Question about Whirlpool Ultimate Care II LSQ9549L Top Load Washer
My agitator does not work at all, everything else is perfect. Where can I get an exploded view drawing of washer and a parts list to do the repairs myself?
    Scholar:
  • 84 Answers
Go to www.partselect.com then put in your model number and the diagrams show up for you model washer. I go here all the time to look up parts for appliances. Hopefully that helped
Posted on Jul 31, 2009
How do I find a drawing/ exploded view of the front driveline/u-joints/cv joints on a 2003 ford ranger 4x4?
google " drawing/ exploded view of the front driveline/u-joints/cv joints on a 2003 ford ranger 4x4", several sites come up including a video on how to change them out
Dec 11, 2014 | Ford Cars & Trucks
Hello. My Kenmore 80 Series/ Heavy Duty(Model # 110.24852300) is shaking like crazy during it's spin cycles. I've been doing research online about this. I will proceed in turning it over and searching for...
It is not recommended to turn the washer over, or on it's side. These top loaders have a direct-drive gearcase that is filled with oil. Laying the washer down can cause oil to leak from the breather hole on top of the gearcase unit.
I would recommend you check the level of the washer before doing anything else. These model washers have an auto level system on the back two feet, followed by a manual level on the front two feet. The following link explains this leveling system and how to properly level the washer:
http://www.fixya.com/support/r3868923-level_whirlpool_top_loading_washer
An unlevel washer is the number one cause of off balance issues and vibration.
If you do wish to view the washer internal components, the correct way of accessing the interior is to remove the exterior washer case. This procedure is not difficult. The following link explains how:
http://www.fixya.com/support/r3631789-washer_case_removal_whirlpool_top
Other causes of vibration (if the washer is level):
1. Loose suspension springs on the lower support under the drum.
2. Loose agitator bolt causing the agitator spin unbalanced.
3. Loose spanner nut under the agitator causing the wash tub to be loose.
4. Suspension pads under the drum worn out and requiring replacment.
You can view exploded view diagrams of your washer at any of the following websites to assist you with your inspection:
searspartsdirect.com
pcappliancepartspros.com
Refer the "Washer Base" drawing for a view of the suspension components. Refer to the "Agitator" parts list for a view of the agitator components.
If you need further assistance, please let me know. I hope you find this information helpful.
May 04, 2011 | Washing Machines
In the agitator, how do i remove the clear plastic cam holder so i can replace those little cams so the agitator works again
If the clear plastic piece you are referring to is the center post cap, it simply lifts up. If the model number is correct, the cap is listed as item 23 in this parts drawing:
http://pcappliancerepair.com/model-display.php
Sometimes it can become gunked up with detergent and/or softener residue which can make it a little difficult get off. If it is on too tight, you can try reaching it with a pair of pliers and gently pull straight up on the handle portion. Make sure you do not damage the cap is it is required to provide and air gap to keep water from entering into the gearcase (transmission) shaft.
If you need further guidance, the following link explains how to access and replace the agitator dogs:
http://www.fixya.com/support/r3608577-replacing_agitator_dogs
The part number for the agitator dogs is included in the instructions I provided. For a little more, you purchase the entire cam assembly (which includes the dogs, the cam and the bearing) for about $8 to $10. It is listed as item 9 in the drawing I provided and the part number is 285809.
Replacement parts can be found at any of the following websites:
repairclinic.com
All these sites are reputable, offer great service and have competitive pricing, so shop and compare. The first three sites have helpful exploded view parts diagrams to assist you with locating and properly identifying the parts you may need.
If you have questions, please post back and let me know. I hope this helps you.
Jun 01, 2010 | Whirlpool Ultimate Care II LSQ9549L Top...
Agitator spindle isn't revolving
If the problem is just the agitator auger not working, but everything else does, you may just have a worn agitator cam assembly, worn agitator dogs, loose agitator bolt, or all of the above. The following link explains what agitator dogs are and how to access them:
Whirlpool manufactured washers (such as Kenmore) use a split agitator design. The top half is known as the "auger, while the lower half is the agitator. Between the two pieces is a cam assembly, with small teflon teeth known as "dogs". There's also an agitator bolt that holds the entire assembly to the center post.
If the auger (top half of the agitator) is slipping, I would suspect the dogs or cam assembly need to be replaced. The part number for the dogs is included in the link I provided. For a little more you can purchase the entire cam assembly which includes the dogs, the cam, the cam seal and thrust bearing.
If the entire agitator appears loose or slipping, check the agitator bolt to ensure it is tight. DO NOT overtighten as this can restrict movement of the agitator or damage it. Tighten until snug.
