Question about Sony VAIO VGN-N250E/B Notebook
Need to remove and replace, however Sony doesn't make it easy. Need the directions on which screws to remove to get to the hard drive. step by step diagram would be helpful
  • yblee Aug 01, 2009
    This is the VGN--N250E - Model PCG-7X1L
    I've taken out many hard drives on various models, including Dell and Toshiba. Sony does not make it as easy as other manufacturers.
    There is a panel on the bottom with one screw, however, this area holds the memory modules for the unit. From speaking with the Sony support team, the hard drive is under the keyboard. That's why i'm looking for instructions on what I need to remove in order to get to release the keyboard and remove the hard drive.
    So, back to my original request: I need to find the instructions on "taking apart" this laptop to the point where I can remove the hard drive.
    Do you have access to that?
    Great job. Exactly what I needed.
  • Sony Master
  • 13,433 Answers
You need to replace the hard drive? Please confirm the laptop model, is it VAIO VGN-N250E/B? If not, which model? Thanks.
Posted on Jul 31, 2009
  • 5 more comments
  • Ekse Jul 31, 2009
    On the VNG-N250E Check the bottom of the laptop, there is a cover that is hold closed with 1 screw, unscrew the screw and open the cover, do you see the hard drive in there?
    Probably something similiar to this:
  • Ekse Aug 01, 2009
    Well I own a similiar but older sony vaio that had the hard drive under the touchpad.
    I do have a service manual for VGN-N series laptops.
    I see that to remove the hard drive you need to remove battery, keyboard, palmrest and then get to hdd.
    to remove the keyboard there is one screw in the bottom of the laptop.
    Release five(5) tabs from the bottom of the keyboard that hold it in place.
  • Ekse Aug 01, 2009
    rotate the keyboard from the bottom to remove
    to remove the keyboard completely from the laptop disconnect the keyboard cable from the motherboard.
    After this you will have to remove the palmrest that has the touchpad on it.
    Can I have your email I'll send you the rest of the steps in a PDF so I don't need to write them all out here? Thanks.
  • Ekse Aug 01, 2009
    to remove the plamrest you will need to unscrew all the screws in the bottom of the laptop, and one from under the memory cover. to get the top of the laptop come off (palmrest)
    after that you see the motherboard and the hard drive in the bottom left corner.
  • Ekse Aug 01, 2009
    Hi again,
    I placed the service manual for you here
    http://ekse.pp.fi/Fixya/vgnN.pdf
    Please download the manual and and accept the solution.
    It will contain all you need.
    Thank you,
    Ekse
  • pjpeter2 Nov 17, 2010
    Hi Ekse, Do you still have that e-mail or the rest of the steps? I'm helping a friend over IM to replace their HDD after their laptop failed and I haven't seen the unit myself to get any sort of idea on how it would work physically, so all these pics are very useful.
    Thanks,
    Peter
    The link is down and I didn't see this until after - sorry about that - but I got the service manual elsewhere so I'm good - thanks.
How to remove hard drive from sony vaio pcg-2c1l
As you install new programs, rip music files from CDs or download data from the Internet, the hard drive on your Sony Vaio PCG laptop will eventually fill up and run out of room. You can replace the hard drive with a new one that has a larger capacity.
Power off the Sony Vaio PCG laptop, disconnect the power cord and then close the lid. Flip the computer over so that the bottom is facing up toward you. Press down on the raised latch that holds the battery into place and then pull the battery out of the laptop. Locate the five screws arranged in a square pattern on the right side of the laptop case. Take a screwdriver and remove all of the screws. Slide your fingernail or the tip of the screwdriver underneath the seam of the square plastic cover and lift it up. Grab the cover and remove it. Pull out the two screws that hold the hard drive onto the motherboard. Grab both ends of the hard drive and carefully pull it directly upward for about an inch so that you can see the cable connected to the motherboard. Disconnect the cable and then pull the hard drive the rest of the way out. Take out the four mounting screws that are located on both side edges of the hard drive. Take the replacement hard drive and install the mounting screws into its left and right sides. Plug the cable that runs from the motherboard into the corresponding port on the replacement hard drive. Check the direction of the new hard drive and lay it into the open slot in the same direction as the old hard drive. Use the two screws you pulled out earlier to hold it in place. Slide the cover piece back on and replace the five screws. Push the battery back into the laptop until the latch snaps into place. Hope this helps.
