Question about Bissell Carpet Cleaner Powerbrush Deep Cleaner Vacuum
The tank lid will not click into place. - Bissell Carpet Cleaner Powerbrush Deep Cleaner Vacuum
    Renaissance:
    An user who is expert in 3 categories / brands.
  • 1,810 Answers
Check the seal is in proper position
Posted on Jul 31, 2009
It is not dispensing water and solution
Clean Water
Solution Tank
won't dispense.
1. Clean Water Solution Tank
not firmly in place.
1. Make sure tank is securely locked in
position.
2. Clean Water Solution Tank
empty.
2. Refill tank according to instructions for
surface being cleaned.
3. Dirty Water Tank lid not on
correctly.
3. Make sure lid is firmly in place.
4. Pump needs to be "primed"
(when using tool).
4. See "Before Using Tool" section.
Dec 17, 2012 | Hoover SteamVac F5914-900 SpinScrub...
My shampoor will not pick up the dirty water?
If your ProHeat 2X machine is not suctioning properly, first check the motor duct gasket. To check this, first remove the tank and place your hand over the rubber square opening. If there is no suction there, please take your machine to a BISSELL Authorized Service Center for inspection. If your machine does have suction at the duct, continue to check the following:
- Ensure the Ready Tools Dial is set to the appropriate setting (Floor Cleaning or Hose Attachments).
- Remove the tank from the machine and ensure the tank lid is attached properly. The front window must first hook onto the lip of the bottom of the tank and then drape over the tank. Latch the bottom tank to the top tank lid. THIS LID CANNOT BE ATTACHED PROPERLY IF THE TANK IS NOT REMOVED FROM THE MACHINE.
- Make sure the Water Tank is not full on the outside of the bladder. If it is, empty the tank.
- Ensure the hose is firmly attached to the back of the machine. If not, re-insert as necessary by twisting into place.
- The machine must be in an upright, locked position and set to the Hose Attachment setting. If the handle is slightly tilted back while using, it will create a small gap at the suction inlet (where handle meets gasket, above the Bottom Tank) which will cause little or no suction.
- Check the red Tank Lint Screen for debris. If the Lint Screen is dirty, the unit will have poor suction. Clean the Lint Screen if necessary.
- If the float flap door in the tank lid is activating prematurely when you turn the machine on, this flap door should be replaced.
- Check the Tank Lid and Tank for damage.
If you continue to experience low suction, please take your machine to a BISSELL Authorized Service Center. The warranty on your machine is one year. To locate your nearest BISSELL Authorized Service Center, click here.
To contact Consumer Services by phone, please call us at 1-800-237-7691, Monday - Friday 8 a.m. to 10 p.m., or Saturday 9 a.m. to 8 p.m., ET. A representative will assist you.
Apr 19, 2012 | Bissell 9500 ProHeat 2X CleanShot Upright...
I just purchased a floormate. I can't seem to get it to spray cleaning solution.
Turn the cleaner off and then on again to determine whether the cause of no suction resulted from the activation of the automatic shut-off. There are two reasons a tank will automatically shut off. The first is if the recovery tank is full. Located on the lower front panel of the unit, the recovery tank can be easily emptied and replaced into position. To remove from unit, press down on the release button and pull the tank downward and forward. Lift up on the tank latch lid and take out the tank lid. Empty the tank. Also check the tank lid screen for debris and remove any found. To replace the lid, align the tab that corresponds to the front hole of the tank. Snap the latches on the back of the tank. Insert the bottom of the tank back into the cleaner and push in and up until it locks in place.
Turn the unit on again and check the suctioning action. The second reason automatic shut-off could take place is if the handle was raised to an upright position while the motor was running. Should this occur, simply turn the unit off, wait a moment for the shut-off to reset, and turn it on again to continue cleaning.
  • 2 Make sure the filter and filter lid are properly positioned in the recovery tank lid. The cause of the problem could be that the filter or the filter lid were missing or were not in the proper position.
