Question about Dometic Rooftop RV Air Conditioner
Dometic rv air conditioner well not run
I turned it on and it was working in adout 30 mimites it blow the bracker and now it just humms and blows the bracker.
  • Mike Butler
    Mike Butler May 11, 2010
    No fan coming on, just hum?
    Champion:
  • 233 Answers
Unfortunately this is generally a sign the compressor is bad. Not always, but generally. the compressor needs to be isolated and checked for shorts to ground. (it could also be another component or wiring issue that has shorted the unit to ground causing the breaker to trip.
Posted on Jul 31, 2009
What happens when ac turned on without 30 amp plug
Usually overload the circuit your plugged into. (Trip breaker) If the unit does run it will be on low voltage and shorten the life of the component. Possibly blow the start or run capistor.
Aug 10, 2014 | Dometic Rooftop RV Air Conditioner
RV. when furnace is turned on , fan on rooftop AC unit runs continually
i would say its the relay board or communication cabl between stat and board.
Jun 18, 2014 | Dometic Rooftop RV Air Conditioner
Air stop blowing cold but sill runs
What is the brand of rv ac you have?If you have a duo-therm I had the switch go out ..Not the one that says low-meduim-high but the one next to it that has various sub settings..
Jun 11, 2010 | Dometic Rooftop RV Air Conditioner
Dometic air conditioner blowing cool air
When the cooling slows down, but water is still running off, usually something is icing up. You can turn the unit off, and let it thaw, and try again. Sometimes, if the humidity is high, this is more pronounced. It sounds like you are low on refrigerant. That implies that you have a slight leak. You should have the unit serviced, and the leak repaired.
Best regards, --W/D--
Aug 01, 2009 | Dometic Rooftop RV Air Conditioner
Sounds like compressor is running but no air is blowing out vents
pull the cover and see if fan motor is running if not see if it is frozen by trying to turn blade if its free check for voltage to it. Its easy to replace yourself.
Jun 27, 2009 | Dometic Rooftop RV Air Conditioner
Rv air conditioner
Check the temperature control and see if it clicks when you turn it off and then back on. Check to see if the compressor is running. If the compressor is running but not cooling you may have a leak and lost the refrigerant charge.
Jun 27, 2008 | Dometic Rooftop RV Air Conditioner
Dometic Rooftop RV Air Conditioner Logo
129 people viewed this question
Top Dometic Heating & Cooling Experts
Bill Long
Donni Steen
mike cooper
Are you a Dometic Heating and Cooling Expert? Answer questions, earn points and help others