Dec 08, 2012 | Computers & Internet
Tip
How to replace a IDE Hard Drive
The following tip is a step by step instruction guide to replace your IDE Hard drive.
Before you start working with any of the Computer hardware, you need tobe sure that your computer is switched off. Also, unplug your computerfrom all cables.
Once you are done with the above steps, you need to open your computercase at the side on which the motherboard is not situated. This isusually done by unscrewing the 2 screws at the back of the panel.
Now slide away the panel gently and expose the inside of your computer.
You will be able to see a clear view of the hard drive. You will also be able to see the screws which holds the hard drive in place. There is usually only 2 screws, but if you unscrew the 2 screws and the hard drive is still attached to the case, you need to unscrew the other side panel as well to unscrew these other 2 screw.
When you are done unscrewing the hard drive, you can gently remove it from the hard drive slot.
Now, unplug the cables from the hard drive. you will just plug this cables back into the new hard drive. Just remember, if you plug in the new hard drive, you need to check the jumper settings. If this is the only drive, and you want to install the Operating system on this drive, it needs to be set to primary. Otherwise, to secondary.
After you have checked the jumper settings, you can plug back the Hard drive and just reverse the previous steps.
I really hope this can steer you in the right directions.
Kind regards
Andrea
on Feb 22, 2010 | Computers & Internet
Can you tell me step by step directions on how to reseat my hard drive on a dell inspiron 1545?
Turn off power, remove battery.
Flip it over and look to the bottom right. Remove the 4 screws with a small Phillips screw driver.
Pull out hard drive slot. Remove the screws attaching the slot, fix new hard drive in old hard drive's place.
Put screws back in, plug back in battery.
It really doesn't get any easier than this, kudos to Dell for making it easily serviceable.
if you are still unsure watch the youtube
http://www.youtube.com/watch?v=ZILBkW7Zmfo
hope this helps
Jul 24, 2012 | Dell 160 GB 7200 RPM SATA Internal for...
Instructions for installing a toshiba hard drive MK103GAS in a Sony Vaio laptop
Step 1 - Remove Screws Flip the entire laptop over and remove the battery.617_bottom.jpg
There are a total of 4 screws you need to remove as depicted in the red circles.617_unscrew.jpg
Begin removing one at a time.617_unscrew2.jpg Step 2 - Removing the Keyboard After you remove the four screws from the bottom chassis, flip the laptop over and take a look at the keyboard area.
Now look carefully at the top corners of the keyboard, there is a tiny little button that you need to push in order to release the keyboard. 617_keyboard1.jpg
Push both the release keys while pulling the entire keyboard towards you. 617_keyboard3.jpg
Gently lift up the keyboard towards you, while flipping it over. 617_keyboard4.jpg
The keyboard has been removed!
Step 3 - Removing the Palmrest Looking inside, you will need to remove three screws as depicted in the red circles below.617_unscrewhandrest.jpg Next, gently slide the entire palm rest chassis towards you.617_handrestremove.jpg Before you lift the palm rest, notice the delicate ribbon cable on the underside. Then lift it upwards, flipping it over. Be careful not to rip the ribbon cable that's connected!617_handsetremoved.jpgYou now have access to the hard drive!
Step 4 - Removing the Hard Drive Remove three screws from the cage holding the hard drive as depicted below in the red circles.617_unscrewthree.jpg Next, gently remove the SATA cable from the hard drive. It may require a bit of effort to pull the SATA cable from the hard drive, just try to be gentle. Note that there is tape over the SATA cable underneath the hard drive making the SATA cable more difficult to pull out.617_removesata.jpg
Be careful in this step not to rip the ribbon.
The hard drive is now removed!
The next step is to just remove the stock hard drive from its cage be removing the screws on the edges and replace it with the hard drive of your choice. Carefully screw it all back in place, slide the keyboard back in and power on your system! 617_hardrives.jpg
Replacing Toshiba 120GB hard drive 5400RPM with Seagate 100GB 7200RPM 2.5? Hard Drive.
Enter the BIOS by pushing on F2 key during the VAIO boot screen. Ensure the proper hard drive is listed in the BIOS. 617_biosscreen.jpg
Insert your Windows XP or Recovery DVD disc to begin installing the operating system!
if it help full to you please vote me
thanks:ayyunoora
Oct 27, 2010 | Computers & Internet
I need to install a new hard drive .. how do I do
  1. urn the laptop over. Position your laptop in the direction so that the Toshiba label, on the bottom of the hard panel, is facing you. Your Toshiba label is positioned correctly if it is positioned on the upper-left side of the external hard panel. Remove the battery pack from the bottom your Toshiba laptop to be sure it is powered off.