  • 3 Check that both recovery tank and/or solution tanks are locked in place and are positioned properly. The recovery tank is located on the lower front panel of the Floormate, and the solution tank is located in the front top panel of the unit. To remove from unit, press down on the release button and pull the tank downward and forward. Lift up on the tank latch lid and take out the tank lid. Empty the tank. Also check the tank lid screen for debris and remove any found. To replace the lid, align the tab that corresponds to the front hole of the tank. Snap the latches on the back of the tank. Insert the bottom of the tank back into the cleaner and push in and up until it locks in place.
  • 4 Observe whether filter is dirty. If the filter is dirty, clean the filter by turning the cleaner off and disconnecting it from the electrical unit. Take out the recovery tank and lid. Remove loose debris from the filter by wiping clean with a brush or tapping the filter over a garbage can. After this is completed, the filter may be rinsed clean for additional cleaning and then air dried before returning the filter to the unit.
  • 5 Check that the nozzle is in the proper position and locked. Locate the nozzle underneath the suctioning base of the unit. Make sure the latches are out and line up the middle section of the nozzle with the opening of the cleaner. Hold the nozzle in place while simultaneously sliding the latches inward to lock in
  • Mar 07, 2011 | Hoover Floormate H3000 Upright Wet/Dry...
    How to attached stair cleaning attachment
    Hi There,
    I'll be happy to walk you through step by step how you can attach the hose to your Hoover SteamVac.
    Here are step by step instructions for you:
    Step 1. To prevent possible leaking, remove
    clean solution tank by pressing down on
    tank handle (D) and pulling forward; set
    tank aside (do not set tank on furniture2_bing.gif).
    Remove hose from storage rack.
    Step 2: Step on handle release pedal (E) and
    lower carpet cleaner handle until it rests
    on the floor.
    Unlatch back part of recovery tank and
    remove lid.
    Step 3: Remove recovery tank front panel (F)
    by sliding it straight up.
    Step 4. Replace panel with converter (G).
    Slide converter halfway down opening
    until it is firmly in place.
    Step 5. Before connecting tube (H) to
    cleaner, make sure black tabs are
    extended by pulling tan collar toward
    tube.
    Open door on hood labeled “Stair/
    upholstery Cleaning Connection”. Press
    round solution tube connector onto
    round projection inside door. Press connector
    collar down firmly to ensure
    that it is fully connected.
    Step 6. The tank replaces in a hinge-like
    manner. Position front of lid under tabs
    (I) on front of tank. Rotate lid down onto
    tank.
    Make sure lid is secure on all sides
    before cleaning.
    For full suction, it is important that
    the recovery tank lid is properly
    secured before cleaning.
    Reverse procedure to remove hose
    and solution tube.
    Raise carpet cleaner2_bing.gif handle to upright
    position.
    I hope that this was helpful to you in hooking up your Hoover SteamVac hose. If you found this helpful, please be so kind and rate my repair helpful by clicking the 4 thumbs up icons in the top right hand corner of the repair, this is really appreciated.
    Thanks again,
    Chris J.
    GoVacuum.com
    Apr 25, 2010 | Hoover F5835900 Upright Steam Vacuum
    Hoover carpet cleaner not picking up water
    Assure the ring gasket is in place under the hood. A round rubber gasket must be in place on the round tube under the hood where the recovery tank sits to connect the vacuum from the motor to the round tube on the bottom of the tank.
    In addition, make sure the recovery tank lid is properly aligned to the tank to seal.
    Lastly, make sure the square duct is latched in place in front of the recovery tank, that links the nozzle plate to the tank lid.
    Feb 14, 2010 | Hoover SteamVac Carpet/Upholstery Deep...
    Won't pick up the water while cleaning
    Please check two three things:
    (1) Is the lid on the recovery tank aligned to the tank at rope seal of lid?
    (2) Is the rectangular panel in place in the front of the recovery tank, that connects the clear nozzle to the tank lid?
    (3) Remove the tank from the base, and check and see if a round black gasket is in place on the round tube that comes up to the front corner of the bottom of the recovery tank. This is a vacuum seal to connect the motor to the tank to supply suction.
    Oct 13, 2009 | Hoover SteamVac F5914-900 SpinScrub...
