My home theater receiver totally shuts off when the sound level is turned up above 2
    Renaissance:
    An user who is expert in 3 categories / brands.
  • 1,810 Answers
Bad speaker polairity or crossed wires
cats like chewing wires so do pupys
and a lot of other small vermin like wires too rats mice dogs cats
check your wires then check the polairity failing that check unit 4 over heat
to check wires disconect 1 speaker at a time turn on reciever and turn it up
failing that check unit for in operational fan in rear of case
Posted on Jul 31, 2009
Fix onkyo ts-sr313 turn on problem
If the relay clicks on and then off straight away then it might have detected an overload condition and so shuts down. Overloads can be caused by faulty speakers or wiring. But if the damage is done already then one of the main power amp transistors or other devices could be short circuited.
Oct 16, 2014 | Onkyo TX-SR313 Home Theater Receiver - 5.1...
Powered subwoofer amp repair? On and off works fine.. very weak signal to sub. All wires checked and working fine.
For starters, it is a home theater in a box. With that being said, highly consider upgrading before spending more money on the system. If thats not even an option, have you tried adjusting the level of signal being sent from the receiver out to the sub? It sounds stupid, but this is often over looked and can sometimes be tricky depending upon the type of receiver you are using, to adjust the level being sent to the sub... Typically when a subwoofer has little to no sound, this is the issue. Also, is the sub powered (does it have its own amplification using a power cord that plugs into an electrical outlet? If so, does it have a volume knob on the back, and does it respond when turning the knob? If its not powered, than your problem is what I described above, unless you've already done that. If that is the case, your speaker is fried... Hope this helps
Jun 19, 2014 | Cerwin Vega CMX 5.1 Home Theater Package...
Amp keeps shutting off
• Check again with no speakers connected, if it doesnt shut off,
Check speaker system, connect one at a time to find the cause.
• If the receiver still shuts down without the speakers,
troubleshoot inside the unit.
Aug 04, 2012 | Yamaha Rx-a710 Aventage 7.1 Home Theater...
RT2770 cuts out above a volume setting of 30.
Bass and other settings may be set too high and are overdriving the unit.
If all else fails try the old unplug it for a while and then plug back to see if that helps.
What if anything else is hooked up at the same time to this system?
Jun 14, 2012 | RCA RT2770 Theater System
I just bought a Coby home theater system 5.1 surround sound dvd/cd/ player model#765. I've got it all hooked up but I have one problem, when I want to listen to my tv stations through the home theater...
Hi - Your Home Theater System and your TV should have separate volume controls. You should be able to control each individually. Start by checking the volume level on your TV with your HTS shut-off. Turn the volume on your TV all the way down to 0.
Next, turn your HTS on and check the volume level there. Is it still loud? If so, try turning the volume down on your HTS. That should do the trick. If its not loud then you know you can control the volume on either the HTS or the TV. If this answer does not help, then please write us back with a little more detail. Thanks.
Feb 28, 2011 | Audio Players & Recorders
No home theater sound
Protect mode will kick in whenever a fault is detected.
You get the unit not powering up, and sometimes you hear a clicking noise, that is the protection switch that keeps shutting down the unit.
Causes that can start protect mode are:
Electrostatic harges on internal circuits.
Leave the unit unplugged for power for one hour or so, this will allow discharge.
Bad speaker wiring.
Check speaker wiring, try unplugging and plugging back, or start after removing one speaker at the time.
Internal fault.
Internal fault is the natural cause for protect mode. If all the above did not work, then the problem is a blown component or an internal fault. In this case the unit must be taken apart , tested and repaired by an experienced person.
If the unit is less than one year old, or if you want to get service, call Sony at the phone number listed on the product documentation.
Regards.
Mar 07, 2009 | Denon AVR-4800 Receiver
Samsung 5-Disc 1200-Watt Home Theater Surround Sound System My Home Theatre System is keeps shutting down by its self. before it shuts down the screen says protection mode and then shuts down. i have...
If the unit shuts down almost immediately without sound, you have an electronic failure of the audio amplifier.
However if you must play the unit up above quiet background levels, you likely have a shorted speaker wire. With home theater systems, you have the luxury of trying different surround modes and speaker level settings. It's not unusual, for example, to have a loose wire strand going to the center speaker. In stereo, the system works fine. As soon as you switch to a surround mode, the amplifier senses the short and shuts down to protect itself.
Check those wires really close - I bet you'll find it there.
May 15, 2008 | Audio Players & Recorders
Onkyo 805 zone 2 problem
I just figured out what I was doing wrong last night. On the 806 at least, when zone 2 is not powered (receiver is set to act) there is a separate volume control 'level' that is on the receiver a couple buttons right of the zone 2 button. By default this level appeared to be set to -50db. As soon as I turned up this level sound came out of my zone two.
Jan 02, 2008 | Onkyo TX-SR803 Receiver
Wiring with a sattelite receiver and new Samsung TV
Nope RamaTheMan - you are incorrect! No way to get an actual surroundsound from your TV on this turd - this came straight from the Samsung FAQ -
"You cannot get surround sound from your television. On the other hand, if your television has audio output jacks you can connect your TV or Set Top Box to your Home Theater System and get stereo sound (that is, sound from the left and right speakers of your Home Theater System only).
To connect your TV or STB audio output jacks to your Home Theater System and get stereo sound, follow these steps:
  1. Turn off your TV and Home Theater System.
  2. Connect the Audio Out jacks on your TV to the External Audio Input jacks on the back of your Home Theater System. The External Audio Input connectors are typically labeled AUX IN. Note: There are usually two pairs of Audio Input jacks, AUX 1 and AUX 2. Each pair has a jack for the left audio input and the right audio input. Often, there are two Video AUX IN jacks as well. You can plug the audio cables into either audio AUX 1 or AUX 2. See the following diagram.
  1. Turn on your TV and Home Theater System.
  2. Press the Function Button on the front panel of your Home Theater System until the display on your Home Theater System shows AUX 1 or AUX 2.
For advanced installation, if you are using a High Def STB, you can connect an OPTICAL connection from the STB to the HTS. This is a specified cable that must be purchased separately.
In either instance, you must then set the HTS to its auxiliary input. (i.e AUX 1, AUX 2, DIGITAL IN) in order to get the sound from the HTS.
Note: If your television does not have Audio Out jacks, you may be able to get stereo sound by attaching the Audio Out jacks on your VCR to either the AUX 1 or AUX 2 audio inputs on your Home Theater System. If you attach your VCR to AUX 1 or AUX 2, you will have to tune your television to channel 3 or 4, and then tune to the station you want to watch on your VCR."
Dec 26, 2007 | Samsung HT-X50 System
VOLUME CONTROL
Try to increase the speaker levels through setup. I had the same problem and I increased the speaker level from 0dB to +10dB, and seems like it is better now. Let me know how you make out.
Nov 29, 2007 | Onkyo HT-SR800 System
 Grubhead
Grubhead
