Tv(zenith space command 1987 model, console) wont come on. I plug it up and there's no indication at the on/off push button, could it be my power supply if so how do I check I have no diagrams
  • 27 Answers
Checked first the ac outlet if theres a supply then the ac cord (male plug), the main switch of the tv....if it is all good then go check the power supply section af the tv
Posted on Jul 31, 2009
I have a Zenith D60WLCD, I have replaced the lamp and it still will not power up. I there something I need to reset.
You need to reset the lamp counter if it reaches 16,000 hours. The tv will not turn on once this limit is reached. With the tv remote, and the tv off, push the ? Button on the remote, then 9876, then push the enter button. The three lights on the front panel will flash indicating the counter has reset.
Dec 11, 2012 | Zenith D60WLCD Television
How do I reset the replace lamp indicator light on my zenith d60wlcd tv ?
Aug 30, 2012 | Zenith D60WLCD Television
I need to reset lamp timer on zenith d60wlcd
Jun 29, 2012 | Zenith D60WLCD Television
How do i program my remote
Hello;
Without knowing the codes for the specific brand names and models of your devices, this is how you program the Zenith MBR3447 for your TV, VCR, DVD Player, CD Player or Audio Receiver:
TV
1. Push the "Power" button on the TV to turn it on.
2. Press and hold the "PRG" button in the upper left corner of the remote. Release when the indicator light, located in the top center of the remote control, comes on.
3. Push the "TV" mode key located at the top of the remote.
4. Enter 0 -- 0 -- 0 on the remote's number pad, then press the "Enter" button.
5. Aim the remote control in the direction of the TV's IR sensor and push the "Power" button. Pause a second. If the TV fails to shut off, push the "Power" button again. Repeat until the TV does shut off. Each time the "Power" button is pressed the Zenith MBR3447 tries using a different TV device code from its code library to turn the TV off. Therefore, when the TV finally does shut off it's an indication that the remote is temporarily programmed with the correct device code to control the brand of TV you're using.
6. Press "Enter" to save the current code.
VCR
1. Push the "Power" button on the VCR to turn it on.
3. Push the "VCR" mode key located at the top of the remote.
5. Aim the remote control in the direction of the VCR's IR sensor and push the "Power" button. Pause a second. If the VCR fails to shut off, push the "Power" button again. Repeat until the VCR does shut off. Then press "Enter."
1. Push the "Power" button on the device your programming the remote to control to manually turn it on.
3. Push the "AUX" mode key located at the top of the remote.
5. Aim the remote control in the direction of the device's IR sensor and push the "Power" button. Pause a second. If the device fails to shut off, push the "Power" button again. Repeat until the device does shut off. Then press "Enter."
Mar 11, 2011 | Zenith MBR3447 Remote Control
Zenith L20V34S Completely DEAD Zenith LCD flat screen 20in Model: L20V34S Manufactered: Oct 2005 Listed HealthCare Facility TV Hello all, TV wont turn on (no red light either)after turning it...
The tv now is completely dead,no LED power light indication at all?Yes,than the tv power supply board 90-95% it is alway the problems and the causes.That the board,where the power a/c cord plug into it.Tries websites like Shopjimmy.com,Ebay.com to buy a refurbish power supply board for the replacement.
Mar 01, 2011 | Zenith L13V36 LCD TV
I need the Zenith remote control code for the 1986 Zenith TV
joe, the remote control codes are not the same from vendor to vendor. I think you're trying to program a universal remote control to operate your tv, if this is so, you will need to get the model number of the universal set and refer to the product code list, look under tv and zenith, another procedure you may try is the code search, this puts out all the available codes programmed into the universal set, just follow the instructions and be very patient because like I mentioned it will take you through all the available codes untill it will send the correct one for your zenith tv.
Feb 10, 2010 | Televison & Video
I need instructions for the zenith universal remote 3201 for a new Panasonic LCD TV
If you have a manual for remote and you try all codes for your model and it didn't work, you may try for automatic search. First turn on TV, and point the remote toward the TV. You press: SETUP and hold, and press button for device: TV, lite is on, then you release all button and press again SETUP, just once, the lite is blinking, now press the power button on a few seconds. When your tv is turned off, you press button TV. Press button for power and it will turn on your tv. Try other commands on your remote, if everything is working that's it, if not do procedure again. Hope this was helpful, if not, ask more. By!!!
Nov 03, 2009 | Zenith ZN-501S Remote Control
POWER SUPPLY
zenith are famous for bad soldering even going back to the 80s with the 960-05 boards in the space command sets.
i would pull out the circuit board and check the soldering before doing anything else.
Sep 09, 2009 | Zenith Televison & Video
Zenith DLP-Projection tv 42"
Try this solution which I found on Fixya
This solution is for the zenith 56" DLP. Unplug the tv, either from the wall socket or the TV. While the TV is unplugged hold the power button on the TV for 40 seconds. This lets the excessive power drain from the TV. If this does not work call 1-800-243-0000. This is the number for their help line. This is the fix the tech gave me and it worked right away. Hope this helps and have a great day.
Zenith dlp projection model z52sz80 turns off randomly
Further advice here. If the bulb is over a year old it is suspect.
LG DLP TV wont power up Red indicator lightjust blinks when
and where I got all this information frlom
zenith dlp projection tv blinking red light Google Search
Jan 09, 2018 | Zenith Televison & Video
Zenith Remote controller
It's a Zenith remote, MBR 3440 is the model #, 124-202-01 is the part #. To program, press and hold PRG button until red light stays on, press TV,AUX etc, enter 3 digit code (www.xdiv.com) press Enter.
Jan 10, 2008 | Zenith HCS3000R Headend Controller For...
Televison & Video Logo
226 people viewed this question
Top Televison & Video Experts
