Question about Fisher and Paykel Fisher Paykel Intuitive Eco Washer IWL15
Have older machine always worked with no problem ....it is and FandP Intuitive top load.. today put in light load started off machined filled and stopped....now nothing is happening not even any lights. have switched off and tried to re start ... no response ..... could it be the mother board ??? ... have check the power socket with other appliances it works fine , and there have been no power outages or surges in the area in last 48 hours
  • 69 Answers
If machine is completely dead ie no lights, then you probably have a faulty motor control module (main power board). These do not have any replaceable fuses, requires new module. Note- fault could be with another part of machine, which has caused module to fail eg faulty drain pump can blow control module. All other components need to be testedd before module is replaced, preventing a new module from blowing due to a fault elsewhere. These can be quite a complex machine, and not really easy to fix by untrained persons. Recommend calling service technician
Posted on Aug 09, 2009
Why would a washing machine fill to proper level and then stop. no action after filling.
Power was never the issue or it wouldn't have filled at all. Also the pressure switch that detects water level must be okay since it stopped filling at the proper level. That leaves the control board or a relay that the control board uses to start the drum motor.
Sep 16, 2014 | Washing Machines
Where do i put liquid detergent in top stacking may tag older model
Just pour the liquid/powder into the wash tub prior to loading clothes... this machine does not have a detergent dispenser...
Jul 06, 2014 | Maytag Neptune MAH5500B Front Load Washer
Hi, Having trouble with initial fill model IW811, will work some days and not others. Say's" I am not getting any hot water" so I tip 2 buckets of hot water in and it prompts it to continue...
Hi Maree just read your posting.Sounds like a fault I had on an intuitive washing machine the other day.To repair that machine I 1st changed the hot water valve then eventually had to change the control module.Is your machine the 'Intuitive model'?Is the machine beeping and showing an error code in the led display? Please reply with additional information and I am sure I can help.Looking forward to your reply.
May 23, 2011 | Fisher and Paykel GWL11 Top Load Washer
Whirlpool ultimate care II stops after filling
Hi, could be faulty timer, faulty water level switch, faulty start capacitor for motor, or faulty motor. always put clothes in machine before starting. you can empty machine by lowering drain hose to flow level.
Aug 02, 2009 | Whirlpool Ultimate Care II GSW9650LW Top...
Starts to fill with water then beeps and says not getting water fisher and paykel intuitive eco
undo the water hoses at the back of the machine & check for any blockages between the hoses and the the water inlets.
Mar 09, 2009 | Fisher and Paykel IWL12 Top Load Washer
Indesit W123 washing machine
it maybe your brushes are worn out, on alot of machines these days if the brushes wear the machine wont fill , or your motor itself could be faulty or your board. Unplug the machine , take the back off , get yourself a test meter disconnect the motor and put the probes from the meter and put it across the tags, if the motor is wrong you wont get continuity between 2 tags normally 1 and 5 looking from the top of the block going down
Mar 31, 2008 | Indesit W 123 Front Load Washer
Washing machine noise
my washing maching will not spin out all the water in the spin cycle.
Dec 20, 2006 | Hotpoint VLXR1020A Top Load Washer
Washing Machines Logo
115 people viewed this question
Top Fisher and Paykel Washing Machines Experts
Dan Webster
Dan Webster
Owen Barnes
Are you a Fisher and Paykel Washing Machine Expert? Answer questions, earn points and help others
