Question about Frigidaire FEF352 Electric Kitchen Range
Oven overheating set oven temp to 350 degrees and in a matter of minutes temp rises to over 550 degress. Top element stays on
  • braintastitc Apr 05, 2009
    I have the same problem with my frigidaire oven overheating Model PLEFM399DCB
Soulvisitor
  • 1113 Answers
SOURCE: Oven Temp Problems
I be changing the temp sensor
Posted on Feb 09, 2008
freetek
  • 5568 Answers
SOURCE: Whirpool electric range - RF196LXMQ - Will not reach 350 degrees
When using Broil, it is normal for only the top element to work and it depends on the oven whether both should be on or not for baking but typically, baking does not use the upper element otherwise it could burn baked goods.
If setting the temperature higher than 350 does not cause the lower element to turn on, then it's likely that the thermostat has failed and can no longer respond to the temperature set.
The fact that both elements work under some conditions means that both of the heater elements are working at least some of the time. Because of the primitive nature of the elements, it isn't possible for them to just become 'weak' but they can interrupt themselves if there is a break in the resistance element but you could only separate the two possibilities by measuring the hot coil and that would be difficult unless you can pull the range out and access the AC feed lines that go to the element. Obviously, the power would have to be disconnected and the measurement done quickly so the element didn't have time to cool and regain continuity.
Posted on Nov 27, 2008
  • 29 Answers
SOURCE: We have a frigidaire electric
CHECK TO BE SURE THE BAKE ELEMENT IS GLOWING ORANGE WHEN SET TO BAKE.
Posted on Jan 29, 2009
buffalonyman
  • 1865 Answers
SOURCE: I thank i need to replace thermostat in tappan
Go to this link and select your model number. It will take you to a set of drawings and parts list
http://www.apwagner.com/index.php?main_page=part_finder&searchType=model_number&keyword=tgf320
Posted on May 14, 2009
Maytag317
  • 1136 Answers
SOURCE: Oven temperature does not get hot enough.
Hi, It sounds like the ignitor might be getting weak and opening the gas valve conditantly. Try setting a temperature and watch to see the ignitor glow. The flame should ignite within 30-45 seconds. If the flame ignites to heat rith away, it should get up to temp before shutting down.
I hope this helps you. Please let me know if I can assist you further with this issue.
Thanks
Vic
Posted on Jun 24, 2009
Frigidaire oven temperature unreliable.
Is this an electric oven? Sound like a bad breaker to me if it is.
Dec 22, 2016 | Frigidaire Ovens
Oven is over heating to set temp
Well if that is really happening you would need to make sure that the temperature gauge is working properly
Jul 31, 2016 | Frigidaire Gallery 30" Self-Cleaning...
Oven temp fluctuates
It is normal for the thermal device to turn on and off. Obtaining a steady temp is not always possible. When setting a temperature on some ovens, they have what is called a tolerance point. That means a set temperature has a range of a few degrees up or down. At the Down point, the oven is triggered to energize the coils and bring the interior of the oven back to the settings desired. The other factor is opening the oven and allowing cool air to enter, or in some cases a leaking door seal allows air to enter and heat to escape.
Feb 26, 2014 | Kenmore 30" Slide-In Electric Range...
Oven temp heats higher than set
The control board is bad. One of the relays has fused and you will need to replace the control board.
Jan 07, 2012 | General Ovens
Our frigidaire range oven is not able to hold temp...if I set it to 350 it may go as high as 550...but it doesn't always rise that high but it never goes to the temp set or stay at it.
Hi
This means a loose/broken wire on the oven temp sensor or the oven temp. sensor itself is bad and should be replaced. To solve this issue test the oven temp. sensor, it should read between 1080-1120 ohms, if the rating is more then that and the door appears to be closing fine then it is the control board that is bad and should be replaced. Hope this helps...please post back for further assistance.
Daniel
Aug 06, 2011 | Ovens
G E oven temp fluctuation
No, that is just fine. As a matter of fact, older ranges often had 50 to 60 degree swings in temp. Your oven temp (assuming your thermometer is dead on accurate) is 347 + 365 / 2 = 356 degrees when set at 350. I never mess with ovens which are within 10 degrees of set temp. (when checking the temps, make sure to take the readings after the oven has cycled on and off at least three times, and use a good digital oven calibration thermometer)
Mar 18, 2009 | Kitchen Ranges
Temp stuck on 100 degrees
try unplugging the range for at least 30 minutes
Feb 08, 2009 | Amana ACF3355AS Gas Kitchen Range
Adjust temp level of the oven .. model 34ja-5tkxw
Press the bake key.
Adjust temperature to 550 degress.
Press the bake key again and hold it for 3 seconds.
The temperature +/- should appear.
You can then adjust temp +/- 35 degrees.
Mar 24, 2008 | Magic Chef CER3725AA Electric Kitchen...
Kenmore electric oven
Sears Kenmore Electric Wall OVen, Mod.#9114012192 purchased in 1993. Set oven for 425 degrees, reaches set temperature, stays on about 10 minutes and temp. display goes out and oven starts cooling down. Will not stay on desired temp.to cook. Can you tell me what my problem is? Thanks. Doug.
Dec 02, 2007 | Ovens
Frigidaire FEF352 Electric Kitchen Range Logo
383 people viewed this question
Top Frigidaire Kitchen Ranges Experts
Dan Webster
Dan Webster
Ismael Rodriguez...
Paul Carew
Are you a Frigidaire Kitchen Range Expert? Answer questions, earn points and help others
