Question about Gateway GT5242E PC Desktop
Blue power light does not come on when i turn the comp on
When i turn on the computer, the blue light doesnt come on. both cd drives the power supply and the processer fan comes on but nothing else. the moniter mouse and keyboard are all dead.
  • ocdnekutta Jul 31, 2009
    its not the power supply, its a new one in it now, 600 watt. i tried another one before i posted the problem. i did hope that was the problem. any other ideas? im stuck. i think its either the processer or the mobo, but i dont know how to figure out which one it is.
    its not the power supply, i checked it first. its either the cpu or the motherboard i just dont know how to figure out which one it is. any ideas on how to tell?
There is either a motherboard/cpu issue (worst case), or a power supply issue (best case, cheap and easy fix)...
without being there looking at it i can't really tell you more. if you happen to have a spare ATX power supply, open the machine and plug it in to the system instead of the old one to see what happens.
if you don't have a spare, you obviously have another working computer you're posting from so maybe borrow it's power supply and see what happens.
Posted on Jul 31, 2009
Hi, I have two cd drives that originally came with the Dell dimensions 3000 PC home edition I own, I've had them for a while, but recently my cd drive has ceased to work, the computer doesnt acknowledge...
The best bet and I have had several customers bring systems in with this problem is you have to edit the registry file and get rid of the upper and lower registry values once you do this save and reboot the machine it is just like a new drive was installed worked on all of theres one however came back to me twice and it turned out it was a conflict with other installed hardware. Hope this helps If you simply go to google.com and type clear upper lower registry values and the name and model of you drive as above it usually gives you a step by step and happy computing. Check us out on the web @ http://www.davispcrepair.com or contact me personally @ kzthomas@davispcrepair.com
Jan 14, 2010 | Dell Dimension 3000 PC Desktop
Cant comp to work,it's plugged in and when you go
Remove Any Docking Stations or Port Replicators From the Computer Note: Docking stations and port replicators are optional equipment. If you are unsure if you have a docking solution attached to your computer, refer to Table 1 and Table 2 for examples. To remove the docking station or port replicator, perform the following steps: Shut down the computer. Remove the docking station: Universal Docking Stations: Disconnect the docking station's USB cable from the computer. D/Port or D/Dock: Remove any cable locks from the security slot on the right side of the docking station. Move the slide lock forward to the unlocked position. Press the Eject button and lift the computer from the docking station. C/Port II or C/Dock II: Remove any cable locks from the security slot on the left side of the docking station. Pull the locking lever forward until it stops to eject the computer, then slide the computer out of the docking station. Dell manufactures the following docking stations and port replicators (Table 1): D-series DocksC-series DocksSpecialty Docks D/PortLatitude? C/Port IIMedia Bases D/DockLatitude? C/Dock IIInspiron? Advanced Port Replicator Table 1: Dell Docking Stations (Click an image to enlarge it) Universal docking solutions are also available from third-party manufacturers including, but not limited to, the products below (Table 2): TargusKensingtonBelkin Table 2: Universal Docking Solutions (Click an image to enlarge it) Disconnect All Peripherals from the Computer Remove all external connections from the computer. This includes but is not limited to the following devices: docking station or advanced port replicator keyboard mouse speakers or microphone printers scanners USB or 1394 devices palm pilots zip drives secondary battery Plug the AC Power Adapter into the Laptop Computer Remove the battery from the computer. Connect the AC adapter directly to the computer Verify That the AC Power Adapter Has a Solid Green or Blue Light Verify the AC power adapter displays a solid green or blue light. Older Latitude? C Series laptop computer AC adapters may not have a light. The new E series power adapter indicator light is either a blue ring or a blue dot and is located at the tip, on the DC connector, not on the power brick itself (Figure 1). Figure 1: E Series Power Adapter Indicator Light Location Numbers reference image above: E Series Power Adapter Indicator - Blue Ring E Series Power Adapter Indicator - Blue Dot D series power adapters have a green lights located on the power brick (Figure2). Figure 2: D Series Powed Adapter Indicator Light Location Numbers reference image above: D Series Power Adapter Power Brick D Series Power Adapter Power Indicator Light Shut Down the System If the computer currently is turned ON, running on the battery, shut down the system: 1 Click Start. 2 Click Shutdown. 3 Choose Shutdown from the menu. 4 Click OK. 5 Allow the system to power off. Plug the AC Adapter into a Known-Good Wall Outlet Verify the wall outlet is known-good by testing it with another device, such as a lamp. Confirm there are no power strips, surge protectors, or uninterruptible power supplies (UPS devices) connected to the power cable. UPS devices provide temporary power for a computer when there is no electricity available from the wall socket, such as during a power outage. Plug the power cable into the known-good wall outlet. Power up the system. Replace the MiniPCI Door, Rubber Feet, and System Motherboard
Nov 07, 2009 | Dell Inspiron 1150 Latitude D600 14.1 LCD...
