Question about Miele Powerhouse Plus Bagged Upright Vacuum
Miele upright not sucking up? - Miele Powerhouse Plus Bagged Upright Vacuum
  • 1 more comment
  • misty_luelle Jul 31, 2009
    yes it's turning but it's not sucking up thru the bottom or thru the hose?! My Mom used it when she came over the other day and said it worked fine-- I turned it on and it won't suck-- changed the bag out and still nothing-- it has a filter and I'm looking online to see if I have to change the filter for some reason. I won it off the Bonnie Hunt show in December and received it about February and we don't use it that much (i'm ashamed to say)
    Thank You!! Thank You!! That worked -- I had to take a broom stick and put it thru the hose to get the hair ball out!!
  • jennerina
    jennerina May 11, 2010
    Are the brushes turning? Suction, just not strong? How long have you had the machine? Anything peculiar that you sucked up inside the machine lately?
    Scholar:
  • 86 Answers
Sounds like there is something blocking the main airway. I doubt its the filter. You may have to partially disassemble it. Maybe a hairball or something is blocking it I sucked up one of my daughters thin socks one time, had to take it apart to get it out.
My vac has an access panel in the back for this. Thankfully or I would have never been able to get it out. Remove a couple of screws, look for any blockage.
Unplug the machine, and go hunting. If its not in the airways, it is likely close the motor blades. You can't mess anything up, so grab a screwdriver and have at it. Just remember to replace all screws in place when done.
Hope this helps some. Good Luck!
Posted on Jul 31, 2009
It is not sucking at all
So your machine sucks :>) Sorry I couldn't resist.
Remove the bag. Turn the machine over and remove the base plate. At one side of the brush towards the back, you will see the hole that all the fluff goes through, to the motor and then onwards and upwards to the bag. That is where your blockage will be. If you can get it all your can make a little hook from a wire hanger. You can also put the machine outside and run it without the bag. This creates a lot more force and will often dislodge blockages. Remove as much as you can first though.
Nov 22, 2015 | Miele S7260 Bagged Upright Vacuum
My Miele vacuum's hose has stopped sucking-help!!
Sounds like you might have something caught in it. If you have another vacuum with a hose, use that machine to suck out the clog in your Miele hose.
Sep 06, 2014 | Vacuums
Miele upright dog and cat vacuum clogs easily and won't pick up pet hair
could be as simple as a broken belt or a clogged hose run a broomhandle through it or a plummers snake also check filters for dirt
Jan 05, 2014 | Miele Vacuums
Steam coming out of Miele S7000 upright vacuum cleaner
There is no steam generator on your Miele. It can only be smoke or dust. Are you certain it is steam. If you have sucked up water the motor could be in danger of shorting out.
Aug 12, 2013 | Miele Vacuums
Miele S7210 red light on
You may have more dog hair in the main hose. Pull the hose out of the body, turn the lower hose swivel 90 degrees parallel to the floor and twist the hose off. You will see where to remove it at the swivel. Also check the port door on the back of the vacuum near the bottom of the upper section. It can be looks like a parallelogram with 2 plastic screws, twist the screws half a rotation and gently pry the cover off. After clearing out any debris, replace the cover and fasten the screws. A small LED flashlight will be very handy for checking all of the ports and hoses.
Feb 07, 2013 | Miele S7210 Bagged Upright Vacuum
When the brush is on it won't **** properly
Look for blockage carefully as the unit does not know which you have attached.
Dec 05, 2012 | Miele S7210 Bagged Upright Vacuum
Hose was not sucking but the rest of the vacuum seemed to be working. the model is a S7210 twist. it felt very hot and the red light was on. it then shut down completely. we can't see any...
No suction at the hose?
There could be a clog IN the hose somewhere. If it is easily removed, take it outside and run a garden hose through it. Your bag might be filled to the top as well...?
Jun 09, 2011 | Miele S7210 Bagged Upright Vacuum
Vacuum sucked up a sock through the hose- now it's clogged how do I fix it upright vacuum
Best thing you can try is getting a "snake" like for unclogging water pipes. Start at where it went in, the hose is behind the brush roll, just off to one side. Gently push the snake in until you feel the scock and twist the snake while pulling it out; if nothing comes out after a few attempts, try a reverse approach by removing the rear parallelogram looking port on the back rear of the vacuum. There are 2 plastic screws which only have to make about a quarter turn. Gently lift the cover off the port and try the snake down the left channel.
Jan 24, 2011 | Miele S7210 Bagged Upright Vacuum
Miele Powerhouse Plus Bagged Upright Vacuum Logo
555 people viewed this question
Top Miele Vacuums Experts
Mack Baxter
Colin Stickland
Colin Stickland
Are you a Miele Vacuum Expert? Answer questions, earn points and help others