    My hoover steam vac is not releasing the cleaner
    http://www.hoover.com/pdfs/manuals/F5914900.pdf this is the manual for your model
    Godbless
    Problem: Clean solution won’t
    dispense
    Problem: Brushes/brush indicator
    won’t rotate during floor cleaning
    Possible cause
    Possible solution
    • Not firmly plugged in
    • Plug unit in firmly
    • No voltage In wall plug
    • Check fuse or breaker
    • Blown fuse/tripped breaker
    • Replace fuse/reset breaker
    Possible cause
    Possible solution
    • Recovery tank full/automatic
    shut off engaged
    • Remove and empty recovery tank
    • Blockage In tool on end of hose
    • Remove tool and clear blockage
    • Recovery tank lid not on
    correctly
    • Make sure lid is on securely
    • Recovery tank front panel not
    replaced after stair or upholstery
    cleaning
    • Replace recovery tank front panel
    (page 14)
    Possible cause
    Possible solution
    • Solution tank not firmly in place
    • Make sure tank is securely locked in
    position
    • Solution tank empty
    • Refill tank according to instructions for
    correctly
    • Make sure lid is firmly in place
    • Pump needs to be “primed” (when
    using tool)
    • See “Before using tool” section, p. 13
    Jun 15, 2009 | Hoover SteamVac F5914-900 SpinScrub...
    Hoover SteamVac F5905900
    The proper way to install the reovery tank lid is to attach the front such that it catches the tank and then lowered to snap in place in the back
    I’m happy to assist further over the phone at https://www.6ya.com/expert/robert_b96ba3f038cf317c
    Mar 09, 2009 | Hoover SteamVac F5914-900 SpinScrub...
    Where do I put the water.
    1. Release the handle and lay the machine
    handle back to access the tank.
    2. Remove the tank from the base of the
    machine by lifting the tank carry handle.
    3. Carry like a bucket to the sink. Rotate the handle forward
    to unlatch the lid. Lift off and set the lid aside.
    4. Fill up the bladder with clean hot tap water.
    *Do not boil or microwave water as it can
    destroy the bladder.
    5. Replace the top of the tank by matching the
    lid and tank edges. Handle must be in the
    forward position in order to replace lid. Rotate
    Note: Remember to secure the lid and test to make
    sure it is secure before picking up the Tank.
    6. Place tank into machine base, seating firmly in place.
    Rotate tank handle back into latched position. Bring
    machine handle back into upright position.
    You can download the manual from the Bissell website www.bissell.com
    Jan 28, 2009 | Bissell 1699 ProHeat Clear View Upright...
    I have misplaced the directions for the Bissell powersteamer powerbrush. I need the directions for filling the u tank etc.
    Release the handle and lay the machine handle
    back to access the Tank.
    2. Remove the Tank from the base of the machine by
    lifting the Tank carry Handle.
    3. Carry like a bucket to the sink. Rotate the Handle
    forward to unlatch the lid. Lift off and set the lid aside.
    4. Fill up the Bladder with clean hot tap water.
    destroy the Bladder.
    5.
    Replace the top of the Tank by matching the lid
    and tank edges. Handle must be in the forward
    position in order to replace lid. Rotate the handle
    to the carrying position to latch the lid.
    make sure it is secure before picking up the Tank.
    6.
    1.
    Lift the formula Tank up and out of the machine base.
    2. To fill the Formula Tank, first unscrew the Cap
    and Insert. Always use genuine BISSELL formulas
    to maximize cleaning and for the safety of your
    machine. Fill formula up to the line and replace the
    Cap and Insert. Place Formula Tank back into the
    base of machine, making sure it is seated securely.
    Note: If bottle leaks, check for proper positioning
    of red gromment and straw.
    Apr 29, 2008 | Bissell 1699 ProHeat Clear View Upright...
    Bissell Carpet Cleaner Powerbrush Deep Cleaner Vacuum Logo
    Top Bissell Vacuums Experts
    Jim Parker
    Jim Parker
    Are you a Bissell Vacuum Expert? Answer questions, earn points and help others
