Question about Ovens
My oven made a buzzing sound,and and smoke came out form the oven. Now it wont heat up, but the top stove still works...Any ideas? Thanks
    Renaissance:
    An user who is expert in 3 categories / brands.
  • 1,810 Answers
Fryed switch or fryed burner
if smoke came from inside stove likely the burner is fryed
try setting oven to broil and see if it heats up
if it does replace lower burner
Posted on Jul 31, 2009
Oven was heating and we got HEAVY smoke....
Nothing in the elements, thermostat thermocouples are gas filled, sensors have wiring inside, nothing in the liner or insulation. You said this was a stove, and some stoves have a vent that goes up through one of the burners on the top. If you had oil splatter or drip into this it can get into your oven. We do know that some blower fans on convection ovens have a sealed oil bearing, but there would be very little oil coming out of this (drops) and you will notice your fan getting noisier or running slower in the near future. Good Luck, Appliance Specialists
Jan 25, 2010 | Ovens
Stove burners don't get hot enough and the oven takes a long time to preheat
sounds like its wired incorrectly .. the stove operates on two phases of 120 volts each .. together they form a 240 volt supply .. if its wired incorrectly you may be getting only 120 volts .. it will then take 4 times as long to heat .. have an electrician or someone skilled in that sort of thing, check the voltage at the plug .. and make sure the pig tail is attached correctly to the stove .. check the circuit breakers .. there is one for each phase .. but if one is tripped then some functions wont work at all unless there is a second problem (shorted phase) in which case it will work but have the 4 times as long to heat problem and it will trip the circuit breaker immediatly .. ..
Oct 01, 2009 | Frigidaire Ovens
GE glass top and oven are not heating?
I have an electric oven that is turning on but not heating up. The oven, broiler, & stove top are not heating up. Any easy solutions to this?
Jul 18, 2009 | GE Profile JKP18 Electric Single Oven
Frigidaire model MGF331BFWA...Oven isn't lighting(heating)up
Stove wont heat up. Stove top elements are working fine. do you think it is the heating coil/element in the oven?
Mar 01, 2009 | Ovens
Kenmore ultra self cleaning oven or top heat
I found that the 220 plug had burned out, that was where the smoke came from. The display worked because the ground "prong" was the only one burned. Had to replace the electrical 220 socked and the electrical plug on the oven.
Jan 13, 2009 | Ovens
Oven doesnt work
If it is a fan assisted model, check that the fan blades are not catching the back panel in the oven itself, the fan mat be worn or the blade loose or bent.
Plz rate this solution.
Thanks.
Dec 15, 2008 | Ovens
Kenmore ultrabake lights up when stove top is on but wont heat up
Hard to know...First thing I'd check is the power supply to the unit.  Turn off both breakers.  Check wiring all the way through for tightness.  Turn both breakers on.  Next, you'll need to check the elements for continuity...with the power off.
Nov 28, 2008 | Kenmore 40494 / 40495 / 40499 Electric...
Oven wan work
make of stove .. digital or standard controls .. may not even be the oven ovens are 220 volts 110 works stove top other 110 works oven
Aug 24, 2008 | Kenmore 40494 / 40495 / 40499 Electric...
Heating element in GE Range Oven
get the model number and order the exact repacement bake element
Mar 10, 2008 | Kenmore 40494 / 40495 / 40499 Electric...
Ovens Logo
132 people viewed this question
Top Ovens Experts
ashburton
Craig Butler
Craig Butler
Are you an Oven Expert? Answer questions, earn points and help others
