Question about Palm i705 Handheld
I hooked my palm
I hooked up my palm as soon as I got it and it won't turn on.
    Mentor:
    An expert who has written 3 tips or uploaded 2 video tips.
  • 448 Answers
Slow charge for 8 hours
Posted on Aug 01, 2009
I just bought the eclipse cld and it won't turn on after charging for hours
If the rechargeable battery is more than 3 - 4 years old then the battery could be worn out. Rechargeable batteries have a finite number of charge and discharge cycles and will lose their charge capacity over time, i.e. won't charge to 100% and gradually the charge reduces until the battery won't charge up at all. OR The battery shows a 100% charge but when the adapter is disconnected the battery drops off to zero capacity in a very short time. If the battery drops to an unacceptable charge level then the battery needs to be replaced. Rechargeable batteries will fail if stored in a discharged state for long periods.
Sep 30, 2012 | Eclipse Audio Players & Recorders
Help needed, my Palm will not turn on...what should I do?
Go to nearest store and give it repair they Fix this soon..
Aug 18, 2011 | Palm Pixi Plus Cell Phone
How to register
  1. Turn on your Palm phone. Wait for the boot-up sequence to finish. The boot-up screen will vary based on which cell phone service you signed up for. Holding down the red "call-disconnect" button on the right side of the five-way navigator button will finish the turn-on process.
  2. Enter the activation code. As soon as you turn on your phone, an activation screen will ask you for your ESN/MEID code. To register your Palm phone, you will need to enter this code. Then pick the language you want to use and click "confirm."
  3. Create your profile. You will be prompted to agree to accept your cell phone service provider's terms and conditions. Once you accept this, follow the guide to create your own profile. Your Palm phone will be registered after you go through the tutorial.
Regards
Jun 29, 2011 | Palm Cell Phones
When i turn it on it won"t get past the hello moto screen
try hooking it to your pc..have some sort of phone tool on there for flashing..after you hook it up start it in flash mode,you do thius by holding the star key and the palm key at the same time and then pushing npower while still holding the star and palm
Mar 12, 2010 | Motorola Mobility RAZR V3
How do you turn on the Palm m515
the palm m515 has a button at the top right corner .. hitting the button quickly will turn the unit on or off ... holding the button for 2 seconds will turn the display backlight on or off ... if the unit fails to start then you can do a reset .. thats like a reboot .. the top of the stylus unscrews ... that gives you a little probe that you can use to push the reset button on the back top center ... if the battery is bad you can still run the machine with the charger hooked up ..
Sep 29, 2009 | Palm m515 Handheld
Palm TX travel charger problem
It is an issue with the slot on the device, however you can charge the device using the Sync cable, it is the safest way to charge the device.
Dec 01, 2008 | Palm TX Handheld
Palm i705 won't turn on
are you certain that the belkin universal charger, is compatable with the palm ?
if any single cable, is wired differently. this could have damaged the palm.
try a hard-reset using your palms user manual.
this varies between pdas, usually comprising of either a reset hole, at the bottom of the palm, or underneath the battery on certain models.
i,d suggest obtaining the correct charger/usb cable.
as you may cause damage to the unit. most new devices have a battery fitted, but does not necessarily mean it,s charged.
Hope this helps, please rate the solution.
Mike @ compurepair.
Nov 06, 2008 | Palm i705 Handheld
Palm 650 stuck in loop
you have to hard reset it. Remove any software that you just install.
May 21, 2008 | Palm Treo 650 Handheld
Palm i705 Handheld Logo
22 people viewed this question
Top Palm Computers & Internet Experts
JC Meredith
JC Meredith
gary433
Are you a Palm Computer and Internet Expert? Answer questions, earn points and help others
