Question about Boating
Chrysler 70 HP outboard motor dies when pushing throttle
My engine was running fine for the first few months I had this boat. Last few times out the engine starting losing power. Starts fine and idles but now it dies when I give it throttle. Fuel pump is working fine, new wires and plugs, cleaned points. I'm stumped.
  • 77 Answers
I have found that 99 percent of the time when this happens it is carb related. It is very possible that you picked a a small piece of grit or trash in the high speed jet of one, or both, of your carbs. I would be willing to bet that pulling the carbs and cleaning them will resolve your problem. I am almost positive that will fix your problem, mainly because it sounds like you've already tried everything else. I had this same problem last season, and what had happened was I left the vent open on my fuel tank, we got a shower, and I pulled just a small bit of water into the carb and that was it, she would not do anything over idle until I pulled the carbs and cleaned them. i even put the water muffs on it and let it run in the yard for about an hour thinking that it would burn the water out, but i was wrong. Anyway, clean the carbs and i think you'll be in good shape, Good Luck.
Posted on Aug 02, 2009
Ok when I start the engine of this Chrysler 90 hp outboard motor It starts right up reverse is fine neutral idle is fine but when I push the throttle forward to go forward it shuts the engine completely off any body have a helping opinion on this?
Posted on Jul 12, 2013
What will make a johnsonew 50 hp out board motor bog when under load
Evinrude 50 HP Bogs at WOT - MarineEngine
www.marineengine.com > ... > Johnson Evinrude Outboard Archive
Aug 6, 2002 - 17 posts - ‎3 authors
83 50 HP Evinrude - sat out in weather for 4 yrs. Been cleaning ... At WOT, she bogsdown. Up to. ... Yes, this boat/motor is new to me. Actually ... Mercury 50 1987 bogs down when full @ full throttle
Sep 12, 2013
Motor Runs great bogs down under load.
Jun 23, 2011
1984 Johnson 70 idles but won't go
Jun 1, 2011
Johnson 70 hp no power under load Update
Oct 30, 2006
More results from www.marineengine.com
motor bogs down at full throttle Page: 1 - iboats Boating Forums ..
Dec 09, 2015 | Cars & Trucks
Suzuki 70 idles rough
injectors mite need cleaning in injector cleaner ! remove to soak them !
May 07, 2012 | Light Outboard Motor Boat Bass Fishing...
When I start my 10hp mercury outboard after priming it will run for a few seconds and then die. IF I push the throttle only button and rev it up before priming or set the low idle up higher and then prime...
Be sure to run the recommended fuel mix. most modern 2 stroke outboard engines run on 100 to 1, some times the mix is on a decal inside the cowl.
Cheers, Timo.
Feb 27, 2010 | Light Outboard Motor Boat Bass Fishing...
My mercury 35 hp outboard motor idle's fine but won't run
While at the river try to adjust the fuel air mixture. When you are on the water it puts the engine under a load and if that dont work then dont be afraid to bump up the idle stop screw slightly.
Aug 02, 2009 | Light Outboard Motor Boat Bass Fishing...
Boat engine 1995 Johnson Outboard 70 HP
Ihave a 1991 70 hp Johnson outboard thats hard to start the first time but starts good after that. Seems to be flooded. Starting rpm seems to be low.
Jun 25, 2009 | Boating
15hp push idle in motor shuts off
First, always have the motor in water or with a hose and muffs when you run it. It is simple to fix if all the parts are there. Let me put it this way. If you know where the air mixture adjustment is on the carburetor you turn this screw until the engine speeds up at idle to a maximum rpm, then back in 1/4 turn. Adjust throttle stop screws to achieve a minimum base idle. If this seems complicated, take it to an outboard place or lawnmower shop(if you have a hose and muffs). Its a 15 minute job and will last until its changed.
Jun 13, 2009 | Boating
Boating Logo
832 people viewed this question
Top Boating Experts
Steve
Steve
ray gallant
Fabrice Wolters
Are you a Boating Expert? Answer questions, earn points and help others
