Question about Palm TX Handheld
Error (sys 0505)(0,841) - Palm TX Handheld
  • Palm Expert
  • 346 Answers
I entered "Sys 0505" in the Search box on the main Palm support site and got a bunch of hits, one of which is a Palm Knowledge Base article which would suggest that the error might be related to a file (these hits suggest a backlight file though the last four digits of the error are different) which might have gotten onto your TX if you upgraded from an older Palm.
http://tinyurl.com/2vwqq4
http://tinyurl.com/2rq73o
Hope this helps. If it's not the backlight file, it could be some other relic system file from an older Palm. You might have to try Hard Resetting your TX, renaming the Backup folder on your desktop, then Hotsyncing your regular PIM data back and reinstalling your third-party apps one at a time. This routine is the customary way to try to troubleshoot a software problem, which is prolly what you have. Now, if you have never had a prior Palm handheld and there's no way it could be a legacy system file from a prior device...I dunno...I would still suggest going the Hard Reset route, renaming your backup folder to backupold, Hotsyncing your data, make sure it's all working, then reinstall your 3rd party applications.
Posted on Aug 20, 2009
5 Suggested Answers
SOURCE: HotSync error ((sys 0505) (0,841)
Thanks a lot for the tip. I just deleted the mypalm application and the error message stopped!
Posted on Aug 27, 2008
Joed911
  • 4338 Answers
SOURCE: Still getting error (sys 0505) 0, 841 on Palm TX
Try a hard reset and wiping it out. Then resync it with the newest Palm Desktop manager 6.2
If I could be of further assistance, let me know. If this helps or solves the issue, please rate it.
Thanks, Joe
Posted on Jul 27, 2009
gemmy23
  • 346 Answers
SOURCE: when trying to sync, error message reads (sys
Try to perform a System Reset (see article linked below). If it works to break the loop, you should then be able to delete the offending "My Palm" software and perform a Hotsync to backup your data to your desktop.
If that doesn't break the loop, you'll have to perform another Hard Reset. Sometimes, a Hard Reset takes a couple of tries to get it right, since it's easier to do it wrong than to do it right.
This article discusses the various types of Reset for different Palm devices:
http://tinyurl.com/zlwza
Until you break the TX out of its loop, you won't be able to get the data from it.
To see the Palm OS version running on your TX, enter the Menu, select Info, then Version.
To Get Out Of A Loop:
  1. Perform a SYSTEM RESET by doing the following:
a) Press the UP Button
b) And THEN press and release the RESET Button
c) When you see the second Logo (Palm Powered) release the UP Button
d) Now check if your SYSTEM RESET worked by going to Beam Receive. If it goes back to Off even after you put it to On it means you were successful
2. Now Perform A SOFT RESET by pressing and releasing the button in the back once
  1. After a soft reset, a logo screen appears, followed shortly by a Preferences screen asking you to set time and date.
  1. If a soft reset does not break it out of the loop, you may need to try one of the other resets below.
  1. Do an INCOMPLETE HARD RESET by holding down the power (on/off) button on your device.
  1. While holding down the power button, Press and release the reset button on the back of your handheld device
  1. Keep the power button pressed and release it when the “Palm Powered” logo appears.
  1. A message will now appear warning that you are about to “Erase All Data”. And this will happen if you press UP or DOWN.
  1. Instead you press left or right to begin a soft reset, leaving your data intact.
  1. Your device will then take you through a series of screens to calibrate the digitizer and verify the time and date.
Sorry this was so long, I tried to put everything down that might help you.
Posted on Aug 03, 2009
Consultapro
  • 23 Answers
SOURCE: I get an (Sys 0505)(0,841) Error when I try to Hot Sync or go to
Try Uninstalling and reinstalling DocsToGO
Posted on Oct 06, 2009
Toshiba 3500c cA90 error code
[CA90] indicates Image data transmission error of sys board.
Check the harness between the PLG board and SYS board open-circuited or the connector dis-
connected?
If the harness is ok, then probably is the PLG board & SYS board issue.
