Question about OKI C9300 Led Printer
My oki transfer belt is saying that it has run its course despite it has just been installed ( new)
  • bigdogmi Nov 26, 2007
    We have the same problem. I called a local office machine repair company and they claim it is a full waste toner bottle.
    I, however, can not find any manuals or diagrams showing where this is and I can't seem to locate one, easily, with a cursory look inside. As it is not good to expose to the light for long, I would like to know ahead of time where I'm looking for a waste toner bottle.
    Any help with junior's and my problem would be greatly appreciated. If anyone knows where the waste toner bottle on a C9300 is located at that would be great too.
    Problem Solver:
  • 5 Answers
The waste toner bottle is on the underside of the transfere belt. Becareful when you unclip as it can break. Another option is to drill a small hole on the back to empty the toner and then seal it up again. You do this at your own risk so becareful!
Posted on Jun 26, 2008
Where does oki c9500 waste toner box located
Your printer does not have a waste toner bottle. Waste toner is stored within the transfer belt. When full it will give you an error indicating its time for a new transfer belt.
Jul 08, 2017 | OKI Office Equipment & Supplies
Can I reset the belt
How to reset your OKI C3300 C3400 C3600 laser printers ...
? 2:40
Oct 6, 2014 - Uploaded by Toner Man
How to reset your OKI C3300 C3400 C3600 laser printers drum unit ... drum message you can install the chip on your drum unit and continue printing. ... Replacing the Transfer Belt on an OkiC3000 Series Printer - Duration: ...
Nov 26, 2015 | OKI C3400n Laser Printer
My Oki C5800 says "Replace Belt, 355: Belt Life" but I was told I could reset it without changing it if it was still good. How?
requires a fuse that sits underneath the transfer belt. However the belt itself would be full of waste toner that would need to be emptied
Jun 30, 2010 | OKI C5800Ldn Led Printer
Oki C5500 printer keeps jamming
Open the tray and find yout imput roller. You can remove this roller and put it back on the other side. Normally this is caused because it is worn. The inside of the roller is like a new one.
Jan 11, 2010 | OKI C5500n Printer
Is it easy to change the belt on an OKI C5400 printer?
Do you mean the image transfer belt? If yes, then it is easy. Instructions are in with the new belt.
Dec 30, 2009 | OKI C5400 Laser Printer
How do you rest an OKI c3530 image drum
Turn off the printer
Turn the printer on whilst holding down Menu button. (Display says user maintenance.)
Press the menu button three times. (The display will say drum counter reset.)
Press enter key. The system should go back on line, if not press on-line key.
You can just put a new fuse on the drum.
When you insert the drum the machine resets the counter and then blows the fuse. So if the unit is ok and you just wish to run it through another cycle just change the fuse.
This means you cannot just put a full unit in from another machine as it will not reset the counter until you put a new fuse in it as you found out.
This applies to drums transfer belt etc.
Note with regard to refilling the toner, some printers have 2 sections. 1 where you put the fresh toner and an after collection section in the same unit. You must empty the 2nd section if you refill it more than 2 or 3 times
Oct 07, 2009 | OKI C3400n Laser Printer
Order belt
Assuming you rprinter says Order Transfer belt on the disply you will need to order then replace the transfer belt, part number 42158711.
Open the top cover, remove the cartridges, unlock the belt unit using the blue levers then fit the new belt
Jul 06, 2009 | OKI C5500n Printer
Fatal error 917 on an Oki C9600 printer. What does this mean and how can I resolve the problem. Many thanks James
A fatal error 917 means there is a problem regarding the belt **** sensor.
Usually it means the printer can't see the transfer belt rotating.
First thing to try is to remove and re install the transfer belt, if that does not work you should replace the transfer belt.
Jan 07, 2009 | OKI C9600hdn Laser Printer
Transfer belt for the oki 9300 led printer
Swith off the machine before installing new units. Also check for toner dust on pins and also check to see if the pins are not bent. You can also try leaving the machine switched off for about an hour unplugged from the mains.
Nov 24, 2007 | OKI C9300 Led Printer
OKI 9800 with "342" error code
problem might be with toner recycle coil which runs around the back of the belt unit. as the cyan unit is the furthest down the line if any blockages occur it can back up and lift the drum unit up. check the square opening of the recycle unit on the cyan end. Make sure you change waste toner unit when prompted or you might break a gear (big job) Karl Oki engineer
Aug 24, 2007 | OKI 9800hdn Laser Printer
OKI C9300 Led Printer Logo
188 people viewed this question
Top OKI Office Equipment & Supplies Experts
Level 1 Expert
Don  Farrell
Don Farrell
mukhtar21 shaikh
mukhtar21 shaikh
Are you an OKI Office Equipment and Supply Expert? Answer questions, earn points and help others
