Question about Car Audio & Video
When ignition switch is turned on - voltmeter goes to 8 volts-when engine is started and running voltmeter remains at 8 volts-battery is staying up - what is the problem?
  • zoomer441 Jul 31, 2009
    The voltageregulator appears to be builtin to the alternator however it may be possible to remove
    it from the outside. Alternater tested 13.99 volts at O'Reily.
    President:
  • 1,714 Answers
Your Alternator is not functioning correctly. The output to the battery when running should be 14.5 volts DC. Usually the voltage regulator is built into the alternator, but not always. It could be the voltage regulator if it's separate from the alt. Pull into an automotive store and have them test it for you and they can tell you what's failed free of charge.
Posted on Jul 31, 2009
  • Craig Butler
    Craig Butler Jul 31, 2009
    Did they test it in your car? Was it hooked up to the battery? Is your meter working ?
    If they said you had 13.9 volts, that sounds good...
    Are you having trouble starting or any voltage problems?
Why doesn't engine turn over?
flat battery, loose dirty connections , faulty starter motor
Mar 23, 2016 | Motorcycles
2005 Honda VTX 1300 R battery load test
Hi, Anonymous you have a bad battery or faulty charging system, now it is time to put on your Battery Priest Robe and prepare yourself for the Ceremonial "LOAD TEST" but before you begin, maintenance type lead-acid batteries must be topped off with distilled Holy Water and all batteries must offer their terminals to the battery charging altar to receive the Sacred Infusion of Holy Ions until they have reached a 100% full charge of 12.5 volts or better. No matter how new the battery is, do not be lured into the false sense of "it's OK it has 12.5 volts" and not doing the test below, it could have little or zero "AMPERAGE" causing the battery to be faulty and must be replaced, AGM maintenance free batteries fall into this scenario more so than lead-acid types.
Below is a quick and easy test to see if your battery is in good condition or needs Last Rites and must be replaced.
1. Make sure the bike is in "NEUTRAL"
2. Disconnect the spark plug cables.
3. Adjust voltmeter to DC volts 20-volt range
4. Place the voltmeter leads to the battery terminals.
5. Turn the run/off switch to run.
6. Turn the ignition switch on and press the starter button.
7. Watch the voltmeter as your engine turns over for 10 seconds.
8. If the voltage drops below 9.6 volts, the battery is faulty and must be replaced I "HIGHLY" recommend a maintenance free AGM battery they typically have more amperage for cranking.
9. Reconnect the spark plug cables if your battery is good and the bike starts ok, place the voltmeter leads on the battery and rev the engine to a steady 2500 RPM the voltmeter should read 14.5 volts DC anything in the 13's or less you have a charging issue that needs to be diagnosed and repaired.
For more information about your issue and valuable "FREE" downloads that you will need for viewing or printing please click on the blue links below. Good luck and have a wonderful day.
How to test motorcycle battery
How to Test Your Motorcycle or Powersport Battery
Honda VTX1300S Service Manual
http://www.partsfish.com/page/oem-parts-for-honda
Honda VTX1300C VTX 2004 Owner Manual
Jul 02, 2013 | 2005 Honda VTX 1300 R
Zx6r 2004. Bike ran great for two months. Went out to dinner last night and came out to my bike not starting. Trailered it home, started when taking off trailer. Went for a 15 minute ride and parked it....
Hi, Matt it saddens me to inform you that you have to put on your Battery Priest Robe and prepare yourself for the Ceremonial "LOAD TEST" but before you begin, maintenance type batteries must be topped off with distilled Holy Water and all batteries must present their terminals to the battery charging altar to receive the electrical infusion of Holy Ions until they have reached a 100% full charge of 12.5 volts or better.
1. Start by disconnecting the spark plug cables.
2. Adjust voltmeter to DC volts 20-volt range
3. Place the voltmeter leads to the battery terminals.
4. Turn the run/off switch to run.
5. Turn the ignition switch on and press the starter button.
6. Watch the voltmeter as your engine turns over for 15 seconds.
7. If the voltage drops below 9.5 volts, the battery is faulty and must be replaced.
For more information about your issue and valuable "FREE" downloads that you will need please click on the blue links below. Good luck and have a wonderful day.
