Question about LG 42PC3D 42 in. Plasma Television
My LG plasma was working fine two hours ago when I turned it off. I just turned it on and first got a invalid input message and now it's a lime green screen. Help!
Green and black screen when I use turn Direct TV box
Try changing the input device to something you are sure, works such as a DVD player.
Switch off TV manually, switch off power, remove plug and retry after 48 hours.
If problem persists, please refer it to a qualified service technician.
Aug 02, 2012 | Panasonic Viera TH-42PX80U Plasma TV
LG plasma 50 inch tv with a fine vertical black line in the center of the screen that runs from the top of the screen to the bottom
Try changing the input device to something you are sure works. Switch off TV manually, switch off power, remove plug and retry after 48 hours. If problem persists, please refer it to a qualified service technician.
Jul 25, 2012 | LG 50PG20 50 in. Plasma HDTV
My LG Plasma TV Model 50PC1DRA displays the following message after powering it up and connecting to cable: "Invalid Format" All of our other in house TVs attached to the same cable are fully...
Hi
Thanks for using FixYa. Invalid format indicates issues with the PC Mode, if the signal is not out of range then check the input source.
Please accept the solution if the issue is resolved or post a comment for further assistance.
Thanks
Rylee
Sep 30, 2010 | Televison & Video
Sony KDS R50XBR1 TV, LIME GREEN PIC
if all sources and hdmi cable are good--you need the hdmi input board--dont know sonys letter designation
Jul 22, 2009 | Sony FD Trinitron WEGA KV-32FS120 32" TV
LG plasma tv screen is washed in magenta
This is normally only caused by two things, 1st- if your using the RGB inputs make sure the green is securely connected or possibly a bad set of cables. 2nd- If your not using that set up then I would say you have a defective main board. Have it looked at by a servicer if you cant find anything wrong with RGB Comp input cables.
Feb 20, 2009 | LG 42PX4DR 42 in. Plasma TV
INVALID FORMAT
the tv must see an input connected. try turning on the game before the tv.
Jan 06, 2009 | LG 42PX5D 42 in. Plasma HDTV
Hd tv doesn't work at all says invalid format
is the tv 720 or 1080. it wont work if your inputing 1080p to 720p or 1080i
Dec 11, 2008 | LG 50PC1DR 50 in. Plasma HDTV
Zenith Z42P3 "Invalid Format" message from upconverter DVD
Ran into the same problem with this DVD player and my LG tv. Try this:
Open the DVD tray, with the DVD tray open press the HDMI select button until the proper resolution for your tv is illuminated, put the DVD back in, close the tray and try again. Simple fix -- worked beautifully for me.
Good luck
May 01, 2008 | Zenith P42W34P 42 in. EDTV-Ready Plasma...
Vizio liquid crystal tv l32hdtv
Check the cable connections and/or replace the cables to the AV2 input.
If replacing the cable doesn't provide a solution, try running your DVD through the input. Since it works fine now, you would be checking the input AV2 by putting your working DVD. If the DVD plays with no problems, the input is fine.
Also try the VCR using coax into the TV instead of RCA into AV2. This will give you some idea about the condition of the VCR.
I suspect either the VCR or the cables.
Apr 22, 2008 | Vizio L32 32 in. LCD HDTV
LG 42PC3D 42 in. Plasma Television Logo
212 people viewed this question
Computer Repairing
Computer Repairing