Replacement parts (if required) can be purchased at any of the following websites:
repairclinic.com
All these sites are reputable and offer great service with competitive pricing, so shop and compare. The first three sites I listed also include helpful exploded view parts diagrams to assist you in locating and properly identifying the parts you need. If you do not wish to order parts on line, use the part numbers from the Sears website and go to your nearest appliance parts retailer. These parts are commonly sold as part of their in-store inventory.
Read through the information provided and let me know if you have any questions. I hope this is helpful to you.
May 30, 2010 | Whirlpool Ultimate Care II LSQ9549L Top...
Agitator problems..
If the problem is just the agitator not working, but everything else does, you may just have a worn agitator cam assembly, worn agitator dogs, loose agitator bolt, or all of the above. The following link explains what agitator dogs are and how to access them:
Whirlpool manufactured washers use a split agitator design. The top half is known as the "auger, while the lower half is the agitator. Between the two pieces is a cam assembly, with small teflon teeth known as "dogs". There's also an agitator bolt that holds the entire assembly to the center post.
repairclinic.com
All these sites are reputable and offer great service with competitive pricing, so shop and compare. The first three sites I listed also include helpful exploded view parts diagrams to assist you in locating and properly identifying the parts you need. If you do not wish to order parts on line, use the part numbers from the Sears website and go to your nearest appliance parts retailer. All these parts are commonly sold as part of their in-store inventory.
Thank you for posting your model number. The part numbers you may need are as follows:
Item 10 - If just replacing the Agitator Dogs: 80040.
Item 9 - If replacing the entire Cam Assembly: 285809 (includes the Dogs and the Cam Thrust Bearing).
Item 22 - Spacer Thrust Bearing: 3951608
All these parts can be viewed under the "Agitator, Basket and Tub Parts" section of the parts resource websites I listed for you. The last digit of your model number is a "zero" (0), vice the letter "O".
If you have any questions, please post back and let me know. I hope this is helpful to you.
May 26, 2010 | Whirlpool LSQ9030P Top Load Washer
Good afternoon - I have a Whirlpool model LSR7233EQ0 washer. The washer works fine in regards to draining, filling, lower agitator works...however, the top agitator does not engage and almost sounds like...
Whirlpool uses a split agitator design. The upper portion is called the auger, while the bottom is called the agitator. Between these components is a agitator cam assembly. This problem is commonly caused by worn agitator dogs or the agitator cam assembly. The following link explains what the dogs are and how to replace them:
The part number is included in the link provided. You can purchase replacements at pcappliancerepair.com for about $5. For a little more you can purchase the entire cam replacement kit, which includes the cam, the thrust bearing, and the dogs. For the model number you have listed, the part number for the kit is 285811 and sells for about $11.
NOTE: You can refer to the excellent exploded view parts diagrams the web site has to offer for assistance. Whirlpool also recommends the application of a little grease on the thrust washer. The part number for their recommended grease is AP3098553.
If you have any questions about this repair, please let me know. I hope this helps you.
NOTE: DO NOT overtighten the agitator bolt. This can cause damage to the plastic, or restrict the agitator movement. Tighten until snug only.
Dec 16, 2009 | Dishwashers
Top Part of agitator does not agitate?
Whirlpool manufactured washers (such as your Kenmore) have a split agitator design. The upper portion is called the auger, while the bottom is called the agitator. Between these components is a agitator cam assembly. This problem is commonly caused by worn agitator dogs on the agitator cam assembly. The following link explains what the dogs are and how to replace them:
http://www.fixya.com/support/r823955-replacing_agitator_dogs
The part number is included in the link provided. You can purchase replacements at appliancepartspros.com for about $5. For a little more you can purchase the entire cam replacement kit, which includes the cam, the thrust bearing, and the dogs. The cost is usually about $11 or $12 and lists under the "Agitator Part" section.
Nov 27, 2009 | Dishwashers
Top of aggitator does not turn.
This problem is commonly caused by worn agitator dogs on the agitator cam assembly. This is a very simple and inexpensive repair. The following link explains what the dogs are and how to replace them:
The part number is included in the link provided. You can purchase replacements at appliancepartspros.com for about $5. For a little more you can purchase the entire cam replacement kit, which includes the cam, the thrust bearing, and the dogs. If the model number you listed this under is correct, the part number for the kit is AP3138838 and sells for about $11.
NOTE: You can refer to the excellent exploded view parts diagrams the web site has to offer for assistance. The parts I have referenced are listed as items 9 and 10 under the Agitator Parts section. Whirlpool also recommends the application of a little grease on the thrust washer. The part number for their recommended grease is AP3098553.
Nov 06, 2009 | Whirlpool GSW9800PW Washer
I have a Whirpool washer with a two stage agitator. Top part stop
Oct 27, 2009 | Washing Machines
Whirlpool Ultimate Care II LSQ9549L Top Load Washer Logo
299 people viewed this question
Sal De
Gerry Harvey
Gerry Harvey