ZX6R 636 Bike won start
Kawasaki NINJA ZX6R My bike won start Starter problem or discharged battery
Kawasaki Ninja ZX6R Service Manual
OEM Parts for Kawasaki
Kawasaki Ninja ZX 6R Owner Manual
How to Tell if Your Battery is Bad in 3 Easy Steps
May 18, 2017 | 2007 kawasaki Ninja ZX6R
Just bought a new starter and battery for my custom bike it has a 113ci S&S motor no compression release. Battery has full charge when I hit the starter sometimes it turns over good and sometimes it...
Hi, James you have a bad battery or faulty charging system, now it is time to put on your Battery Priest Robe and prepare yourself for the Ceremonial "LOAD TEST" but before you begin, maintenance type lead acid batteries must be topped off with distilled Holy Water and all batteries must offer their terminals to the battery charging altar to receive the Sacred Infusion of Holy Ions until they have reached a 100% full charge of 12.5 volts or better. No matter how new the battery is, do not be lured into the false sense of "it's OK it has 12.5 volts" and not doing the test below, it could have little or zero "AMPERAGE" causing the battery to be faulty and must be replaced, AGM maintenance free batteries fall into this scenario more so than lead acid types.
For more information about your issue and valuable "FREE" downloads that you will need please click on the blue links below and for more specific information or questions at no charge please feel free to contact me at xlch@mail.com. Good luck and have a wonderful day.
Test Your Battery in 10 Seconds Reliable Load Test with Only Multimeter
http://racetechelectric.com/files/pdf/rte_troubleshooting_flow_chart.pdf
Harley Charging System Check
Checking your harley Stator charging system Insulation breakdown
Jun 26, 2017 | Motorcycles
Starter keeps on running
Hi, Calvin your starter motor stays engaged because the solenoid positive plunger contact plate/disc has spot welded itself to the negative contact shoes usually caused by low battery voltage and/or a faulty starter relay, your starter motor has two main systems the motor itself and the starter solenoid which transfers high amperage to the motor enabling it to turn over your engine, your issue only involves the starter solenoid and can be repaired in most cases. The solenoid is the part that has a large copper stud protruding from it that the positive battery cable connects to. Start by disconnecting the battery negative cable and wrapping the cable terminal with any kind of tape so it will not accidently touch metal and make all electrical circuits hot again, remove the starter solenoid cap and with a screwdriver break away the contact plate from the shoes and clean/dress all electrical arc residue. In order to diagnose the starter circuit, you must start with a fully charged battery, 12.5 volts or better and be able to pass a proper "LOAD" test if necessary. The battery cables and terminals must be clean and tight. The "NEGATIVE" cable is famous for corroding and or breaking inside the harness, check the terminals at both ends. Check your starter relay with a test light for continuity, it could be faulty due to corrosion and sticking in a closed configuration, another claim to fame. Finally, there is the starter solenoid, low battery voltage or faulty battery connections will cause extremely high amperage at the plate and contact shoes and rob the hold in coils of much-needed voltage. In extreme cases, the solenoid plunger plate will literally spotweld itself to the contact shoes, keeping the circuit closed and thus permanent engagement. Another scenario is unacceptable voltage drop to the starter solenoid from the ignition switch to the starter relay to the starter button, and finally to the solenoid. Remove the starter relay wire from the starter solenoid and hook up the positive lead of your voltmeter to the relay wire connector and ground the negative lead. Turn on the ignition switch and depress starter button, the voltage reading should be no more than 1/2 volt less than the battery voltage. If it is more than 1/2 volt you need to backtrack that part of the circuit with your voltmeter until you find the voltage robbing offender. Next, remove the solenoid plunger, dress the plate and the contact shoes of arching residue and make sure the contact shoes are tight and secure. If you have done all of the above, replace the starter relay wire, hook up your voltmeter to the battery and check the voltage drop when you start the engine, anything below 9 volts could indicate a faulty battery and a proper "LOAD" test should be performed.
