I have an 18000 btu wg1805ry6 and it will not come on, i have checked the fuse and have power on all sides of the compasitor.what could be the problem
  • hoghunter256 Jul 31, 2009
    WELL ITS NOT COOLANT OR INTERNAL FUSE
    Renaissance:
    An user who is expert in 3 categories / brands.
  • 1,810 Answers
Low cooland
bad start up reley
blowen internal fuse
fried board or switch
Posted on Jul 31, 2009
I have a Crosley 220 volt 18,500 btu window unit air conditioner with a heat pump. The cool air works fine when set on cold, but when set on heat, it doesn't blow warm air. What should I check first?
18000 BTU Air Conditioner ' The Air Conditioner Guide
www.theairconditionerguide.com > BTUs
An 18000 BTU air conditioner is your best bet if you are looking to cool a room ... 2) Frigidaire 18,500 BTU Window-Mounted Median Air Conditioner with ...Troubleshooting Guide. Lost your Everstar air conditioner manual? Fix it tips are here!
Nov 26, 2015 | Crosley CAHE18ER Air Conditioner
The control card is displaying error ch-01
PDF]SERVICE MANUAL R?410A Ductless Split System Air ...
dms.hvacpartners.com/docs/1011/Public/.../42108920400_ICP_26610.p...
421 01 9204 00 1/03/13. SERVICE MANUAL ... Consult local building codes and National Electrical Code. (NEC) for special ..... 18000 (5970-22350). Heating Capacity (Min. - Max). Btu/h. N/A ..... Error Messages Displayed Front Panel. S.
Oct 08, 2015 | LG 18000 BTU Dual Zone Mini-Split Heat...
Whirlpool dryer AWZ 8578, power is going into the
2 things stops your drum from turning ist thing to check is belt broken you take the top off and look into and you will be able to see if iis broken if that is ok then you will have to check the compasitor it on the side it like a big fuse
Oct 13, 2014 | Dryers
How many tons is my unit?
divide your btu rating by 12000. (1 ton = 12000 btu)
For example - a 24,000 BTU Air Conditioner is a 2 ton unit. 24000 divided by 12000 = 2
A 18000 btu air condtioner is a 1 1/2 ton unit 18000 divided by 12000 = 1 1/2
you can find out your btu rating by looking on the tag on your unit.
Jun 07, 2011 | Heating & Cooling
Installed 18000 btu split system heat pump and condensing unit is freezing up in cold weather 15 degrees out side air.
Actuall, out door fan sucks fresh air to cool the condensor when it's on "Cool" mode. If it is in " Heat mode' if the fan should run only on pressure build up. May be pressure switch is faulty.
Melt the ice with Torch gun, and check again.
Dec 15, 2010 | LG Heating & Cooling
Cooling capacity :18000 BTU/h Air circulation
check the amperage of the compressor if it is high better to replace.
Nov 30, 2010 | Ruud UBHC Air Conditioner
LG 250 Volt, 18000 btu window air conditioner. Tested power on the outlet, and that is fine...but will not power up the unit. Have already tried the reset and test buttons, still nothing. Any help would be...
Take cover off of electrical compartment, locate power on off switch, see if you have proper voltage before and after switch, if power is present locate thermostat, check the same way, also look for burnt wiring, Good luck.
Mar 04, 2010 | LG Heating & Cooling
Just put in a new ac unit and replaced a old one. old unit was 18000 btu and the new one is on 12,000 btu I used the same power outlet but the new ac unit starts up but then shuts down and seems like it is...
The 18,000 btu A/C is 230 volts, are you sure the 12,000 btu unit is 230 volts most are 120 volts.
Usually 12,000 btu is the biggest 120 volt A/C you can buy.
Jul 10, 2009 | Heating & Cooling
Heating & Cooling Logo
50 people viewed this question
Top Heating & Cooling Experts
Paul Carew
Dan Webster
Dan Webster
Donni Steen
