Cars & Trucks Logo
Susan Price Posted on Feb 16, 2018
Answered by a Fixya Expert
Trustworthy Expert Solutions
View Our Top Experts
My vw polo year 2004 needs new front control arm bushes. Can you replace just the bushes or do you need to buy the whole control arm?
Karl w
Level 3:
Master:
  • Cars & Trucks Master 437 Answers
  • Posted on Feb 16, 2018
Karl w
Level 3:
Master:
Answers
437
Questions
0
Helped
159298
Points
1024
You can buy just the bushes but if you dont have the right tools you wont be getting them on the arm
2 Related Answers
Anonymous
  • Posted on Apr 14, 2010
SOURCE: 2004 Nissan Quest front control arm bushing replacement.
Sorry guys not a solution but I too have an 04 Quest, which supposedly has worn controller arm bushings and Nissan says I need both controller arms replaced. For a total of $950!!! I was told that they need to replace the whole arm and cannot replace only the bushings. Now reading the posts on this site I find that to be untrue. Seems all I need to spend is anywhere from $25 to $35 per bushing.
redneck59250
dj griffin
  • Posted on Mar 13, 2014
SOURCE: Does my car have rear control arm bushings?
Yes the 95 Camry has rear control arms and you can buy just the bushings
1helpful
2answers
How do i fix it
Sway bar bushing, Ball joints and Strut Mounts make these noises. See if the ball joint have grease fittings then get them greased. Check if Control arm bushings have play and can they be pumped with grease. If Control arm bushings have play then change the complete Control arm which will be economical in the long run. Please check and get back to me with more information.
How to repair vw
Lift Vehicle and place on axle stands. Remove wheels. Disconnect the lower control arm from the bolts that hold the ball joint, or from the knuckle. Undo the rear two bolts that hold the ''D'' shaped rear bush and the bolt that holds the forward bush. Have it pressed out and replace with new one. Reverse the procedure for installation. While the arm is out check the condition of the ball joints and replace if needed. After assembly have the front wheel alignment checked.
Bushing on rear control arm to spindle
you have replace the control if any bushings has cracked and dry rotton.
I need to change the front bumper and the driver side wishbone on a W reg Polo tdi, could i get illustrated diagrams and easy to follow information about doing these two jobs please? Thankyou.
It would help if you join a VW forum that has Polo group. You'll have a higher chance for info regarding the vehicle.
The control arm is pretty much straight forward, I'd advice you to mark the balljoint (bottom 3 bolts carrier) by using a center punch before you loosen this bolts. This will help you put it back the same exact position and lessen the probability of messing the alignment in a big way.
I'd also suggest to replace the control arm rubber bushings if the mileage is quite high.
3helpful
2answers
Lower Control Arm Bushing replacement
I just did this job on my 98 regal, and I own the service manuals also. The lower control arm bushing that usually goes, is the front one. The rear one doesn't usually go, it is horizontally mounted. The front one for some reason is vertical. The control arm must be removed, and put in a vise. The front bushings outer metal sleeve, must be driven out with a chisel. It comes out easily. The new bushing can be tapped in with a hammer. Hope this helps!
JOEVETTE
22helpful
3answers
Top Cars & Trucks Experts
ZJ Limited
ZJ Limited
john h
Arnie Burke
Arnie Burke
Are you a Car and Truck Expert? Answer questions, earn points and help others