PC fans turn on but it doesnt do anything else
HI. check the hard drive pin plug that connects to the main power supply unit. make sure it is connected properly. if the connections are correct, this will confirm that the motherboard has failed.
Oct 03, 2009 | Computers & Internet
GT5034 has power, blue light on power button, no beep, no boot, sounds like fan running hard. Hard drive light is on for a while and both CD drives green lights flicker. Nothing comes up on the monitor. HD...
powersource is good.motherboard might be the problem.harddrive can be tested by putting it in
another computer and see if it boot up.to test the mother board unhook the cd drives and harddrive.turn
on the computer and see if the gateway logo comes on.if it still does the the samething with everything unhooked
then it might be the bios.you might have to flash the bios and reinstall it.to do this i recommend you take it to a
shop.if the comp runs with everything still unpluged and stops then you know that you have a wrong
setting on the harddrive or cd drive.if you got two of anything make sure that you have a slave or master.if you nned me to
write a guide email me at gamecrazy944@yahoo.com or if you got anymore questions.
Jun 29, 2009 | Gateway GT5034 PC Desktop
SOLID AMBER LIGHT ON DIMENSION 3000
One of two things:
Either the power supply is marginal
or
the motherboard is bad.
Good luck.
Mar 09, 2009 | Dell Dimension 8400 PC Desktop
Cd drive
try to unplugged all the connection through the CD/DVD drive. and plug it again.. maybe this would work. sometimes this happin for faulty connection for ide cable and supply cable.
Sep 02, 2008 | Computers & Internet
Compaq presario evo 1015v
sounds like a bad screen this might be able to be remedied by hooking the laptop straight to a computer monitor threw the ports provided in the back
also you could have bumped something loose inside like a video card if any cards or memmory comes loose this will give you black screen of death the laptop will have to opened and cards pressed down gently
theres the solution of your power supply on the laptop went out and you need a replacement
if power supply went out it doesnt hurt your comp it just makes it hard to run
May 21, 2008 | Compaq Presario 900 /1500 Series EVO...
System won't boot
Better you try with a bootable CD, if that works then check for your Hard Disk it might got faulty or crashed.
Feb 04, 2008 | Dell Dimension 4600 PC Desktop
Emachines problem... PSU works but comp doesnt turn on
Hi, Did you just add the second CD? If you did you may need the driver for the mother board? Make sure the power cord for the cd has voltage plug it into the DVD drive also check the cable make sure red stripe is on the correct side of drive. You can download the driver at http://www.emachines.com/support/product_support.html?cat=Desktops&subcat=T-Series&model=T2672 User guide is there as well. The start button has a pair of wires with a small pin connector on it. This will connect to the motherboard if there is a 3 pin set you might try moving to the other pin. The new power supply also has to provide a start voltage? Your power supply may not be compatible or it may put the voltage on the third pin.
Aug 22, 2007 | E-Machines eMachines Desktop PC
She won't run
do you still have your restore CD? try to fresh restore it and updates everything on that unit again. Often online gamers send you malicious script that crashes your system.
Aug 04, 2007 | Gateway GT4022 PC Desktop
Gateway GT5242E PC Desktop Logo
251 people viewed this question
Top Gateway Computers & Internet Experts
Prashant M
Prashant M
Matthew Spark
Matthew Spark
Are you a Gateway Computer and Internet Expert? Answer questions, earn points and help others