  2. Step 2 Remove your laptop's external hard panel. This panel is the external plastic layer on the back of your computer to cover and protect your computer's most important hardware components. The screws you need to remove are located on the four outermost corners of the bottom of your laptop. Follow the chart guide listed in Tips for screw and screw driver compatibility and removal. Distance your screws from your workstation to avoid mixing them up and/or losing them.
  3. Step 3 Locate your hard drive panel drawer door when you have totally removed the external hard panel. It is located where the smaller door in the bottom-right panel was before your removed the external hard panel. Your hard drive will be locked into this specific drawer door and the computer itself. Completely unlock the hard drive and remove the drawer from your laptop.
  4. Step 4 Remove the entire hard drive from the drawer door. Hold the hard drive on all sides to ensure that you do not drop it. Place the removed hard drive in an enclosure area to avoid damage of any kind.
Place the new hard drive in and put it back up.
Please let me know if you have any further questions or concerns.
Thanks.
May 04, 2010 | Toshiba Satellite A105-S4334 Notebook
Need service manual or instructions on replacing hard drive on a Sony Viao VGN-ns135e or Sony VGN-NS100 Series Laptop
The hard drive is inside of the laptop and not accessible from the outside. The way to get to the hard drive is to take out all the screws from the bottom of the laptop, take the keyboard out and there may be some screws there that need to be removed. The dvd drive needs to come out and where the dvd drive normally is, check for screws there.
At this point you can remove the top cover assembly and you will see the hard drive. Remove the screws that are holding the hard drive in place and then it will come out.
Nov 30, 2009 | Sony VAIO VGN-NS135E/S Notebook PC
How to open sony vaio-pcv-w101/w to replace bad ram?
Try this:
STEP 11
Lift up and remove notebook display panel.
13-taking-apart-notebook.jpg STEP 12
Remove hard drive cover, memory cover and modem cover from the bottom of the notebook. Each cover is secured by one screw.
14-taking-apart-notebook.jpg STEP 13
Here’s how you can remove the hard drive. Remove four screws securing the hard drive caddy to the base assembly. Slide the hard drive down to disconnect it from the motherboard. Lift up and remove the hard drive.
15-taking-apart-notebook.jpg STEP 14
Removing memory modules (if needed). Carefully spread latches on both sides of the memory slot. The memory module will pop up at 30 degree angle. Pull the memory module from the slot by the edges.
Removing modem card (if needed). Remove two screws securing the modem card. Lift up the modem card to disconnect it from the motherboard and unplug cable from the side.
Hope this Helps
DR GEEK MD
May 06, 2009 | Sony VAIO VGC-V617G PC Desktop
Replacing Hard Drive in a Sony VAIO SZ330P/B
Turn your Vaio upside down and look for an easy access panel or release lever to remove the hard drive carriage. You will probably need a small Philip's screw driver to remove the carriage, but I don't think you need to remove the keyboard.
Aug 10, 2008 | Sony VAIO VGN-SZ330P/B Notebook
How do I remove the hdd from compaq nx9010?
Hi - follow these steps and picture:
. Remove the hard drive by following these steps:
a. Remove the two rubber screw covers 1 that conceal the
hard drive retention screws.
✎Spare part number 371808-001 should be used to replace
the hard drive rubber screw covers.
b. Remove the two PM2.0×6.0 screws 2 that secure the
hard drive to the notebook.
c. Use the notch in the hard drive bezel to slide the hard
drive forward 3.
d. Remove the hard drive.
864136d.gif If this solves your problem PLEASE rate this as fixed. If you need more help just add a comment and I'll be happy to assist you further. Thanks.
Jeff
May 21, 2008 | HP Compaq Business Notebook NX9010
Sony Vaio PCG-6G1M
sure..it's easy...take battery out first
turn over the unit
find hard drive on side
look for two screws holding it on bottom
usually small phillips is needed for that
remove screws
gently pull hd from slot
keep screws with drive, until you replace it
check your computer warranty here 4 FREE
Mar 19, 2008 | Computers & Internet
Sony VAIO VGN-N250E/B Notebook Logo
2,354 people viewed this question
Top Sony Computers & Internet Experts
Alun Cox
Are you a Sony Computer and Internet Expert? Answer questions, earn points and help others
