SOURCE: Bosch SHY66C05: interlock broken, dishwasher rinse-aid leaks, and soap does not open (sometimes)
don't know what you did with the spring but it only needs replacing if it is broken
SOURCE: i have a craftsman LT1000 and it will run for
Try cleaning your gas cap vent. It sounds like it may be partially plugged. If it is plugged, the engine will eventually stall.
Regards!, --W/D--
SOURCE: My old GE potscrubber 700 dishwasher stopped working
moter has probably locked up TAKE FRONT LOWER PANEL OFF AND YOU CAN ROTATE ROTOR/ if itis not free and rotates easly then the motor has failed / mm
SOURCE: DISHWASHER COMPLETELY DEAD
Hi John, and welcome to Fixya. I don't believe the greasy water sitting in the machine has anything to do with the problem, rather it is likely a by-product of the problem. Based on your post, I would start by first shutting off the breaker. Then removing the kick plate ( access panel at the bottom ) and checking the wiring at the junction box for the dishwasher 120vac supply line. Remove the murret's and visually inspect the wire for "resistance burn" and strip the wires back and install new fastener's if necessary to repair. This is actually quite common to find a wire connector come loose due to improper fastening and once the unit is in use for a while the connections heat & cool, become loose from normal operating vibrations and burn up from all the added heat caused by "resistance". The end result is no power to the controls. Check it out and post back what you find. Thanks for visiting "fixya" and please take a moment to rate the solution/suggestion provided here for you. Good luck. Macmarkus :)
Testimonial: "Thanks for the solution. I'm afraid I am not very technical and some of what you've suggested is over my head. I'll pass the info to my brother in law to decipher and see if the problem can be sorted"
