Question about Garden
Low pressure spray only - Garden
    Renaissance:
    An user who is expert in 3 categories / brands.
  • 1,810 Answers
Likely the ruber o ring is broken in the gun take the triger assembly apart and inspect also remember that if a piece is missing look down the barrel of the wand
likely it will be a piece of ruber stuck in the end of the wand
Posted on Jul 31, 2009
On page 25 under trouble shooting for greenworks 1700 it states that you can turn nozzle tip to a high or low pressure position. how is that done?
The owners manual was badly written by someone in China whose English is a second language. The output pressure is set at the factory. The only thing the consumer can do is change the spray pattern by changing the nozzle. 0 for pinpoint, 25 for small fan spray pattern, 40 for large fan spray pattern, and Soap for dispersal.
Jul 08, 2016 | Greenworks 1700 PSI 1.4 GPM Electric...
Intermittent fuel delivery problem. 93 Chevy Lumina APV 3.1L with throttle body fuel injection.
year/make/model/engine size??? Do a fuel pressure test to see what the pressure is. Low/no pressure= poor spray
Nov 08, 2015 | Cars & Trucks
How do i prime my troy built 2550 psi pump for the soap?
You have to use a low pressure nozzle ( usually black with very large spray opening) With the low pressure nozzle siphons your detergent in with the spray water . If you are using a high pressure nozzle the soap will not prime.
Oct 26, 2014 | Garden
Pressurewasherwon'tpullupsoap
I got two washer units and never been able to get soap to work. I read the instructions last week and it says you have to use a low pressure spray setting or low pressure spray tip. I haven't tried it yet but I always wanted some soap and the high pressure. LOL
Sep 12, 2013 | Garden
DE6744 spray arm duct needs replaceing
The water pressure must be good and the spraying must be seen to be good. If there is low pumping or pressure then the spray arms will not turn around to inject with pressure. If so the pump must be checked for clogging.
To replace check this link:
http://www.espares.co.uk/advice/dishwashers/a/3/1293/how-to-replace-the-spraying-system-on-a-dishw.html
Nov 07, 2011 | Dishwashers
Low water pressure
Remove the spray head and point the hose into the sink drain. Turn the faucet on. If you have good pressure, cal American Standard for a free replacement spray head.
If you still have low water pressure without the spray head, ask them for a new faucet cartridge.
After replacing the faucet cartridge, if you still have low water pressure you will need to ask for a new faucet, possibly free if yours is still under warranty.
Sep 07, 2010 | American Standard Kitchen Faucet 6310 020...
Low water pressure coming out of faucet. good press at ang stop.
If you just installed it check to see if it has a water saving feature that in some homes and almost restrict all the water force
Feb 18, 2018 | Price Pfister Marielle Kitchen Faucet with...
How do I get my Power Washer to spray with soap in the water?
You will need to adjust the pressure to low pressure by adjusting the lance. This way the machine will draw chemical at low pressure.
May 21, 2010 | Karcher G3025OH Pressure Washer
Kohler K-12177 low water pressure output. Removed
check valves under sink make shure tey are all the way on but spray them into a bucket if you can to see if they are ok.
Oct 25, 2009 | Kohler Model 10433: Fort® Single-control...
Honda p/washer won't **** up cleaning chemicals cleaned filter,still no go.
In general, pressure washers will draw detergent from the reservoir only when the spray nozzle is set to low pressure. At high pressure a non-return valve closes to prevent water flowing back in to the reservoir. If you've got the spray nozzle set to low pressure and still have the problem, it may be that the spray nozzle is partially blocked - you can try clearing it with a length of wire.  Failing that, the non-return valve is probably stuck (and that may need professional attention).
Apr 17, 2009 | Honda Garden
Garden Logo
467 people viewed this question
Top Garden Experts
Dennis Key
Dennis Key
roeb
john h
