Question about Mitsubishi VS-50705 50" Rear Projection Television
When I turn the set on it immediately clicks off. I have had no problems with the set for the 10 years I have owned it. Is there a reset button? I have unplugged it and re-plugged it but that did not help. It powered off today while we were watching tv and won't power on.
  • Mitsubishi Master
  • 5,568 Answers
Feel fortunate for the 10 years; owners of sets failing just after the warranty are really angry.
That length of time tells me that the power supply was better designed than most but is now failing to turn on and run. Modern supplies are very complex and demand a high level of component quality, far more so than the older (and less efficient) type called 'linear.'
The supply assembly is almsot always on a separate board and you should be able to recognize it through the relationship to the AC power coming in and the fact that they will have physically larger components, some cylindrical (capacitors) and others block-like devices (chokes and transformers.)
Look for an assembly number on that unit and contact Mitsubishi service to inquire about the replacement and/or repair cost of that board.
You really have been lucky since most modern sets don't run half that time without failing.
Posted on Jul 31, 2009
Why does my top load whirpool washer restart on its own after it finishes the last rinse and spin cycle. It does this on all settings, delicate, normal or heavy.
  1. Turn the washer off.
  2. Set the mode selector dial to NORMAL.
  3. Turn the dial counter clockwise ONE click (LEFT), clockwise THREE clicks (RIGHT), counter clockwise ONE click (LEFT) then clockwise ONE click (RIGHT).
  4. Now press the start button.
  5. All the cycle indicating lights should be illuminated.
  6. Press the Start Stop button once.
  7. Rotate the dial until Rinse, Wash, and Stop light illuminate.
  8. Turn the washer off and unplug it for 10 seconds.
  9. Finally, turn on the washer and it should now be reset.
  10. Run a test load empty to be sure the reset worked. If not perform the reset procedure one more time.
Oct 07, 2016 | Whirlpool Whirpool 3.5cu ft Top Load...
Tip
How To Reset Your Magellan Maestro/Roadmate GPS Units
Factory Reset
Do not attempt to perform a factory reset on the Roadmate or Maestro GPS units by holding down both the "Reset" and "Power" buttons. This will cause the GPS unit to format its own hard drive. Doing so will erase all data, including the GPS software, from the unit.
  1. Locate the button marked "Reset" on the left, right or bottom of the unit.
  2. Using a thin object, such as a paper clip, depress the button for two to three seconds. The unit should reset.
  3. If the unit does not reset, immediately press the button again and hold it for up to 10 seconds.
If your Maestro GPS Touch Screen Doesn't work, try performing a Hardware Reset
  1. Remove the Magellan Maestro from the holding cradle.
  2. Hold down the "Power" button on the right side of the device, until the unit powers on.
  3. Straighten the end of a paper clip. Place the paper clip in the reset hole, located on the left side of the GPS unit. Hold down the "Reset" button for 10 seconds. Remove the paper clip.
  4. Turn the Magellan Maestro unit off by holding down the "Power" button. Turn the unit back on again. The device is now reset.
If your Roadmate GPS is locked up, try performing a Hardware Reset
  1. On the RoadMate, press + + - - + -
  2. The "hidden menu" will appear.
  3. From there, you can access the shell and perform a hard reset.
on Feb 15, 2011 | GPS
Gud day.prob with a160 matic has wrench displayed on instrument panel.car is pre owned,no manual or spare key.ride is horrible,and i dont know if all a160 is 5 speed.
All the different lights you get on the dash of any vehicle, have
been there since 1980. That is 31 years. Nothing has changed
since then ,unless you were on another planet
Check for Codes
Diagnose System with OBD Malfunction
Repair system as necessary
Jul 28, 2011 | Mercedes-Benz B-Class Cars & Trucks
Went in to set a wep but when i i click wep it locked with out giving the option to personolize my own code now i cant connect
Hello. There is a reset button on the back of the router. You will have to use a pin or bent paper clip to stick into the hole to hit that reset button. With the router on, push that button and hold it down for 5-10 seconds (or until you see the router lights turn off then on again). What you will be doing is a reset of the routers factory settings. Once this is done, you will be able to access the router settings again as you did before.
Feb 28, 2011 | Computers & Internet
Tv isnt turning on, you will hear a click then see the power light flash 6 times then the light goes off for about 10 mins then comes back on flasing again...and the cycle just continues. It did this once...
