Question about Cell Phones
I was curious and i pressed nam2 on my metropcs settings . and i have my phone on lock when it powers up . now i have no clue what the code is and well I NEAD HELP! Im on vacation and they have no store here so i have to wait til i get back home . Any suggestions that i can do to get it working faster ?
If you have locked yourself out of your samsung cell phonedue to switching to nam2 with the lock on powerup option on, here isyour solution. open the back of your cell phone. there should be ahexidecimal number printed on there(behind the battery) it will be abunch of letters and numbers. its the last number printed. meaning it'son the bottom. open up your windows calculator. you know the one youwould use to help you with math. go to settings or view and switch toscientific. after that make sure you check the little circle that says"hex" after you have imput the number switch the calculator to "dec"for the decimal conversion of the number you have just put in. the lastfour of this number will be your password for your phone. i swear thisworks on any samsung phone. i locked myself out of my 740. it workstrust me if you don't believe me here is the website i got the infoit's the samsung tech support page
http://www.samsung.com/us/support/f...ias%20(SCH-u740)
Posted on Jul 31, 2009
  • krissbby7 Nov 01, 2010
    but i entered the wrong password into my phone too many times and it wont let me enter another one in anymore! what do i do now?!?!?!??
I have a samsung reality. i was fooling around with the settings & set it to NAM2. it's now locked i need a 4 digit code. i've tried all the online suggestions nothing works. i've been up for 4 hours...
Using the default "last four digits" unlock code will not work because switching to NAM2 changes your phone number, and hence changes the default unlock code. You have to find out your new phone number (and new unlock code) under NAM2. Do this:
  • Get to the dialer screen.
  • Dial #43574357* (#helphelp*)
  • Tap "1. system info"
  • The top two entries, MIN and MDN are your new number. Usually they are invalid phone numbers (000-000-????) but the last four digits are your unlock code. Write them down or remember them.
  • Get back to the unlock screen, type in the code.
  • Go directly into the menu and change back to NAM1
  • Don't do that again. :)
Sep 17, 2010 | Cell Phones
Switched to NAM2 and do not know the lock code.
Dial *22899 and press SEND to program the phone.
after it has finished downloading the programming information, the phone will reset.
The Lock code will now be set to the last 4 digits of your phone number.
when you have finished, be sure to switch back to NAM1 and dial *22899 again to re-program it.
Sep 30, 2009 | Samsung SCH-u740 Cellular Phone
Can't unlock Samsung Hue?
samsung hue r500 and having problem when accidentally or curiously selected nam2.. after it powers off then on again by itself, it brings u to a little window (initial programming needed) and the enter code (password). as you will notice none of your 4 digit passwords will work, default wont work, u have to push the back or end call button to get away from the enter code window. enter ##626# and hit send button. it will bring u to option to select nam1 or nam2, select nam1.. go to next screen, enter in the sdc code which is 000000, (6 zeros), enter or next screen, make sure that mid is same as ur cell number, go to next screen, it will show ur number again, next screen, will be sid and nid numbers... they are what they should be, go next screen, then i think there is option to be done, view, edit choose done, next screen then it will program by itself. powering on then off, bringing u back to same screen with the same window of initial programming needed, just go to enter code, and enter the last 4 of your cell number, and it will let u through,.. just remember to go back in to your phone options menu and change the nam setting in there back to nam1 also. then it will power off and on again. program should be complete... you can always also dial *228 and option 2 to reprogram your phone again to make sure.
hahah
May 08, 2009 | Samsung Hue (SCH-r500) Cellular Phone
Locked and cant get in
try the last 4 digits or ur number orr! 0000
Apr 14, 2009 | Samsung Hue (SCH-r500) Cellular Phone
I have a Samsung U520 and I accidentally activated NAM2. Now my phone does not work. When I try to deactivate NAM2 it asks for a password. Can you help? It needs a 4 digit code. It also states Initial...
hi sir have you done restore factory settings firstThe Nokia 2160 series hand portable CMT uses an EEPROM NAM that can be programmed directly from the standard user keypad. In order to access the
NAM, you must enter the special access code currently programmed into the
phone. Once the programming mode is accessed, NAM parameters are loaded
by entering them into the display and "storing" them to selected memory
locations. Be sure to obtain all parameters before proceeding.
EASY NAM PROGRAMMING
1. Turn on phone.
2. Enter the Easy NAM access code. Access code is: *#639#
3. Verify the display now reads "Cellular Number" and enter the 10 digit
MIN for the phone.
4. Press the softkey under the word "OK" in the display. If less than 10
digits are entered an error message will prompt you to reenter the
number.
5. Verify the display reads "Enter code" and enter the five digit SID
followed by four zeros. (Example 001750000 is a SID of 175 followed
by four zeros). An error message will display if an incorrect entry
is made. Do not add more than four zeros to the code.
Note: Change the Lock code by adding a pound sign and new lock code after
the code. (Example: 001750000#7788. Lock code = 7788).
Change the Language code by adding a pound sign (#) and new
language code after the code. (Example: 001750000#2. Language = 2)
Language Code: 0 (default) = English, 1 = French, 2 = Spanish,
3 = Portuguese
Change the Lock code and Language code by separating each set of
numbers by a pound sign. (Example: 001750000#7788#2). The SID =
00175, Lock code = 7788, Language = 2 (Spanish).
6. Press the softkey under the word "OK" in the display.
7. The display will tell you t
Sep 10, 2008 | Samsung Cell Phones
Cant unlock my phone
If you know your original lock code, take it in to your service provider, each code is diffrent and can only be programed manually, if you dont know your original lock code you will have to sacrific all info pics,mess,numbers, etc. by a reset... I can guide you through the steps to erase all if you lost your Unlock code, or switch back to nam1 if you know your lock code, ( when you switch back, if security is on automatic lock, password is required) intial programing code is not your Unlock code.
Apr 03, 2008 | Samsung SPH-M500 Cellular Phone
Cell Phones Logo
1,775 people viewed this question
Top Cell Phones Experts
Computer Repairing
Computer Repairing
William Alequin
Are you a Cell Phone Expert? Answer questions, earn points and help others
