Logo
83 people viewed this question
Top Smartpool Pool & Spa Experts
Craig Butler
Craig Butler
Robert Plante
Are you a Smartpool Pool and Spa Expert? Answer questions, earn points and help others
