Question about Sony MHC-GX450 CD Shelf System
Speaker wire is bad where it enters the cabinet. How do I disassemble the cabinet to repair this.
  • 90 Answers
The face is glue on the board and the plastic is glue.
Posted on Jul 31, 2009
Impute jack on a kick back type cabinet. need to remove amp from cabinet to repair.
Very simple. Remove all black screws at top and sides of cabinet. Gently slide the amp unit out (towards rear). Done! :)
Don't be alarmed if you have to "tug" on it a bit. This is normal. Just don't try to "FORCE" it out.
Jan 11, 2013 | Behringer Ultrabass Bxl3000
How do I disassemble the JHT525 speakers so that I can paint the enclosure?
Just takes the screws out that are holding the speakers in to the cabinet, Unhook one wire at a time from the speakers end keep track of where they go on The speakers for when you put them back in,
Dec 05, 2012 | Car Audio & Video
How to open the enclosure???
Many speaker enclosures are glued together - this helps prevent vibrations of cabinet panels. Many panels are made of particle board, covered with a simple veneer. Disassembling the enclosure would likely be destructive.
The best way in, turns out to be via the largest driver - or woofer. The woofer is the largest speaker in the cabinet and is usually held in place by 4 screws. It can be removed without (or with only minimal) damage to the cabinet after removal of the screws with a screwdriver. Use of a battery operated screwdriver is discouraged due to the possibility of stripping the holes in the particle board. Once the screws are out, you might need to gently pry the outer edge of the woofer's metal frame from the cabinet with a small screwdriver to separate them.
Be prepared for the speaker to come spilling out of the cabinet. Wires on the speaker - if to be disconnected - should labeled as to which terminal they are connected - so the speaker will be in phase when reconnected. All wires to be disconnected should be labeled first! You may find filler material (looks like a thick fiberglass blanket) and crossover components (coils & capacitors) along with the additional wires between the crossover components and other speakers in the cabinet. Be careful to not accidentally disconnect wires from the internal components if you need to remove the filler material.
These are tips for opening most speaker cabinets - yours may differ slightly. Hopefully, this helps. Please rate this reply - thanks!
Dec 13, 2010 | KLH 915 Main / Stereo Speaker
Hello sir my problem is how to attach cabinet
all the wires have their names, ex. speaker, all you have to do is find the speaker terminal in *********** board, and so on,
Jun 19, 2010 | Computers & Internet
I have a set of teac speakers that are about 40 years old and I need to replace a woofer. I just do not know which one to buy. The speakers were bought in Germany, the model number is LS-80 and they have...
These sound like they a JBL speaker.
1. You will need the impedence and diameter spec and the Hz (hertz) specifications to get a replacement set.
you can call JBL Altec-Lansing is the company that manufacturer this series of speaker.\ On the back of you speaker cabinet should be a phone number to the company or check the user manual that you received with the speaker system and they should be able to give full information on how to replace the speaker in question or where to have it repaired.
The cabinet is glued together and will need a cabinet expert to disassemble.
Contact JBL for more information.
Mar 10, 2010 | Electronics - Others
How do i disassemble my ws-65313 for transport
Good Day,
To disassemble this TV follow these directions:
1). Pull front speaker grill off
2). Unplug the 2 cables connectors in front
3). Remove 4 screws on both sides of cabinet (might have plastic covers)
4). Carefully lift cabinet top until the support tabs clear the bottom cabinet
5). Carefully rotate the cabinet top and place back side on floor ( the mirror is on the top side)
6). Pack/wrap properly with blankets and transport in this manner.
Good Luck and Move, Big Irish.
Dec 02, 2009 | Mitsubishi WS-65313 65" Rear Projection...
The amp protection circuit was actived - what should we do?
Remove all speaker wires from the receiver and turn it on.
If it still goes into protect, I'll bet the house that one of the channels is shorted out and it needs repair. This is a job for a pro.
If it doesn't go into protect, check for a short in the speaker wire or for a bad speaker.
Jan 28, 2009 | Onkyo TX-SR605 Receiver
Passport 250 PD dropped face first and it loosened the inside speaker connection
I have experience with the original Passport 250 as leader of the design team. To get inside of the speaker cabinet, you will need to remove a couple of small screws that hold in the grille at the top and bottom of the cabinet face. Once these screws are removed, you will need to carefully pry out the grille from its pressure fit in the plastic noting how it is placed so you can reassemble the grill later. Once the grille is removed you will notice several holes located around the outer perimeter of the speaker panel. Inside these holes, you will find the screws that secure the front of the cabinet (part with speaker attached) with the back of the cabinet housing. Once you have all of the screws removed, you can separate the front panel from the housing and fix the wires or dislocated parts such as crossovers, etc.
Once repaired, use the reverse method to reassemble the cabinet. Don't tighten the cabinet screws excessively as they can strip the plastic.
I hope this repair works for you.
Oct 18, 2008 | Fender Passport P-51 Consumer Microphone
Z5300e center speaker no longer works
Hi Phineasj
It is possible the speaker is bad, and defective, time to change,or repair, or RMS, try carefully, open and see the cables, you also can welding the cable again the cables IF broke.
good luck
Nov 25, 2007 | Logitech Z-5300E (970102-1403) Computer...
Sony MHC-GX450 CD Shelf System Logo
111 people viewed this question
Top Sony Audio Players & Recorders Experts
 Grubhead
Grubhead
Are you a Sony Audio Player and Recorder Expert? Answer questions, earn points and help others