Sounds like a power supply problem. I worked for a short period for Panasonic at their USA plasma R&D / small scale manufacturing facility and learned that to "ignite" or start the plasma when turning on the set, a significant current discharge is required.
The recycling seems to indicate that the "brain" in the set realized that a plasma has not been established, and it is attempting to recharge the starting circuit. The flashing power light is probably significant and a trained technician or a service manual will probably identify this as a trouble code pointing to the problem. Sorry, I did not have any exposure to the finished product and cannot advise what the code means.
If the set is still under warranty, you should act immediately and get the problem taken care of, because it will not go away on its own, and will most likely get worse. Sorry the news is not better. Good luck!
Jan 28, 2011 | Panasonic Viera TH-42PX80U Plasma TV
Turns On but not past the loading screen
Hello :
I recommend you to reset your RoadMate .
To reset your RoadMate please follow these steps :
1: Locate the button marked "Reset" on the left, right or bottom of the unit.
2: Using a thin object, such as a paper clip, depress the button for two to three seconds. The unit should reset.
3:If the unit does not reset, immediately press the button again and hold it for up to 10 seconds.
NOTE : Please don't attempt to perform a factory reset on the Roadmate or Maestro GPS units by holding down both the "Reset" and "Power" buttons. This will cause the GPS unit to format its own hard drive. Doing so will erase all data, including the GPS software, from the unit.
This solution should help with your problem . If that didn't help , then I recommend you call Magellan service for help .
PLEASE DON'T FORGET TO RATE !
Apr 16, 2010 | Magellan RoadMate 1340 GPS Receiver
I have a 2004 Volvo S60. How can I clear the "Time for Regular Service" message. I service my own car.
Close all doors.Turn ignition key to position 1.PRESS AND HOLD trip reset button,immediately turn ignition to position2,keep trip button held untill trip is reset to 0.A yellow warning light will show when it is time to release trip button.Release within 4seconds ,a bleep will be confirm reset.Before you start reset, do not reset trip,If trip has been reset to 0,turn ignition to position 2 hold reset for 10- 15 secs untill previous reading is shown,then start reset.
Oct 31, 2009 | 2005 Volvo S60
How do i connect my wireless remote to my d60????
In the Shooting Mode menu, change <from either Single or Continuous or 10Second self-timer> to 2S (two seconds) Remote or immediate Remote -- there's an icon that looks like your remote. Then get in front of the camera (lens cap removed already) and point the remote to the IR receiver on the front of the camera and click the remote button ... it will take the shot immediately or after two seconds (depending on what you specified).
The shooting mode doesn't seem to stick -- if I turn the camera off and then on, it's gone back to how it was previous set and I have to set it to remote again.
My bigger problem was I thought (guessed, since there were no instructions!) that I had to press the self-timer function button before clicking the remote -- but doing that kept resetting my shooting mode back to 10 seconds on SELF TIMER (taking it off of REMOTE mode).
Dec 26, 2008 | Nikon ML-L3 Remote Control
93 tempo
I had the same problem a few months back with my 93 Tempo. After fiddling with the battery, checking for spark, and messing with my distributor cap, I found the emergency fuel shut off reset button in the trunk. If you haven't already, open the trunk, and on the left hand side there is a recess with a largish red button. Press it. If it clicks, then your fuel injector shut off because it though it had been in an accident (mine happened right after pulling into my driveway, where I had bottomed out a little bit, so it doesn't take much to set it off). If it clicks, your car should start immediately
Hope it helps!
Jul 12, 2008 | 1993 Ford Tempo
Printer activates on its own
To change the power save setting, go to the operating panel of the printer.
Press the Option button 11 times until Power Save appears on the LCD.
Use the arrow buttons to scroll through the options:
After 10 minutes
After 30 minutes
After 60 minutes
Never (select never......)
Immediately
Press the Select button to save the required option.
Nov 25, 2007 | Lexmark X5470 All-In-One InkJet Printer
Mitsubishi VS-50705 50" Rear Projection Television Logo
197 people viewed this question
Top Mitsubishi Televison & Video Experts
matt martin
matt martin
Jaime Hernandez
Are you a Mitsubishi Televison and Video Expert? Answer questions, earn points and help others
