Cars & Trucks Logo
Steve Messier Posted on Feb 17, 2018
Answered by a Fixya Expert
Trustworthy Expert Solutions
View Our Top Experts
I have a 2005 Volvo v50 no fuel presure replaced fuel pump still no fuel presure
  • Jeffrey Turcotte
    Jeffrey Turcotte Feb 17, 2018
    Hi Steve Messier, I want to help you with your question, but I need more information from you. Can you please add details in the comment box? Is the pump coming on?
Marvin
Level 3:
Top Expert:
  • Volvo Master 85,242 Answers
  • Posted on Feb 17, 2018
Marvin
Volvo Master
Level 3:
Top Expert:
Answers
85242
Questions
28
Helped
29022533
Points
266281
Is the fuel pump relay working? jumper that relay to power the pump. If relay is ok then check the wiring to the pump.
5 Related Answers
emissionwiz
Marvin
  • 85242 Answers
  • Posted on Apr 17, 2009
SOURCE: When should a timing belt be replaced on a 2005
the recommended replacement is at 105,000 miles
Anonymous
  • 21 Answers
  • Posted on Sep 14, 2009
SOURCE: 2008 Volvo V50 - Cabin Air Filter Location?
It's under the dashboard. First you must dismount the accelerator pedal (!), remove some dashboard plastic on driver side. The filter is somewhere behind the central console.
I think it should be changed every two years. Look into the manual.
The company where you take the car for oil & filter change every year must change also this filter with no additional charges. Of course they charge you for the filter, which is not very exponsive.
Anonymous
  • 21 Answers
SOURCE: fuel filter location 05' volvo v50
If it's a 2.0D engine the diesel filter is in the front of the engine. It has a small metal protector over it for the case of a crash.
It is a black plastic "bottle" with two pipes on the opposite sides - left and right. It also has a connector - for the fuel heating.
Anonymous
  • 236 Answers
  • Posted on Feb 28, 2010
SOURCE: replacing fuel pump on 1992 Volvo 940
look in autozone, look up the part n then click on "view job diagram" hope that helps
Anonymous
  • 28 Answers
  • Posted on May 10, 2010
SOURCE: My 2006 Volvo V50 won't start.
Check the passenger foot area. The CEM is located there and many time passengers unplug connections with their feet unknowingly.
There is only thin insulation between the foot area and the CEM.
CEM= Central electronics module.
2006 V50 keeps getting airlocked have replaced leak off pipes vacuum tested fuel line from filter to tank and replaced sensors on diesel pump but problem is still there Any ideas on what else to do
there may be a tank breather hole in the fuel cap if so make sure it is clear or drive the car with fuel cap slightly loose see if you get an air lock again
Where is fuel pump on 2005 Volvo v50 2.0.d
Most likely there isn't one. There's only high-pressure pump under the hood, no standard pump in the tank.
That's why most people have problems with bleeding fuel lines after filter change.
Volvo v50 wont start sometimes
Check if fuel lines don't have air bubbles.
If you have diesel, then also check glow plugs and throttle body air flaps.
Sometimes Central Electronic Module causes problems with start and other troubles (airbags, ESP, wipers) and usually you need to clean relays connectors.
How to bleed fuel filter volvo v50 2005
You have to disconnect the return line from the fuel pump and suck the air out from the fuel system.
Volvo V50/S40 2005 ambient temperature sensor replacement
The sensor is right below the radiator by the bumper situated on the drivers side two clips and a plug and it is done.
Bleeding after changing diesel filter 2005 v50
You need to unplug the fuel return line from the fuel pump and suck the fuel back to the system on the pump and filter side.
3helpful
2answers
When should a timing belt be replaced on a 2005 volvo v50
Top Volvo Experts
ZJ Limited
ZJ Limited
Ronny Bennett Sr.
Ronny Bennett Sr.
Thomas Perkins
Thomas Perkins
Are you a Volvo Expert? Answer questions, earn points and help others
