Question about Dell Dimension 2400 PC Desktop
Video graphics card
How can I change from an onboard video graphics to a PCI installed graphics card. My onboard video graphic won't let change to the PCI card. I'm trying upgrade my graphics to more memory using the PCI card instead of the onboard graphics.
  • Anonymous Mar 27, 2014
    Graphic card for dell Inspiron 518
  • 93 Answers
Being a PCI card, not a AGP or PCI-E the system may not simply switch to that one a primary display adapter when you install it, in the bios under advanced system settings or intergrated periferals, you should have an option to change the primary display adapter, make sure a PCI adapter is included.. if it isnt, chage it to recognise a PCI card as a primary adapter, turn the system off, and install your card then, depending on the bios/model of the mainboard on some of those dells, it may be a little hard to find, ive had to play with a few of them
Posted on Dec 06, 2007
    Problem Solver:
  • 7 Answers
You should just have to plug the card in to the PCI slot and install the drivers. After thats done try removing the driver for the onboard graphics I had onboard switched to a geforce 8800 and it worked just fine for me. Did you say your running a Dell?
Posted on Nov 24, 2007
Hello here is the ASUS homepage:
Here is a list of beep codes:
Your pci-e graphic card is failing or has a defect.
The problem could also be the power supply, not giveing enough power.
When you add a pci-e graphic card on the mainboard, the onboard graphic should deactivate itselves.
Try to remove the pci-e graphic card, and use the onboard graphic.
If still no picture, change the power supply.
Its not possible to change settings in the bios blindfolded.
You can reset the bios by removeing the cmos battery.
But ofcouse it could also be the mainboard itselves failing.
This is rarely happening, so i hope its just the power supply.
Try also to look for visual defects on the mainboard, especially the condensators on the mainboard.
Good luck
Apr 14, 2013 | Computers & Internet
I want to install my palit geforce 210 1gb ddr3 on my desktop with win7 & 3gb ram, model of cpu is aspireM5600. The problem is, when I installed the vdeo card driver and it requires to restart the
Using onboard graphics enter into the BIOS and set the setting to display to PCI-Express first then onboard if noexist PCI-E graphics.
Save and exit.
This will allow you to install your new graphics card to your monitor.
Take care!
Sep 11, 2012 | Palit Microsystems Palit nVidia GeForce...
My integrated motherboard graphic card is damaged and i am installing a new graphic card but i need to disable any built-in graphic capabilities on the motherboard. can u please help?
Enter the bios and disable the onboard video card. If that is not an option, then there should be a setting for the video to boot to AGP or PCI. Change to PCI.
Jun 20, 2011 | Computers & Internet
I am trying to install a pcie-x1 video card on a ibm eserver x206m i salvaged from work. I am running windows 7 64bit . I have tried to turn off on board graphics so that it takes the video card i just...
I know this is really old, but I had the same problem on my 206m 8584 with a pci-e x1 video card. I had to upgrade bios first, but nothing seemed to change, bios only showed onboard video as option and windows perfectly recognized the exta card. I went to windows video settings, it showed both video, onboard as main and active and extra as inactive, changed the second video to main and active and switched the plug to finally see my enhanced video. Only problem is that bios screen won't show up on pci-e card, so I start seeing something only after one minute :) Hopes this saves someone else some time.
Nov 03, 2010 | IBM eServer xSeries x206m
PCI-E card does not work, onboard video works fine, this is the second card.
The Abit IP-95 manual doesn't show you how to adjust your bios settings when adding a PCI-E x16 graphics card. When adding a PCI-E card you'll need to adjust a few settings within, Advanced Setup.
Press the delete key on your keyboard every two seconds to load your bios menu. Within Advanced Setup look for, Onboard Device Configuration and open it. Find, Primary Graphics Adapter.
Set this to read as [PCI-E, VGA] save your changes and exit.
Currently your onboard graphics is enabled. You'll need to change this setting to PCI-E first. When you use the onboard UniChrome Pro 2D/ 3D Graphics & Video Controller you are also using some of your system memory to run the UniChrome graphics. Once you enable the bios to boot to the PCI-E card you can also stop using your system memory assigned to the UniChrome card. Link to Abit is provided below, click on it to open;
Nov 12, 2009 | Abit IP-95 Motherboard
Dell 1600SC Server - trying to install a video card
try repeatadely pressing delete on startup with the monitor cable attached to your onboard graphics socket but keep the new graphics card in. then you should go into the bios. change the graphics setting to your graphics car and then save and reboot. it should now work from your new graphics card
Jun 18, 2009 | Dell PowerEdge 1600SC Server
H Slimline New Graphic Card-No new DCI output-Yes old VGA output
you are missing nothing actually the graphic card over rides the onboard graphics and you have to use the graphic cards output ,only one hardware at a time for pci devices
May 08, 2009 | Computers & Internet
Graphics card
Hi Harikris, no you can not install just any graphics card. You're Intel D845GLLY board uses an onboard graphics card. (It's an AGP graphics card).
If it's you're intention to install a new graphics card you must use a PCI graphics card. (Understand that the AGP onboard graphics is faster than a PCI graphics card). However, the PCI cards do use their own memory. (Which fee’s you're system memory to run windows.
The Intel D845GLLY has 4 PCI (White) slots, onboard. You can add a video card into the system. You're onboard video card does use you're system memory to function. If you're PC has 512MB of system memory & you're video card is set to use 128MB of memory. Than you're system is left to run with 128MB. One would think you're system is running a little slow.
The Intel D845GLLY motherboard can use up to 256MB of system memory. You can set the amount of system memory in the bios as shown on page 49, table 18. In you're manual. If you do not have you're manual you can download it from here:
May I suggest you increase you're system memory to 1GB. Than increase you're graphics memory to 256MB. You're system will run faster & so will you're graphics card. These older Intel motherboards require memory current for you're board. Click this link:
If you still feel that you want to use the slower PCI graphics card you can choose from any listed on this link:
You will also need to change a setting in you're bios to boot to the PCI card instead of the AGP onboard card. Page 49.
Good Luck!
Jun 04, 2008 | Intel D845GLLY Motherboard
For user BIOS21 & julio1963,
How to enable you're (Add-in AGP video card) & disable the onboard, integrated S3 graphics UniChrome 2D/3D PCI graphics card.
Enter you're bios. Open you're user manual to page 3-13. Integrated Peripherals. Go to, Init display first. Set to AGP.
(Not to PCI). That is all you need to change. The MSI bios will than see you're add in AGP card & automatically disable the PCI S3 graphics, (Onboard) card.
If I can help you further, feel free to post here.
Please, each user's vote this issue as a fix, if this helped you to get you're bios to see you're new AGP graphics cards.
May 31, 2008 | MSI KM4M-L Motherboard
Want to disable onboard graphics to install and use pci vga card
You should be able to turn it off by booting the pc up into the Bios and changing your video settings to AGP.
May 17, 2008 | EliteGroup P4VMM2 Motherboard
Dell Dimension 2400 PC Desktop Logo
388 people viewed this question
Alun Cox
