Question about Garden
My Poulan 3050 will usually crank when cold but, if you cut it off after it warms up or it goes dead, it will not restart. I have changed the air filter and cleaned the plug. Sometimes cleaning the plug will restart it. Any advice?
  • 123 Answers
If you have not changed the plug I recommend that you purchase a new one as they usually are only good for a season or two depending on usage and fuel mixtures
Posted on Jul 31, 2009
  • mbrazil Nov 30, 2013
    Check the condition of the fuel line and fuel filter in the fuel tank. The fuel line tends to go bad over time, and if it has any cracks or holes in it, it will cause the symptoms you describe. It's a good idea to replace the fuel line and the fuel filter every couple of years.
Our AC keeps cutting out. It runs for a few minutes then stops. have to switch off and restart. Any idea why? Have emptied water and cleaned filter recently
Look for:
  1. the ac needs air flow thru the indoor and outdoor radiators
  2. the outdoor radiator coil should get warm/hot and produce warm air.
  3. indoor radiator coil needs should get cold and produce cold air.
The ac needs the fan motor(s) working and compressor running and pumping. Compressor skinny copper line hot and thick line cold.
Jul 21, 2015 | DeLonghi Heating & Cooling
Warm starting problem
Check your alternator. It does more than just charge the battery. If it is not working properly the fuel pump and injectors will stop thinking the car has been in an accident.
Feb 21, 2014 | Cars & Trucks
There are currently no new unsolved problems available for 'I have a 2002 Toyota Camry LE. The car cranks and runs just fine usually but after about 10 minutes or so (after it warms up) it goes de
I would say the problem is the coil. Normally when a coil goes bad they don't work at all but not always. If you know someone that has a timing light you could check for spark to the spark plugs when it goes dead. When the coil warms up it expands and can break connection of the wire with in the coil. I have had this proplem on my chevy pickup and it turned out to be the coil.
Jan 12, 2013 | 2002 Toyota Camry
I changed cam phasers and runs great when cold. When it warms up it stalls at stop lights and gets difficult to restart
have vechicle code scanned bad engine coolant temperature sensor will cause vechicle to stall out and hard to crank when cold.
Sep 11, 2012 | 2004 Ford F150
Starts then cuts off and won't restart
Hello; This is likely a carb problem or clogged fuel line or fuel filter if it has one. If it runs for awhile before cutting out, check your gas cap. They all have some sort of vent to let in air as the fuel level goes down. If the vent is clogged, the carb can only **** out the gas for seconds or a few minutes. john
Aug 15, 2011 | Poulan Garden
Ac goes from cold to warm shut off the ignition and it works again for awhiile then goes warm again
How long does it run for before going warm?
What is the outside air temp?
Does it do the same thing whilst parked?
Does it ever cut back in on it's own [wait a few mins] or do you always have to turn the ignition off?
Some possibilities:
The over-pressure cutout is operating.
Can be caused by the condensor [in front of the radiator] becoming blocked up with to much rubbish restricting air flow, or the a/c auxillary fan [usually in front of the condensor] is not cutting in which could be a bad motor or refrigerant pressure switch is not operating.
Another is that there's a refrig, gas leak and enough gas has escaped so as to cause the low pressure switch to stop the compressor.
When the a/c is first turned on, there is enough pressure for the compressor to run, but as it runs, the low side goes too low and cuts out the compressor.
Aug 08, 2011 | 2004 GMC Sierra
After I drive my jeep some, if it is somewhat warm or not cold weather, my jeep has a hard time starting. It may crank but run a little ways and cut off going down the road.I have had the coil, plugs, plug...
if it shuts off after running for a while and will not restart for about 10 min,a bad crank sensor will cause this. abad crank sensor will make car shut off and not restart for about 10 min. put a scanner on to make sure. a check engine light does not allways come on. if you do not have a scanner, any auto parts store will scan it for free.
Feb 27, 2010 | 1997 Jeep Grand Cherokee
I HAVE A 1998 NISSAN MAXIMA ABOUT 120,000 MILES . CAR WILL TRY TO CUT OFF WHEN YOU FIRST CRANK IT, ESPECIALLY WHEN IT IS COLD. SOMETIMES WHEN YOU FIRST CRANK IT , IT WILL TURN RIGHT BACK OFF. ACTS LIKE ITS...
i have a 1998 nissan maxima when the engine is cold the engine will cut off when you first crank it. It will cut off but i can usually get it going the second time. After engine warms up car runs great. Why does this occur
Dec 21, 2008 | 1998 Nissan Maxima
2003 nissan altima v6- cuts of after cold start up
Have you check the coldstart valve ? It can bee something wrong with this.have you change sparkplugs? , check air filter ( if very dirty , change with new one )
Oct 21, 2008 | 2003 Nissan Altima
Garden Logo
26 people viewed this question
Top Garden Experts
Dennis Key
Dennis Key
roeb
john h
