SOURCE: constant green blinking light Mitsubishi tv WS-65513
Hello all. I have fixed my green blinking light problem on my Mit. 65513 rear project. hdtv. It is on now as I'm writing. I replaced 4 capacitors on the DM board (largest vertical standing board). I used a desolder tool from RS($15).I practiced on a discarded board first. I replaced the caps with 4 radial capacitors rated 1000uf 16v. 105 degrees c and was sure to match the polarity markings on the board(+/-)with the markings on the capacitors. That's it! I also installed a small 12v PC fan(wired to a 12v wall adapter) on the DM module casing with zip ties. You may also use 1000uf 25v 105c caps. I hope this helps-good luck!
SOURCE: Panasonic PT47WX49E blue convergence
me too! everything fixed now how do you exit chk mode??
SOURCE: mitsubishi TV WS-65713
you can get the service manual and detailed instructions on that repair by going to the following link.
http://servicemanuals.vstore.ca/
SOURCE: InFocus ScreenPlay SP61md10 (same as RCA HD61THW263)
I hope you are still under warranty. This is usually a problem with the main DLP chip seating properly on the board. I have rarely been able to correct this without getting a new engine board and DMD (digital mirror device).
SOURCE: Picture problems and need service manual.
http://www.justmanuals.com/samsung-projection-receiver-hcr4755wx-parts-service-p-25530.html
$9.99
