Question about ESD 9210 Radar Detector
I need a speaker - ESD 9210 Radar Detector
    Renaissance:
    An user who is expert in 3 categories / brands.
  • 1,810 Answers
Take apart an old alarm clock or a cheep alarm clock try and get the cam general size
Posted on Jul 31, 2009
Need help with altec lansing ada 745 4.1 speakers
Does the right front speaker need to work in order for the whole speaker system to work?
The whole system can still work with or without it.
Here is an additional tip how to ..... Computer Speakers
Sep 29, 2012 | Altec Lansing ADA745 4 Speakers
I need to find out how to mount stereo MA-10D speakers to a wall. I can't see any mounting capabilities on the back, sides, top, or bottom of the speakers. Has anyone successfully mounted speakers like...
Hmmm. .U don't have option given for speakers to fix them onto the wall. You have to do the following steps.
Things U need are:
  • Masking Tape
  • Level
  • Pencil
  • Keyhole saw
  • UL Class 2 speaker wire
  • Fish tape
  1. Locate the studs closest to where you'd like to install your speaker. You'll want to install the speakers in between the studs.
  2. Tape the template that comes with the speakers in the center. Check to make sure your configuration is level and plumb. Your template will tell you exactly what size hole to drill to insert the speakers. Trace the opening you need to cut into the wall or ceiling
  3. Cut the hole using a keyhole saw or a drywall saw. Keep the section you cut open in case you can't install the speaker and need to patch the hole you just made. If the hole reveals plumbing, you need to relocate the speaker
  4. Run the speaker wire through the wall, or fish speaker wire from an existing installation.
  5. Install the brackets to support your speaker if one is included with your speakers. Some speakers use clips to secure them to the inside of the wall.
  6. Strip the protective coating from the end of the speaker wire, and insert it into the speaker jacks. Test your speakers now if the wires are attached to an audio source. If not, locate the other end of the speaker wire and hook it up. Testing now will save trouble if you run into problems.
  7. Surround the speaker with insulation to enhance the sound. Secure the speaker into place, and do any necessary patching or painting
Aug 27, 2010 | Roland MA-10D Main / Stereo Speaker
Installation of speakers
The speakers require the AC adapter to be connected for the speakers to function. The AC adapter powers the amplifier of the speakers
http://support.dell.com/support/edocs/acc/ada215/ada215.pdf
Apr 18, 2010 | Dell A215 Computer Speakers
Have a dell computer with acer plug in speakers which are not playing or showing as being connected, don't have a disk for the speakers is there somewhere i can download the information i need, speakers...
Try connecting the speakers to a different computer, to see if the speakers work at all.
It's 100% "normal" for the speakers to *NOT* be "detected" by the computer -- the speakers simply are _NOT_ a "plug-and-play" device; there are just "dumb" electro-mechanical units.
There _never_ is a need for a "disk" for speakers;
you never need instructions on how to use a pencil, either. :-)
Apr 04, 2010 | Acer (90.18612.36B) Computer Speakers
Need connector to a sony sa-va1 right and left speakers
Are you looking for connectors on speakers or need wires that hooked in speaker and home theater system?
Please intimate model number that is written on main home theater system to provide you info about speaker wires.
Jul 11, 2009 | Sony SA-VA1 Rear Speaker
I need a wiring diagram for my bluebird
Here you go.
Battery: blue/yellow
Accessory: gray
Ground: brown
Illumination: green
LF speaker (+): pink
LF speaker (-): violet
RF speaker (+): light green
RF speaker (-): blue
LR speaker (+): black
LR speaker (-): yellow
RR speaker (+): red
RR speaker (-): white
Jun 03, 2009 | 1990 Toyota Corolla
Need the speaker wiring diagram for Pioneer KEH-1080
Yellow = +12V constant; Red = +12V switched; Black = ground; Blue-white = remote on; White/White-black = FL speaker; Grey/Grey-black = FR speaker; Green/Green-black = RL speaker; Violet/Violet-black = RR speaker.
--- hope that helps ya
May 20, 2009 | Pioneer Car Audio & Video
Need to install new radio
This should Help:)
Battery WHITE/YELLOW (+) RADIO HARNESS
Accesory WHITE/RED (+) RADIO HARNESS
Ground BLACK (-) RADIO HARNESS
Illumination RED/BLACK (+) RADIO HARNESS
Dimmer RED (-) RADIO HARNESS
Power Antenna YELLOW/WHITE (+) RADIO HARNESS
Amp Turn On YELLOW/WHITE (+) RADIO HARNESS
LF Speaker (+) WHITE
LF Speaker (-) ORANGE
RF Speaker (+) YELLOW
RF Speaker (-) BROWN
LR Speaker (+) RED
LR Speaker (-) GREEN
RR Speaker (+) BLUE
RR Speaker (-) BLACK
Oct 25, 2008 | 1991 Honda Accord
No sound. Do I need driver software for these speakers?
shouldn't need it for speakers. you do however need one for the sound card on your computer. if the speakers were an upgrade and you know the sound card works... check that it is plugged into the proper hole at the back of the computer and that there is power to the speakers.
Robert
Aug 29, 2008 | Yamaha YST-MSW10 Computer Speakers
ESD 9210 Radar Detector Logo
157 people viewed this question
Top Cobra Vehicle Parts & Accessories Experts
John Nolan
Jason
Are you a Cobra Vehicle Part and Accessory Expert? Answer questions, earn points and help others
