Royal Sovereign White 1200 BTU/12,500 Heating Air Conditioner Logo
Henri Forcier Posted on Jul 31, 2009
Model ARP-2113 has a drain at bottom- awkward to drain in pan? any suggestions?
1helpful
LG ptac MODEL : LP153HD3A collecting condensation water in bottom but not going to outside drain pan.
there is probably a blocked pipe or filter it will need cleaning, you may need a pump to remove the water first to get to the pipe to clean it out.
1helpful
I have a Samsung model RF4287HA French door refrigerator. Has anyone had success cleaning the drip pan located at the bottom rear of the refrigerator? I know that this pan can't be removed, but I can'
Hello Derek;
My name is Peter. I am a retired field service refrigeration technician.
In answer to your question, the drain pan is removable. This drain pan is available for purchase. The problem is both Samsung and LG are not service friendly. The drain pan is not secured with fasteners and just lifts up.
However, There is the interference from the seal system (refrigerant) tubing and compressor which prevents you from pulling the drain pan out.
On my service calls with drain pan leakage, I just repaired the drain pan with duct tape an silicone adhesive. Because I could not get the drain pan out with out moving the compressor.
Both, Samsung and LG are the worst service friendly and highest cost for repair.
The bottom of my fridge is filling up with water. I noticed its leaking from the top back of my fridge. Someone suggested its a condensation problem.
Check the drain tube that runs from the freezer to the drain pan, my guess is that its plugged with goo, connect a bulb like you use to asperate a child nose ect and see if it plugged, you can use hot water from the drain pan end and force the water up forcefully to break it loose or you may have to remove the bottom pan in the freezer and clear the drain. If its got ice built up blocking the drain then use hot water to cut the ice and clear the drain first if possible, then the water pan will catch it, but don't let it over flow.
My product royal sovereign arp-4012h is flooding my floor it needs to be drained... the manual says when product gets fiull of water drain plug what plug & how do i get to itt were is it located.. i...
The water drain plug is located on the rear. On the bottom left edge next to the cord keeper. You'll need a pan that will fit under the drain hole, before you unscrew the drain plug. Which has a plastic handle.
Hope this helped you. Please let me know. Thanks
Have a kenmore bottom freezer and when it is humid water leaks from, I gues the drain pan, and stops leaking when humidity drops. Any suggestions other than me putting a towel at the bottom right of the...
you may have a crack in the drain pan. or you drain line has a hole in it . remove your drain pan check for cracks. some glue can repair that, an glue can repair your drain line too.
While cleaning Maytag MBF2556HE Bottom Freezer Refrigerator coils, I noticed green gunk along with the water in the drain pan. It was suggested that I add bleach to the drain pan and to "let it evaporate...
Hello Watsky,
I have ZERO experience with bottom freezers...
BUT
I can assure you a WELL working refrigerator will
deposit water at least daily in the DRAIN PAN...
You will likely not find the pan dry & dusty..
That is typically a sign of DEFROST PROBLEMS.
If your pan is filling toward the TOP on a daily basis... That is USUALLY a SIGN you live in a really HUMID climate OR...
You have a PROFOUND air-leak causing abundant
FROST... Resulting in High (defrost) water in your
DRAIN PAN...
AIR-LEALS are most commonly caused by poor
gasket contact... or REFRIGERATOR CONTENTS
(pizza box) blocking full DOOR/DRAWER closure.
Generally:
you want to follow the manufacturer's warm "SOAPY"
cleaning approach...
GREEN can be pretty unsettling...
If the pan is REMOVABLE... DAWN like detergent
is probably on the AGGRESSIVE side but
I also like SUPER-CLEAN food storage.
Just remember... WARM... never HOT..!!
Wash it alL out quickly... ad gently put it back ...
Check your door seals...
Keep tings clean... Prosper & be healthy
Carnac the Magnificent
SANYO MODEL STWO923H1 CANT FIND THE PAN DRAIN
find the drain outlet and use a wet vac to extracate the water from the pan Slime has appearently clogged the drainage tube Good Luck
Dave
2answers
Drain pan fills quickly
Can you descibe where the unit is located and what climate you are in? Thanks
Top Royal Sovereign Heating & Cooling Experts
Paul Carew
john h
Are you a Royal Sovereign Heating and Cooling Expert? Answer questions, earn points and help others
