Question about Ricoh Office Equipment & Supplies
Ricoh sp 210su printer error sc 556 any solution
    Habit-Forming:
    New Friend:
  • 67 Answers
To resolve this error do soft reset your printer by switching it off and disconnect all the power cables.
Now after printer settle down press and hold power button for 60 seconds after that use 2nd method.
Remove back cover of the printer.
remove print head and cartridge.
Remove rollers on the printer and clean them.
Refix alll of them and restart printer.
For more info : http://bit.ly/2FfFKr7
Posted on Feb 12, 2019
  • 37 Answers
SOURCE: Service Call SC 553 on Ricoh Aficio SP C811DN Printer.
No.
Type
Details (Symptom, Possible Cause, Troubleshooting Procedures)
553
A
Heating roller overheat (software error)
The detected heating roller temperature stays at 230°C or more for 1 second.
• Defective PSU
• Defective lOB
• Defective EGB
Related SC code: SC 543
1. Replace the PSU.
2. Replace the lOB.
3. Replace the EGB.
This is the simptoms of the service manual , you should check that your power output is stable and double check if there is not anything like paper stuck some were in the fuzing unit wich could also cause the fuzer to over heat
Posted on Nov 16, 2007
SOURCE: ricoh aficio 3500
sc441 error means one or more of the developer unit(PCU) isnt rotating. you have to take the PCU out to see which color isnt rotating. there maybe one of the doctor blade is flipped, usually caused by lack of toner in the PCU.
Posted on Jun 05, 2008
  • 86 Answers
SOURCE: Ricoh Aficio MP 2510 SC 541, SC 542 Errors
To clear level A SC codes such as this SC541, you need to
Enter SP mode, and then turn the main power switch off and on, only.
Please check if the thermistors are the proper ones and are installed correctly in their position properly.
This is also useful for SC542.
Please check the thermostats and fusing lamps for open circuit.
Good luck and please rate me, thanks.
Posted on Jan 17, 2009
  • 412 Answers
SOURCE: Ricoh Service Code error - Service Code SC-300
I am a Ricoh tech and my service manual doesent have a 300 code,
Posted on Jun 18, 2009
bosegautam11
SOURCE: Ricoh Aficio SP C411dn error SC542
Ricoh Aficio error SC542
Posted on Sep 26, 2011
Service call-sc491
Possible fixes from previous FIXYA question.
Use Comment menu to add information.
For example, what model Ricoh printer is it?
Have you replaced toner recently? If so, was it Ricoh original or not?
http://www.fixya.com/support/t26593905-printer_ricoh_sp_210su_service_call
Printer Ricoh sp 210SU service call error SC491 using compatable cartridge...
Jul 10, 2018 | Ricoh Office Equipment & Supplies
Ricoh sp 210su service call sc559 problem
Code
SC559
Description
Fusing Unit Third Jam Error (Fatal Error)
Causes
The exit sensor failed to detect the leading edge of the paper within the prescribed time and triggered a jam alert.
Remedy
• After this error has occurred three times, the machine will shut down automatically and cannot be re-started until the machine has been serviced by a service technician. • Check the paper transport path for any physical obstructions (paper scraps, etc.) • Make sure the fusing unit has been installed correctly • After servicing the machine to solve the problem, the service technician must execute a "Fuser SC Reset". Otherwise, the machine will continue to issue this SC code and cannot be operated.
Apr 10, 2018 | Office Equipment & Supplies
Ricoh sp 210 printer showing error sc 556
Make a phone call to your Ricoh service rep and report code SC 556.
Mar 27, 2018 | Ricoh Office Equipment & Supplies
Printer Ricoh sp 210SU "service call error SC491". using compatable cartridge instead of Ricoh original. Service centre suggests to change the cartridge to solve the issue. any idea else pl share me
SC491 on a Ricoh SP 210SU is a code for bias leak.
The machine detects that a bias leak has occured from the drum charge, development charge or transfer charge.
PWM signals are sampled at 20 msec. intervals. This SC is issued if 10 PWM samplings within 200 msec. are abnormal.
• HVPS (high voltage power supply) harness loose, broken, defective
• HVPS board defective
• AIO terminal defective (the terminal for the toner cartridge)
• Cycle the machine off/on
• Check all the harness connections of the HVPS
• Check spring-loaded AIO terminal installation behind the HVPS.
• Replace HVPS.
Usually this error is related to the cartridge. Some manufacturers of compatible cartridges will replace the cartridge with a new one.
At least they should give a discount based on how many pages that was printed before it failed.
I have not seen this problem with a new genuine Ricoh cartridge.
It is important that the cartridge is not refilled more then 3 times. There is no counter on this, and companies that refill cartridges they collect (with unknown number of cartridges) may have problems quite often.
May 11, 2017 | Ricoh Office Equipment & Supplies
Printer Ricoh sp 210 su in error service call sc556
your printer seems overtoned or the toner density is too high regulate it out then switch off an on
Oct 15, 2016 | Ricoh Office Equipment & Supplies
How to make reset for sc 544 for Ricoh Aficio SP 9100DN
Reseting SC 544 error code on Ricoh copier
Press CLEAR MODE(yellow) key,
Press 1 , 0 , 7
Press and hold down CLEAR/STOP (red) key for more 5 sec.
Press in the SP Mode( on the touch pane)
Go to sp5810 and reset SC code
Open the front door turn OFF the power main switch, and turn it ON
Heating roller overheat 1 (hardware error)
During stand-by mode or a print job, the detected heating roller
temperature reaches 220 °C.
Defective PSU
Defective IOB
Defective BCU
Defective fusing control system
1. Replace the PSU.
2. Replace the IOB.
3. Replace the BCU.
Jun 08, 2016 | Ricoh Aficio SP 9100DN Laser Printer...
Ricoh Aficio SP 4100N SC 590 power off on
YOU DONT FOLLOW INSTRUCTIONS VERY WELL,,DO YOU???!!! CALL SERVICE PROVIDER!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!
Aug 13, 2012 | Ricoh Aficio SP 4100N Laser Printer
286 people viewed this question
Top Ricoh Office Equipment & Supplies Experts
gggg
quennie732
OfficeServiceAjnc
OfficeServiceAjnc
Are you a Ricoh Office Equipment and Supply Expert? Answer questions, earn points and help others
