Question about Cuisinart Private Reserve CWC-900 Wine Cooler
Unit will not cool. Stays at room temp. - Cuisinart Private Reserve CWC-900 Wine Cooler
Based on my personal experience it may be a bad fan. can you feel the fan running? or does it just feel hot near the vents?
Posted on Nov 07, 2009
ArghhhHHh! This is a solid-state unit meaning that it has no compressor! It uses a heat exchanger to cool the air through a plenum chamber. It's posssible that the temperature controller is faulty or the Peltier cell (heat exchanger) is bad.
Posted on Aug 14, 2013
3 Suggested Answers
SOURCE: THE UNIT DOES NOT COOL ANDY COLDER THAN ROOM TEMPERATURE.
does the compressor run ? if so you could have a low refrigerant charge, a sealed unit resrtiction, leak or defective compressor.
Posted on Apr 30, 2010
SOURCE: I have a Danby Kegerator
If adjusting the temperature control doesn't give any result, and it is staying at room temp, then most likely the Thermistor, and.or the Temperature controller, the Thermostat, has faulted, what you need to do, is first try replacing that temperate sensor, the Thermistor, if still no go then replace the temperature controller, ie: the thermostat.
It may be better in the long run to pop it into a Danby service center, contact Danby via the internet, and inquire where a repair center is, although most likely any refrigerator repair place will be able to effect a suitable repair,and ask for a "Quote" for any repairs.
Posted on Mar 04, 2011
Why does the unit keep on switching off after running for 2 minutes
Do not know what brand or model your aircon unit is? Sounds as if the temperature you want your unit to run at has already been reached. You need to follow these steps:
- select the temperature you want
- select the icicle icon for cool or thermometer icon for hot.
- select "auto" for your unit to cut in, or to cut off to keep your desired room temp.
For example - hot day 26 degrees and you want the temp in the room to drop to 19 degrees - the unit will shut off once it reaches 19 degrees if it is set to "Auto". Hope this gives you some clues to get it working. Please tick my this helped me box if my tips work. Good luck Gerri.
Nov 27, 2015 | Heating & Cooling
I cannot get my temp down to 58 but stays at 68
What is the BTU rating of the unit and what size space are you trying to cool down? Air conditioners move heat from one area to another. Possible reasons for not achieving the temperature you want are 1) the air conditioner you are using is too small to cool the size room you have or 2) the space where you are trying to exhaust the hot air from the air conditioner is too hot to allow your air conditioner to move enough heat out of the room you are trying to cool.
Mar 19, 2015 | Heating & Cooling
Just purchased and is not cooling at all
please see this steps and fix it. God bless you
1. Unit not running
Possible Causes Response a. Power cord unplugged
b. No power at all
c. If display lighting, temp setting high
d. If temp setting ok, sensors or control board bad
e. Compressor unit malfunctioning a. Check for power cord plug
b. Check receptacle voltage & fuses
c. Lower temperature setting
d. Call service for replacing sensors or control board
e. Call service for component check
Nov 27, 2013 | EdgeStar CWR361FD - 36 Bottle Built-In...
Purchased a couple of months ago. No problems with operation or cooling. Does a great job of colling the room and even risidual rooms on that level. Turned unit off while on vacation for one week. Upon...
When the environmental temperature is lower than the set range, the display will indicate "LO".
Lowering the temperature you have it set on, should resolve the problem.
Hope this helped you and thanks for choosing FixYa.
Aug 21, 2011 | Haier CPRB07XC7 Portable Air Conditioner
I have an LG AC and the lowest temperature setting is 60 degrees
Lowering the temperature setting doesn't change the temperature of the air coming out of the unit it just lets it run until the room temperature gets colder. Check the temp of the air coming out of the unit. If it isn't as cold as it used to be the charge could be low. First though you should make sure the filters are clean and the coils.You should also check the actual room temp. It's also possible the unit doesn't have enough capacity to keep up with the cooling load of the room.
May 02, 2010 | LG Heat cool Window Air Conditioner
Apr 30, 2010 | Haier HVUE08A Wine Cooler
Honeywell thermostat won't regulate temp properly
check to differential setting in the thermostat and are you saying the temp in the room and the set temp is being read from the thermostat or is there another thermometer in the room your looking at
Jun 25, 2009 | Honeywell Electronic Programmable...
GE AGM08LJG1 window unit: digital temp increases on its own. Ex: when set to 65 degrees (and timer set to turn the unit off in 4 hours), return to the room 2 hrs later and the digital temp reads 69. What...
its telling you the room temp that is been sucked into the evaporator.its normal for this to happen.once you set the temp you want.it stays there untile you change it.but its all good.
Jun 09, 2009 | GE Deluxe AGM08LJ Thru-Wall/Window Air...
My appartment does not have cenral AC/heat, it has a GE cooling/heater unit in each room. You can set up low heat or high heat but it continues runing on until you manually stop it when is to hot. Is there...
the unit runs all the time because of the fan (ventilation motor)-but it is not working on cooling or heating all the time - The ventilation motor pushes the air from the room through the machine and when the termostat is reading that you set it up for cooler air or warm air it will turn on the air conditioning part or the heating part of the machine-it is very good system actually
Oct 04, 2008 | Heating & Cooling
Samsung window unit air conditioner model # AW2402M freezes up one time, and the next time freezes you out of the room. What is wrong with it, Termistat or compressor?
Try to set the thermostat to higher temperature and monitor if the compressor will turn " off " when the room temp. is cool, and turn " on " when the room temp. is high. If does not work then your thermostat is defective. Continue running of compressor with very cold room temp. can build up ice in the unit. The compressora73b784.jpg should shutdown when setting temp. will attain.
Apr 08, 2008 | Heating & Cooling
Cuisinart Private Reserve CWC-900 Wine Cooler Logo
1,058 people viewed this question
Top Cuisinart Furniture Experts
Maxumized
Rabbit Brains
Rabbit Brains
Are you a Cuisinart Furniture Expert? Answer questions, earn points and help others
