Question about Kenmore 75085 Air Conditioner
No power, the a/c was running the cut off. have checked all breakers
    Renaissance:
    An user who is expert in 3 categories / brands.
  • 1,810 Answers
Did you check the fuse inside
Posted on Jul 31, 2009
My kipor generator runs but produces no power. What is likely to be the problem
Is there any circuit breakers or main cut off switch in the off position? If so start the generator and turn on all circuit breakers or cut off switches.
Jan 28, 2018 | Kipor Electrical Supplies
Eb20b/ electric furnance/ blower wont shut-off after heat kicks out, got to kill breaker , runs all the time, installed new thermostat, no change?????? Its cold??????
Check the thermostat and make sure the fan switch is set on "Auto". If it is set on "ON" the blower will run constantly.
Jan 31, 2015 | Heating & Cooling
Smeg sca130p. Interlock wont release after running through pyrolytic cycle. Tried running through cycle again but still wont open hours after cycle completed.
Cut the power to it completely, so if its on a breaker, press the test button on that breaker. Wait 3 minutes and put power back on. Has it cleared the problem?
Dec 21, 2013 | Ovens
Bryant condenser not running.
Check that there's power available (open or tripped breaker or disconnect). If there's power available, check for 24-28 volts feeding the contactor coil. The low refrigerant cut-out may have tripped the 24v (leak). The pressure cut-out may have tripped (dirty condenser coil, inoperable condenser fan motor). If there's 24 volts at the contactor coil, check the capacitor before ohming the motor. A defective run capacitor will shut the compressor down.
Aug 27, 2013 | Bryant Legacy 16 Series 4.0 ton AC...
My incoming voltage is only reading 200v, will this stop the unit from running??
If it needs 208 or 220 then yes it will stop the unit from running.Check the voltage at the circut breaker to verify its not a wiring issue.
You may need to get a new circut breaker.Also check a 115 volt outlet if its is also reading low ,like 100 or 105 volts then the power ccompany is cutting power back and theres nothing you can do.
Jul 20, 2011 | Dayton (3UG73) Electric Utility Heater
6180-20 chop saw trips 20 amp on start up all the time Terry
If it trips the breaker as soon as you hit the switch, check the power circuit. Check the power cord for frays or cuts, especially where the cord goes into the saw. Remove/split the handle and check the wires into and out of the switch and to the brushes and field. Lood for burned or melted wires or case parts. Milwaukee is notorious for running lots of small wires in very tight places. Make sure none of them got pinched when the tool was assembled. Watch for this also when you reassemble the saw. Check the brushes, if they're worn or broke they can cause a short on the armature. If these all check out you need to have the armature checked on a growler for shorts.
If the saw runs for a few seconds then trips the breaker I'd check for gear and bearing problems. Cehck for free, smooth movement of the bearings on the armature and blade drive assembly. The blade should turn freely by hand. Feel for undue resistance or a gritty feel in the bearings and gears. If necessary replace any offending parts.
Aug 31, 2010 | Milwaukee 6180-20 14" Chop Saw Abrasive...
Bissell lift off bagless tripped breaker. Cut
if it overheated, there is a automatic switch in or near the motor that resets automatically...if its cooled and wont start back up??? Then check that your outlet has power to it. if not, reset trhe house breaker and if it does, start hitting garage sales for 5 dollar vacuums....
May 02, 2010 | Bissell 3750R Air Conditioner
My honda gx160 generator keeps cutting out after 2 mins
Sounds like fuel flow is restricted.
Is the vent cap on the gas tank clear?
Pull the fuel hose off at the carb and let run into a container from the tank......is fuel flow good while filling a cup or two worth of fuel?
If not check filter at fuel switch or at hose connection at tank for restriction.
It takes about 2 minutes to use up fuel in the carb with engine running.
Sure sounds like a fuel problem.
Sep 06, 2009 | Master Heaters MASTER HONDA POWERED...
Unit will not come on,power to everthing,but blower will not come
You probably have a bad breaker.
Check to see if you have 220 volts coming into the breaker. (while the breaker is in the ON position) and check to see if there is 220V coming out of the breaker. If no, then you have a bad breaker.
If you do, let us know and we can help you diagnose from there.
Jan 16, 2009 | Heating & Cooling
Mower won't start
13 to 15 amps electric or battery operated mower may runs slow when cutting thick grass. also recommended not to cut grass when it's wet & need very sharp blade to do the lawn. may overloading it, cutting grass too thick also draws too much power. check house breaker first.
Jun 11, 2008 | Black & Decker 19" Electric Lawnhog...
Kenmore 75085 Air Conditioner Logo
104 people viewed this question
Top Kenmore Heating & Cooling Experts
Dan Webster
Dan Webster
Ronny Bennett Sr.
Ronny Bennett Sr.
1STHVACMAN
Are you a Kenmore Heating and Cooling Expert? Answer questions, earn points and help others
