New a/c system replaced and not blowing cold air
New a/c is working but not cold air, downstairsunit also replaced and works great what is the problem
  • tonycap250 May 11, 2010
    are these window units
  • 20 Answers
Make sure you check the super heat on the unit. (super heat is the temp of the suction line at the condensor outlet minus the suction pressure. It should be fifteen degrees less than the suction pressure.) This should be done by a skilled refridgeration tech. Whom ever installed the equipment should be able to help you with this.
Posted on Jul 31, 2009
2002 Ford Taurus, Heater blows cold air?
What have you checked so far ?
Radiator full of coolant ? Heater hoses getting hot ?
Feb 23, 2015 | 2002 Ford Taurus
Goodman furnace, blowing cold air
Replace termorelay cose it overheating in service centre 12_26_2013_5_48_58_pm.jpg
Dec 06, 2013 | Heating & Cooling
My GMC Sierra's air conditioning works great but the driver side vents will spontaneousely start blasting out hot air. The passenger side continuse to blow cold air. If iI turn the truck off and...
  1. Air conditioner system is discharged. Have the system evacuated, charged and leak tested by an MVAC certified technician, utilizing approved recovery/recycling equipment. Repair as necessary.
  2. Air conditioner compressor clutch not engaging. Check compressor clutch wiring, electrical connections and compressor clutch, and repair or replace as necessary.
May 24, 2011 | 2005 GMC Sierra
1999 Ford Taurus 3.0l EFI 6cyl, Heater does not work, only blows cold air, have already flushed the radiator cooling system, and installed a new thermostat, still cold air. Anyone's help will be Greatly...
It could be air locked. Feel both your heater hoses, and, with the engine running, loosen the one that's cold, if there is one. If that doesn't help, it is probably your heat control valve that is malfunctioning.
Jan 08, 2010 | 1999 Ford Taurus
89 merc tracer blows cold air brrrrrrr
I would recommend flushing the heater core with water thru the coolant line, then blowing compressed air thru it also. And when you refill the coolant, make sure there is no air in the system.I would also recommend replacing the thermostat if you have the time and the money and the knowledge to do so
Dec 03, 2009 | 1993 Mercury Tracer
Air conditioner isn't blowing cold air
Could be a number of things...electrical connections causing the compressor not to run. Turn on AC and turn your thermostat all the way to cool...now visually check to see if compressor is engaged and not just free wheeling. Most likely you lost your refridgerant due to leak in the system...would need to find leak and repair then have your system re-charged with refridgerant. Best case scenario...your system just needs a charge of refridgerant due to not having enough.
Jul 25, 2009 | 1993 Mercedes-Benz E-Class
A/C blowing hot air while driving
Could be a vacuum line is busted. When you apply brakes it provides pressure to the system for freon to move and blow cold. Without that forced pressure freons not moving. I had that problem with a ford f150 and finding the busted vacuum line fixed it. It may be different with a mitsubishi, ask a local mechanic
May 22, 2009 | 1990 Mitsubishi Montero
My 97' Ford Ranger does not blow cold air.Help??
Have you checked to make sure your compressor is kicking in when turned to AC mode?
Mar 10, 2009 | 1997 Ford Ranger SuperCab
Fan blows.. no cold air... no hot air exhaust blowing
This sounds like you either need to clean or replace the filter, but if the filter is some what new you might want to take a look at the coils just past the filter, if the coils do not have a shine to them then you might want to buy some coil cleaner (i found simple green or formula 50 works great), then you will have to spray the coils with the cleaner, let sit about 10-15 min, then give it a very good rinse with warm water. After that it should work like it is brand new. Enjoy!
May 28, 2007 | Sunpentown WA-1210E Air Conditioner
Heating & Cooling Logo
46 people viewed this question
Top Heating & Cooling Experts
Paul Carew
Tim Whalen