Feb 24, 2013 | Toshiba Office Equipment & Supplies
How to fix error 651 on windows 7
Error 651 is a well-known bug in Windows 7 which happen when you try to connect to the Internet using PPPoE connection. If you're one of the victims who met this bug, you should see the following error message: Error 651: The Modem (or other connecting device) has reported an error. These connections, however, would work just fine in Windows XP or Windows Vista PCs. Below are a few solutions that can perhaps fix the problem:
Windows 7 Fix: Error 651 Modem PPPoE Broadband Internet Connection
Fix 1: - Error 651 Modem PPPoE Broadband Internet Connection
Click here to download Registry Easy to automatically fix your PC errors and speed up your system.
Fix 2: - Error 651 Modem PPPoE Broadband Internet Connection
The root of the problem is believed to be caused by the RAS PPPoE file raspppoe.sys found in the folder C:\Windows\System32\Drivers. To fix this problem, we will have to replace the file raspppoe.sys with a new one. Try to copy the file from your friend's computer which has Windows 7 installed. Alternatively, you can download the raspppoe.sys file from this site (thanks to the author). After you get the file, before pasting it into C:\Windows\System32\Drivers, be sure that you rename the original file to something like raspppoe_ori.sys, so that if something weird happen you have a backup of your original file. Paste the new raspppoe.sys into the directory after you've renamed the original file. Try to connect your modem and it should work fine now.
Feb 21, 2013 | Computers & Internet
Gateway dx4720-03 error 651 can't connect to internet
hello,
This error"Error 651" is caused by this file raspppoe.sys you can find it in c:/windows/system32/drivers/ rename it(raspppoe_something.sys) and copy the new file from a friend pc that runs vista .
Jun 10, 2012 | Gateway Computers & Internet
F10 error after getting moved
the error is communication error between system cpu and scanner cpu
check the following
(1)check the harness connecting the sys board and the slg board is disconnected or open circuited
(2)check the version of the system rom on the sys board
(3)check the version of the scanner rom version on the slg board
(4)replace the sys board
(5)replace the slg board
but first try doing the latest version of firmware
Mar 14, 2011 | Toshiba e-Studio 35 Copier
Fix error 651 on windows 7
In windows 7, when you try to connect using your PPPoE connections, you may be faced with the following error: Error 651: The Modem (or other connecting device) has reported an error.
These connections would work just fine with Windows XP or Windows Vista PCs.
Again, you are not alone, this seems to be a known bug in Windows 7 that is being worked at. However, you can workaround this problem.
The RAS PPPoE driver file "raspppoe.sys" found under c:windowssystem32drivers folder seems to be the root cause of the problem. Fortunately, we can workaround the problem simply by renaming the original raspppoe.sys file to something like "raspppoe_orig.sys" copying a working file from a Windows Vista system. If you do not have access to a Windows Vista system. click here to download raspppoe.sys file (unzip). This should help!
Jan 01, 2011 | Computers & Internet
Wireless not working pc told me error 651
The RAS PPPoE driver file "raspppoe.sys" found under c:windowssystem32drivers folder seems to be the root cause of the problem. Fortunately, we can workaround the problem simply by renaming the original raspppoe.sys file to something like "raspppoe_orig.sys" copying a working file from a Windows Vista system . If you do not have access to a Windows Vista system. click here to download raspppoe.sys file (unzip)
DO VOTE ME
Dec 07, 2010 | Computers & Internet
Memory file dump error, pc freezes
This is the issue with your RAM chip or Operating System .Pls replace the RAM chip with goods one and on the system .If still problem not resolved pls re-install the Operating System again.
Nov 17, 2009 | E-Machines eMachines Desktop PC
Error message: HD521-2W
this error is basically a fatal error. you will endd up needing to replace your hard drive soon but if you dont like doing a recovery every few days and loosing your information all the time replace the hard drive
Mar 30, 2008 | Samsung SpinPoint P80 SP1604N 160 GB Hard...
Palm TX Handheld Logo
132 people viewed this question
Top Palm Computers & Internet Experts
Michael Vincent Cruz
ray gallant
Raj Patel
Are you a Palm Computer and Internet Expert? Answer questions, earn points and help others