Mar 20, 2017 | Motorcycles
My V-strom died the other day because I let clutch out too fast. After this I attempted to restart by pulling clutch in and hitting start button while bike was still in gear. The bike lunged forward a...
Hi, Geakins you have a bad battery or faulty charging system, now it is time to put on your Battery Priest Robe and prepare yourself for the Ceremonial "LOAD TEST" but before you begin, maintenance type lead acid batteries must be topped off with distilled Holy Water and all batteries must present their terminals to the battery charging altar to receive the electrical infusion of Holy Ions until they have reached a 100% full charge of 12.5 volts or better.
HOW TO CHECK YOUR CHARGING SYSTEM and CHANGING the STATOR and REGULATOR...
Suzuki DL650 Service Manual
OEM parts for Suzuki
Suzuki dl650 Owner Manual
Jun 02, 2017 | 2005 Suzuki DL 650 V-Strom
No spark from coil 1991 chrysler labaron v 6
Start by testing the ignition coil primary, and secondary resistance.
To measure the primary resistance, connect an ohmmeter between the positive (+) and negative (-) terminals (the terminals which are connected to the engine wiring harness) on the coil. To test the secondary resistance, connect an ohmmeter between the positive (+) coil terminal and the high voltage cable terminal on the coil. Then, measure the resistance between the positive (+) coil terminal and the coil case; the resistance for the case should exhibit infinite resistance. For coils manufactured by Diamond, the primary resistance at 70-80°F (21-27°C) should be 0.97-1.18 ohms and the secondary resistance should be 11,300-15,300 ohms. Coils built by the Toyodenso company should exhibit a primary resistance at 70-80°F (21-27°C) of 0.95-1.20 ohms and a secondary resistance of 11,300-13,300 ohms. Replace any coil with a new one if it does not meet the specifications.
FAILURE-TO-START TEST Before proceeding with this test make certain that spark has been checked for at the coil. Refer to the ignition coil testing procedures. Failure to do this may lead to unnecessary diagnostic time and wrong test results. CAUTION
Be sure to apply the parking brake and block the wheels before performing any test with the engine running.
  1. Check the battery voltage. It must be at least 12.4 volts to perform the test. If the battery voltage is not at least 12.4 volts, refer to Section 1 for battery charging procedures.
  2. Crank the engine for 5 seconds while monitoring the voltage at the coil positive (+) terminal. If the voltage remains near zero during the entire period of cranking, refer to Section 4 for the On-board Diagnostic checks. The checks will test the PCM and the auto shutdown relay.
  3. If the voltage is at near-battery voltage and drops to zero after 1-2 seconds of cranking, refer to Section 4 On-board Diagnostic procedures. The problem is likely to be related to the distributor reference pick-up circuit to the PCM.
  4. If the voltage remains at near battery voltage during the entire 5 seconds, with the key OFF, remove the PCM 60-way connector. Check the 60-way connector for any terminals that are pushed out or loose.
  5. Remove the connector to the coil positive (+) and connect a jumper wire between the battery positive (+) terminal and the coil (+) terminal.
  6. Using the special jumper wire shown in the illustration, momentarily ground terminal No. 19 of the 60-way connector. A spark should be generated when the ground is removed.
  7. If a spark is generated, replace the PCM with a new one.
  8. If no spark is generated, use the special jumper wire to ground the coil negative (-) terminal directly.
  9. If a spark is produced, inspect the wiring harness for an open circuit condition.
  10. If no spark is produced, replace the ignition coil with a new one.
TESTING
  1. Check for stored trouble codes, then proceed as follows:
    • Fault code 11 - proceed to the next step.
    • Fault code 54 - proceed to step 6.
    NOTE: Before proceeding, verify that a minimum of 12.4 volts is available from the battery for operation of cranking and ignition systems.
