Question about Garden
How to change the spring on my Poulon Weed Eater PE330
    President:
  • 2,559 Answers
Which spring are you referring to?
And this is the gas edger,Correct?
Posted on Aug 04, 2009
  • 336 Answers
Hi there, Please clarify the exact model of your machine. I't appears that Poulan doesn't have PE330 for their weedeater models. Thanks, Jeep Brainy
How do you replace trimmer head on poulon wt3100 with new one
you should see the mount screws to remove the head, you may have to open the string case and remove parts in there depending.
Jun 08, 2014 | Poulan/Weed Eater #Wt200 711724 24cc Gas...
Where do I find a poulon weedeater 24 cc DOUBLE compression ring piston, wrist pin and retainers kit. No conn. rod needed. Thank you FHA
Are you sure it is a double ring and not a single? Get back to me, because it looks like a single ring. If so try Sears parts dept. Make sure to give them the model #, and ask them to look it up on the LIS system.
Oct 04, 2013 | Poulan/Weed Eater No. Bvm200le 711482 24cc...
What is the oil ratio for the poulon pro link weed eater
Hi brochon
Use a 50 to 1 ratio...1 pint 2 cycle oil to 6 gallons of gasoline
Please take time to rate me
Aug 28, 2011 | Poulan/Weed Eater No. Te475 952711797 17"...
Replaced starter spring on Poulan/weed eater FL1500LE leaf blowe.
you may have wound the spring backwards, try winding the othe way.
May 09, 2010 | Garden
Manual
Typically 32:1 to 40:1 for all these models. Use 35:1 and modern 2 cycle oil and you will be fine. :)
Apr 29, 2010 | Poulan 17" T&E Gas Trimmer
Poulon-Pro leaf blower manual
If you know your model number (i.e EVB160 etc) you can use this link:
http://www.poulanpro.com/node4043.aspx
enter your model number and download it.
If you do not know your model number
click on products same link, then click on blowers (not snow throwers) find your model then go back to the users manual download.
Thanks for using fixya.
Feb 14, 2010 | Poulan Weed Eater Electric Blower/Vacuum...
How do i replace a rewind spring in a stihl fs 45 weed eater
you have to kake sure u wind it the rite way there should be tension on the spring when it is wound and if let go should return if it does that u have it rite...the little plastic peice must be connected to the hooh on the spring
Jul 25, 2009 | Black & Decker Garden
Need motor brush
Try a power tool repair shop
Try an electric motor repair shop
Try to find brushes that have the same length spring, same size spring. If they are a little big, they can be made smaller by dragging them on a flat file 'till they fit nicely.
Apr 28, 2009 | Poulan Weed Eater Rte115 4.5 Amp Electric...
Garden Logo
77 people viewed this question
Top Garden Experts
Dennis Key
Dennis Key
john h
