Question about Whirlpool Calypso GVW9959K Top Load Washer
Extreme vibration at the top-end of Spin cycle
Machine starts to virbrate excessively at the top-end of the spin cycle...machine stops reading OB for out of balance. Have had machine balanced but continues to do the same thing.
  • Anonymous Nov 24, 2007
    my machine starts to virbrate excessively at the top-end of the spin cycle
  • Dis-Calypso Nov 28, 2007
    Checked motor pump.....was not loose. Thanks for suggestion.
Had the same problem but the motor pump was loose
Posted on Nov 25, 2007
Washer jumps and vibrates and makes extreme noise
Is this a new machine that you purchased and installed yourself? Or is this a machine that has worked properly and is now displaying this problem? If new, it sounds as though you may have not removed the shipping bolts that secure the drum. This would prevent the drum's suspension system from being able to absorb vibration during the spin cycle and cause the vibration to transmit to the machine's outer shell. If the machine is older, then the drum suspension system itself may need repairs.
Sep 16, 2014 | Washing Machines
Excessive vibrating and banging in the spin cycle with some washes. The unit is only 1 month old. Any advice?
You have a improper installation. The machine has to be perfectly level side to side and frotnt to back. After leveling, check the feet on the bottom and see if one is bouncing on spin with a load. Adjust the bouncing foot down until machine stops bouncing.
Jan 25, 2010 | GE Profile WPRE6100G Top Load Washer
Kenmore 90 tub spins excessively clockwise during wash cycle.
there should be 2 or 3 springs that hold it, they mite have broke, take off back panel an check.
Jan 04, 2010 | Kenmore 24032\24036 Top Load Washer
Machine stops during spin cycle and reads 'ob' on the display
Read this thread about your error. I am sure it relates to your (drain) problem.
Good luck and if you have any more questions, just come back here and leave a comment - I'm happy to help.
May 21, 2009 | Kenmore Washing Machines
Washer spin cycle extreme vibration and loud bang when it stops
check the vibration damper rods for breakage - especially the mounts.
Thanks for using FixYa - a 4 THUMBS rating is appreciated for answering your FREE question.
Mar 17, 2009 | Kenmore Washing Machines
Excessive vibration on spin cycle.
Front loaders are prone to vibration problems. Don't want to go into the technical details of why, but it's important that they're placed on very solid surface (preferably concrete or tile), and checked that their feet have been adjusted so that the machine is level. Unfortunately, most people don't have a concrete pad for their washer. One simple option to consider is to provide dampening of the vibrations. This can be done very simply as this one fellow demonstrates. The main thing to keep in mind with this solution is that it is merely trying to dampen the vibrations. Don't be too forceful in your own solution (think lightly touching the top of a vibrating tuning fork with your finger to stop the tone).
Mar 12, 2009 | Bosch Washing Machines
Excessive vibration during spin cycle
Chck to see that all (6) suspension springs are still attached. Check the plastic snubber ring below the mechanism and above the base plate for cracks or contamination.
Mar 07, 2009 | Maytag Performa PAV2200
Machine vibrates excessively during spin cycle
Open washer's cover and look for a released or a malfunction shock absorber. Good luck!
Nov 08, 2006 | Maytag MAV4755A Top Load Washer
Whirlpool Calypso GVW9959K Top Load Washer Logo
150 people viewed this question
Dan Webster
Dan Webster
Sal De
