Question about Lavazza Espresso Point Capsule Machine
Machine is on and the red light next to the coffee cup in the upper left corner is blinking.....machine will perform no functions.
    Problem Solver:
  • 19 Answers
Contact me at www.lavazzarepair.com
Posted on Oct 13, 2009
Keurig troubleshooting
Is there water in it? There probably is so the next thing to try is to lift the tray and close it again after the machine is ready to brew. This resets the brewing function. Good luck.
Aug 07, 2014 | Keurig K10 Personal Coffee Maker w/ 30...
Saeco Eclipse stopped functioning
Have you solve your problem with Odea. Mine is new out of the box and not working at all. Red light blinking, manually prime it and so far only tree cups of coffee. After priming it the green light was solid and could make 3 cups then stopped. Any advise greatly appreciated.
Dec 12, 2011 | Saeco Odea Go
Machine stopped working and both buttons are flickering, if I push the left (small coffee) button then the machine starts to pump cold water. If I push the left (large coffee) button nothing happens. Not...
May be busted, but before you take it to the shop try these few things. 1. Unplug machine for 30 seconds 2. Then plug back in, (lights should still be blinking) Take silver handle that you lift when you put in coffee pods and gently push back handle as far as you can for 3 seconds. This should reset your machine,back to factory settings. To then reset coffee cup settings to your personal taste by: 3. You can adjust the fill of coffee by holding the large coffee cup down for as long as you want to fill it. Try holding the button down for 20secs., next cup of coffee should automatically fill for 20 seconds. Do the same for small coffee side. Hope this works,it has for me; just not sure because of the cold water pumping out issue. good luck
Nov 11, 2010 | Nespresso Essenza C100 Espresso...
Brew cup stuck unable to get out
If you open the door and take a flashlight, light in the front/middle of the brewing unit. You will see a little screw, take a screwdriver and loosen it, bend little on the little plastic above where the screw was and pull out the brewing unit.
When you have the brewing unit out then you need to reset the machine and brewing unit.
To reset the machine you have to turn off your machine, open the door.
Look in the down left corner, you will see a hole, look in the middle of the machin you see another hole and in the upper right corner.
put a screwdriver or similarly in the left corner and in the middle of the machine, turn on the machine and put another screwdriver in the upper right corner. hold it in place to the machine not get any noise more.
To reset the brewing unit, first put the plastic back again (that one you loosen with the screw first).
If you look back on the backsida of the brewing unit, in the middle you will see a plastic that looks lika a handle, force it down and you will see all the other parts will move around little. Turn it to you can see the little mark on the front goes to the N mark.
Best regards
/Mirran
Jan 29, 2009 | Saeco Vienna De Luxe Espresso Machine
Selftest sign
Try to make a cup of water(tea), press the button for water.
On the old Royal Cappuccino that are the button on the right down corner and the new machine had it on the upper right corner.
Hope this will help you.
/Mirran
Aug 16, 2008 | Saeco Royal Cappuccino Espresso Machine
Saeco Easy
Press the button in the upper right corner. When the light flashes, release the button.
Make sure the brewing unit, dregsbox and driptray is in position.
Try to open the steam knob and make a cup of water.
/Mirran
Aug 07, 2008 | Saeco Easy Espresso Machine
Blinking light
SCALE REMOVAL
The scale contained in the water, over time, will
cause plugging up of some elements in the appliance
and will thereby compromise its correct functioning.
The result will be that more time is
required to make coffee. The formation of scale
depends on the hardness of the water and on how
much the coffee maker has been used. To achieve
the best performance, descaling must be carried
out every so often. The coffee maker has a built-in
system that counts the number of cups of coffee
that have been made. The ON DRIP pilot light will
begin to blink when it is time to carry out descaling.
To do so, proceed as follows:
• remove the anti-chlorine filter (if present) and the
permanent filter from the coffee maker (so as not
to bathe them with vinegar)
• Dissolve 2 dessert spoons (about 30 grams) of
citric acid (available in pharmacies) in the
water;
• Place the container on the heating plate;
• Press the DRIP/AUTO button twice, allow
the equivalent of two cups to percolate and then
turn off the appliance;
• Allow the solution to sit for an hour;
• Turn the appliance back on and allow the rest of
the solution to percolate;
• Rinse by allowing the coffee maker to operate
with only water at least three times (1 full container
each time).
• Press the PROG and DRIP/AUTO buttons
simultaneously to reset the counter to zero.
IMPORTANT: if the machine is left unconnected to
the electrical mains for over two months, before
using it again it is necessary to carry out the
process of scale removal as described in the preceding
section.
10
Aug 27, 2007 | DeLonghi BAR 6
Lavazza Espresso Point Capsule Machine Logo
426 people viewed this question
Top Lavazza Coffee Makers & Espresso Machines Experts
ray gallant
nikolay nikolov
Tom Chichester
Are you a Lavazza Coffee Maker and Espresso Machine Expert? Answer questions, earn points and help others
