Question about AT&T BlackBerry Curve 8310 Cell Phone - Red
My bb won't ring and the speaker don't work
I was using it just fine last nite and when i woke up the speaker didnt work and the bb wont ring i try a lot of things but nothing works....help
My blackweb bluettooth speakers won't catch charge only had um for 3 days..worked fine til last nite.. wtf is goin on here?
I strongly suggest that you contact the seller of the speakers as they seam to be faulty.
Jan 29, 2016 | Cars & Trucks
My bb curve 8520 wont boot up it gets stuck on white screen with the bb logo in blue? help last nite i installed an app called callblock lite it was working fine i had put this frnds no in my block call...
Hello there!
Try to uninstall your app, and better yet to set your bb to format. It is the same thing happened to me last month with my Bold 9780 and now, it work just fine and smoothly.
Regards,
fossildude
Mar 04, 2011 | RIM BlackBerry Curve 8520 Smartphone
My BB 8520 battery got drained last nite and i start charging it in the morning, only red lighhts flashing on the led but its not opening at all.i charge it for 4 hours still not opening.
The battery cell is very weak. Using a charger won't wake it up. To wake up the battery cell, you need to charge the battery with a desktop charger. After that, you can continue charging with your BB charger.
I hope you understand the message I am try to pass above.
I summary, the battery cell needs to be boosted to wake up the battery cell. Your BB charger cannot do that.
Good luck.
Feb 17, 2011 | RIM BlackBerry Curve 8520 Smartphone
At&T CL81209 cordless phone. Line In Use light continues to flash. both phones are registered and no phone is in use.
tried the battery unplug thing and it didnt work. read elsewhere on the web that if you have directv then unplug the phone line for it and your cordless phones should work. Tried that and sure enough it did. I dont use directv phone line for anything (i order payperview online for example) but still begs the question how u harmonize using phoneline for directv AND have these cordless phones. They worked fine together for 10 months until last nite.....there was a thunderstorm though. Maybe restarting directv would cure that.
Oct 19, 2010 | AT&T CL81209 1-Line Cordless Phone
Hi ive got a alpine mrp-m1000 it lights up no sound was woking fine in the car didnt use car for 3 months then i wouldnt work all wires are fine and so is the sub please help
If your not getting any sound make sure the sub input is in the right spot on you radio. if not check the speaker wires on your harness
Feb 14, 2010 | Alpine MRP-M1000 Car Audio Amplifier
Stuck on blue screen and cant get off wont let the freesat function on ext2 any ideas? was fine last nite !!! cable still works ok tho
are you trying to use satellite? if the screen is blue the t.v. is working it is the sat. box. Try to do a hard reset by holding button for 10 full seconds.
Dec 20, 2009 | Philips Magnavox DVD/VCR Dual Player
My Headphone Wont work on my laptop
Try a different set of head phones.
Jun 05, 2009 | Gateway MT6707 Notebook PC
360 wont turn on
Hi there, This issue may be caused by your power supply and or console not getting good enough ventilation or air vents clogged with dust causing over heating. Check power supply and keep in wide open area same with console (not sitting on carpet). If over heating is the issue you may have warped your motherboard, what happens is the Graphics processing unit (GPU) and or Central processing unit (CPU) get extremely hot causing the mobo to warp and the solder becomes loose and break. Even the fan may be the culprit, the fan uses a lot of power and produces a fair amount of heat that can cause the system to over heat. Please contact microsoft and get system repair if problem persist.
Dec 10, 2008 | Microsoft Xbox 360 Console
AT&T BlackBerry Curve 8310 Cell Phone - Red Logo
102 people viewed this question
Top AT&T Cell Phones Experts
Computer Repairing
Computer Repairing
William Alequin
Are you an AT&T Cell Phone Expert? Answer questions, earn points and help others