  2. Test the distributor pick-up signal reference circuit as follows:
    1. Turn the ignition switch to the OFF position.
    2. Unplug the distributor pick-up connector.
    3. Remove the coil wire from the distributor cap and have an assistant hold it 1⁄4 in. (6mm) from a good engine ground.
    4. Turn the ignition switch to the ON position.
    5. Connect a jumper wire to the gray (GY) wire terminal and touch the other end of the jumper wire to the black/light blue (BK/LB) wire terminal on the distributor harness connector several times. While performing this, observe the coil wire.
      • If there is spark from the coil wire, proceed to the next step
      • If there is no spark from the coil wire, the problem is in the engine controller or wiring.
  3. Check the power supply to the distributor reference pick-up as follows:
    1. Turn the ignition switch to the ON position.
    2. Connect a voltmeter between the orange wire in the harness connector and a known good ground.
      • If the reading on the voltmeter is 8-9.5 volts, proceed to the next step.
      • If the reading is anything but 8-9.5 volts, check for problems in the circuit between the reference connector and the engine controller.
  4. Check the mechanical operation of the distributor as follows:
    2. Remove the distributor cap from the distributor housing.
    3. Crank the engine while observing the ignition rotor.
      • If the distributor rotor revolves while the engine is being cranked over, replace the distributor pick-up coil assembly with a new one.
      • If the distributor rotor did not rotate, inspect the engine for a mechanical fault and repair as necessary.
  5. If fault code 54 (No distributor sync pick-up signal) is being received, or was received before performing this test, proceed as follows:
    3. Connect a voltmeter to the tan/yellow (TN/YL) wire of the harness connector.
      • If the reading on the voltmeter is at 4 volts, replace the distributor pick-up coil assembly.
      • If the reading is 0 volts, check for an open in the wiring harness between the reference connector and the engine controller.
Jan 30, 2011 | 1991 Chrysler LeBaron
I think my starter motor has gone? my car wont start unless i pus it and kick start it in gear. Is it the starter motor gone or battery playing up??
hi...
both may be the reason for not starting.
11.please check the terminals from the battery,wires and all in good order.then check the volt comin to the starter motor if the volts are correct then the problem is with the started motor. please service or replace with the new motor.
2.if no supply is comin to the motor terminla then ther is a problem with the wires.the wire is damaged so no power goes to the motor.
3.if the voltmeter/multimeter reads less reading then the problem is with the battery.the charge is not sufficient enough to start the motor. please recharge or replace the battery if required.
if my information was usefull please vote
Jun 26, 2010 | 1997 Volkswagen Golf
BATTERY GOES DEAD OVERNIGHT
Check that the alternator and charging circuit is actually working. You can do this with a voltmeter across the battery terminals. Check the value with the ignition off - you should see 12.1 and 12.5 volts. Then start the engine and leave it on idle - you should see between 13.8 to 14.2 volts. Watch the voltmeter as the gas is pressed down. With the engine revving around 2000 rpm the voltmeter value should increase up to something like 14 to 14.2 V but not increase any further with an increase of engine revs. If you see voltages of 14.5V or above then the voltage regulator needs replacing.
Note that if you constantly see voltages of 12V or less with the engine switched off then the battery should be replaced as it will not hold charge and gradually drain down as you are experiencing to a point where it will not turn the car engine.
If you don’t see any increase in battery voltage, or the battery voltage falls, when the engine is switched on then either the alternator or the voltage regulator need to be replaced.
Nov 19, 2009 | GMC Sierra 1500 Cars & Trucks
New battery but the engine will not turn over
check the starter..is there a click?if so... wiggle battery connections..if still nothing... try tapping on the starter under the jeep while somebody turns over the engine
Sep 30, 2009 | 1996 Jeep Cherokee Country
Car Audio & Video Logo
41 people viewed this question
Top Car Audio & Video Experts
xxxxxx xxx
Are you a Car Audio and Video Expert? Answer questions, earn points and help others
