Question about Rheem 40 Gallon FVR NATGAS Low WATER HEATER 6YR 22V40SF
Rheemglas Low Pressure Gas has Dirty Water
We are experiencing dirty water coming out of our hot water cylinder, which was installed new in 1990. It is starting to clog our tap mixers. After flushing it, it contains many flakes of dirt, or is it rust?
Does this mean that the inside of the cylinder is starting to rust. Is this the end?
    President:
  • 704 Answers
You've done well with having a water heater lasting much longer than the average. Most water heaters will last anywhere from 10-15 years with normal water conditions, somewhat shorter with mineral and sediment issues, etc. Since you've already flushed the tank, which is always the first thing to do, I think you've taken the right steps.
That being said, I believe your tank is failing and you should replace it soon, as having the contamination issues continue will reek havoc with your laundry and could ruin a lot of clothes.
Yes, getting 19 years is pretty good, but the time has come to replace it. Hope this helps you with your decision. Best Regards!
Posted on Jul 31, 2009
Rheem water heater about 3 years old. No hot water.
Get more fresh air to unit and see if that improves problem
Bad gas control valve
Low gas pressure
Bad vent
Lack of maintenance/ dirty combustion parts
Low amount of fresh air/ dirty air intake/ flame arrestor screen
http://waterheatertimer.org/How-to-troubleshoot-gas-water-heater.html
http://waterheatertimer.org/How-to-troubleshoot-gas-water-heater.html#intellivent
Rheem will tell you to call service technician
Gene
Oct 20, 2014 | Water Heaters
Rheem hot water heater not kicking flame to high heat
1) Copy following link to troubleshoot by type of gas control valve:
2) Bad gas control valve, low gas pressure, dirty combustion parts, inadequate venting, clogged flame arrestor screen located under burner
Mar 06, 2013 | Rheem Water Heaters
Piloit light on606 gas water wont satay lit
If pilot light has gas, then ECO is not tripped so water heater has not experienced overheating event.
Remaining suspects include bad thermocouple, bad air quality, not enough air, bad vent, water dripping down vent, backdraft down vent, hot attic with bad ventilation, low gas pressure, air in gas line, dirt water or debris clogging gas control thermostat, bad gas control thermostat, tripped FVIR, dirty pilot orifice, dirty combustion parts, damaged combustion parts from exposure to trace chemicals like bleach and wax.
Suspects include one or more from list above.
Start with thermocouple.
Open following links:
http://waterheatertimer.org/How-to-test-water-heater-thermocouple.html
http://waterheatertimer.org/How-to-install-gas-water-heater.html#troubleshoot
Oct 02, 2011 | Reliance Natural Gas Water Heater Control
Piliot light goes out
Oct 02, 2011 | Water Heaters
What can cause Hot/Cold spikes on an RTG74-XN
Crossover, low hot water flow, low water pressure, sediment in water lines or heater, heat exchanger needs to be de-limed, water filter needs to be cleaned, water heater temperature set too high, incoming water temperature too high or too low depending on model, MUD or PUD districts with pressure spikes, dirty faucet aerators, loose wires, bad sensor, faulty PD-board, bad venting, dirty burner and combustion parts, etc.
Crossover
http://waterheatertimer.org/Crossover.html
Clean water filter monthly, de-lime tankless yearly
http://waterheatertimer.org/pdf/Tankless-maintenance.pdf
http://waterheatertimer.org/pdf/Rheem-De-lime-tankless.pdf
No error code:
http://waterheatertimer.org/pdf/No-Error-Code.pdf
Overcoming fluctuating temperatures:
http://waterheatertimer.org/pdf/Bosch_Overcoming_fluctuating_temps.pdf
Resources:
http://waterheatertimer.org/Troubleshoot-Rheem-Tankless-water-heater.html
Sep 20, 2011 | Rheem Paloma PTG-74XN / RTG-74XN Natural...
Pilot light will not stay light
1) Open following link for how-to resources, illustrations, and service manuals for some brands of heater.
2) Many things can cause pilot problems, including bad thermocouple, air in gas line, low gas pressure, negative pressure in house, bad venting, very hot attic, lack of combustion air, dirty combustion parts and dirty pilot tube, bad gas control, reversed polarity on electrical outlet.
3) If pilot flame is clear blue and strong, then next step is check that thermocouple sits in the flame, and then change thermocouple. This is start point. Following step would be reading service manual for exact troubleshoot and testing steps.
4) If pilot flame is yellow-or-orange or weak, then clean dirty combustion parts including pilot tube and air intake. Might want to change thermocouple while combustion parts are removed for cleaning.
5) Take a moment and rate answer:
And take advantage of fixya expert assistance live.
For a price, expert works with you while you work on water heater or any do-it-yourself project.
Fixya is always less expensive than a service call.
Sep 05, 2011 | RTO W4 A.O Smith Gas Hot Water Heater...
Kenmore Water heater, Model # 153.339462, Pilot lights, burner burns for approx. 10 - 15 minutes then both go out. after which it is more difficult to light the pilot. I need ideas please
Clean combustion parts, clean air intake, get more air to water heater and see if problem continues.
Look at color of burner flame and pilot flame: if flame has yellow-and-orange instead of clear blue flame, then combustion parts need cleaning.
Pilot and burner problems can be caused by bad thermocouple, thermocouple not sitting in flame, weak pilot flame due to dirty tube or low gas pressure, air in gas line, no draft up vent, backdraft coming down vent, dirty combustion parts, clogged air intake, insufficient air, insufficient air quality, hot attic, bad gas control valve, etc.
Open following link for pdf resources, and illustrations for cleaning combustion parts, and some service manuals:
Sep 03, 2011 | Water Heaters
I have an old whirlpool gas water heater and the pilot will not stay lit.
Suspects include bad thermocouple, thermocouple slipped down and not in pilot flame, dirty combustion parts and pilot tube, dirty air intake, backdraft caused by other vent fans pulling air down water heater vent, water dripping down vent because of poor venting, air in gas line, low gas pressure, bad gas control valve, hot attic environment, tight house not allowing enough air:
Replace thermocouple:
http://www.youtube.com/watch?v=v0aBPsNg6vo
http://www.youtube.com/watch?v=xGQngzqrIEE&NR=1
Troubleshoot pilot:
http://waterheatertimer.org/pdf/Pilot-light-will-not-stay-lit.pdf
Clean combustion parts.
http://waterheatertimer.org/How-to-install-gas-water-heater.html#clean
Aug 24, 2011 | Water Heaters
Rheem 22V50F1 pilot won't stay lit. Changed thermo couple & it lit, ran then went out. Let it sit overnight & it lit, ran then went out. What next? p.s. The unit is 5 years old. Thanks
If pilot lights and flame is robust and clear blue, and pilot goes out later, then some suspects can be excluded: air in gas line, low gas pressure, thermocouple is overtightened (finger-tight + 1/4 turn), thermocouple not positioned correctly in the flame, dirty pilot tube.
If flame is yellowish and small: then clean pilot tube and combustion parts.
Remaining suspects can include: air in gas line, low gas pressure, bad gas control valve, tight house so household vent fans pull air down water heater vent that blows out pilot, hot attic with inadequate ventilation, water dripping down vent.
Open following links to read troubleshoot resources.
Aug 16, 2011 | Rheem 50 Gallon FVR NATGAS Water Heater...
Rheem 40 Gallon FVR NATGAS Low WATER HEATER 6YR 22V40SF Logo
111 people viewed this question
Top Rheem Water Heaters Experts
Donni Steen
gizmonix
Level 1 Expert
Are you a Rheem Water Heater Expert? Answer questions, earn points and help others
