Question about Amana Comfort Zone 12M32PBEH Air Conditioner
New ac is blowing hot air in the cooling stage. i have a RTC30C2A R-410A remote heat pump and a BBA or BBC blower cabinet. both of these are AMANA.
  • mcoll023 Jul 31, 2009
    this is a new install and the unit is coming on but even in heat mode it blows hot air. If valve is stuck how do I fix this?
    President:
  • 2,559 Answers
First make sure the outside unit is coming on.
Has it worked this way since installed?
If so,It may have never had the charging valves opened.
If not,
Either something is not wired properly or the reversing valve is stuck.
Posted on Jul 31, 2009
  • Randy Hough
    Randy Hough Jul 31, 2009
    If it heats in both modes,It is more likely improper wiring at the thermostat.
Why is hot air blowing out of air conditioner
If it is a wall mounted one like the one in the picture and it is fairly new, and possibly a Fujitsu or LG, it may be by design. Modern AC can run backwards to become a heat pump and takes the cold air from outside, extracts warmth and blows it inside for the winter months. The remote has different symbols for heat or cool.
If not new, and only blows cold it needs refrigerant gas, or at worst a new compressor..
Oct 30, 2015 | Heating & Cooling
Amana PTH153B50AM AC & Heat pump. fan works AC & heat don't. I was told by the guys who installed it to unplug it to reset the termostat but that don't work either. I turn it on cool &...
Jane, what you really need is the Owners Manual for you discontinued model AC/Heat Pump.
Call Amana Customer Support 1-800-843-0304 and they can furnish you one. Either by email attachment or by snail mail.
Hope this helps you. Please let me know.
Jun 20, 2011 | Amana PTH153B50AM Air Conditioner
Haliburton canadian spa hot tub heating well but blowing cold air
Since the blower simply takes air from inside the spa cabinet and blows it into the spa, the only solution is to get a heated blower, or insulate the interior of your spa cabinet better.
Mar 23, 2011 | Pool & Spa
Amana PGD60C1152E no heat
Your thermostat Function 0170 must be set to "1" for Single Stage Heat/Cool. Function 0180 must be set for "0" for Heating Fan Control. Function 0240 must be set for "5" for the Heating Cycle Rate for your <90% Gas Furnace. If you have already done these steps or if, after doing these steps, you continue to experience a problem, you problem could be with your Gas Furnace. I'm including some links for information on your system and thermostat that include wiring diagrams.
http://johnstonesupply9.com/TechDocs/Amana/Package%20Units%20Gas-Electric/PGD%20Pkg%20Gas%20Ele/PGD%20Tech%20Info.pdf
http://customer.honeywell.com/techlit/pdf/PackedLit/69-2206EF.pdf
Mar 06, 2010 | Amana Haier AP125HD Air Conditioner
Reversing valve wire kills either heat or AC
Your solution is throw that Hunter tsat away and get a good one. You need one with 2 stage heat 1 stage cool heat pump tstat. Heat pump tsta has w,y,o,g,w,rnad w2. Don,t buy one without this one it. I have been in this business 45 years and people are always getting sold the wrong tstat at Lowe or Home Depot. Those guys dont know jack about Tstats. Keep in touch Rus GOOD LUCK. Get the right tstat follow the letter on wiring and you wont have any problem.
Nov 19, 2009 | Heating & Cooling
Heater not blowing hot air display says lo
when the coils freeze up , from intake of outside air, when using the heat pump mode, the unit will try to defrost the coils before going back to heat mode. mine did this alot. does it kick back to heat after a few mins? also after 2 years , mine started having issues with the exhaust blower control and would go into warp mode and bang noise.seems like common issues for this unit.whether the amana, or haier version.
Dec 13, 2008 | Amana Haier AP125HD Air Conditioner
1997 Amana 2 or 2.5 ton heat pump, 13 seer - air handler only blows 4-5 min
do you have a totaline t-stat. they and some other brands have a fan recirculation setting in the installers menu.
this is assuming that this happens in addition to the heating or cooling normally
Jul 02, 2008 | Amana PTH123B25AJ Heat Pump Air...
Mitsubishi wall unit srk50zg condenser src50zg air con not heating new install
Double check your wiring .if the indoor fan is not blowing then you either have an electrical issue OR bad blower motor .
May 24, 2017 | Refrigerators
Amana Comfort Zone 12M32PBEH Air Conditioner Logo
47 people viewed this question
Top Amana Heating & Cooling Experts
Dan Webster
Dan Webster
Donni Steen
Bill Long
Are you an Amana Heating and Cooling Expert? Answer questions, earn points and help others
