Question about Candy CDC266 Dryer
No heat!!!!! just got his from a friend who has bought a bigger one, the filter light stays on and it spins but it does not get hot. I have left it on for 30 mins but no heat at all, it doesn't have a cut off switch, just a high and low button, and dial. I am in the uk. is it easy to replace the thermostat? any help wanted. jen
Re: No heat!!!!!
Have same problem /light goes of when in cool cycle.
i think its the printed circuit panel at top of dryer
have ordered one for £9.30 plus postage
hope it works
clean filter out and condenser element
Posted on Dec 12, 2007
0 characters
3 Points
Dryer heats, tumbles but does not dry. Exhaust has heat.
perhaps the washer is not spinning all of it out therefore making it hard for dryer
Aug 31, 2015 | Dryers
Why wont my dryer stay running?
Good Morning Friend,
I understand that your Frigidaire dryer, model# FEQ1442ES, will not stay running. Please check to make sure the door is staying closed. If the door is opening in mid-cycle, then the dryer will stop running. Also, make sure the plug is in the socket tightly. Your dryer could be shaking the plug loose, which could possibly be causing it to stop running. I ask that you please follow up with a comment on the post, at your convenience, to advise if further troubleshooting is needed or if your appliances status has changed successfully. Hope this is helpful.
-Best Regards-
Jun 17, 2014 | Frigidaire FEQ1442ES Electric Dryer
No heat from dryer
If a Gas dryer look first to see if igniter is coming on or if drum where clothes are gets hot or not.
Dec 10, 2012 | Dryers
Kitchen aid dryer / heat flame not staying on after 20 secs
Sounds like your gas valve is fine, if it comes on at all, its good. A air flow restriction would cause a overheat condition and shut down the burner. Once it cools back down the burner would re-ignite and repeat the cycle. The sensor on the left of the burner is the flame sensor and the flame wouldn't come on at all if it was bad. You've already changed the coil kit so the valve is fine, disconnect the vent from the back of the dryer and see if the problem goes away. If the problem stays, I would suspect the thermostat. Good luck.
Mar 16, 2010 | KitchenAid Dryers
Dryer gets hot and spins won't dry cloths
clean exhaust vent ASAP it could start a fire if the heat has nowhere to go out the moisture stays inside and your heat element will cycle on and off on a high temp limit swich
Apr 01, 2009 | Kenmore 73952 Gas Dryer
Dryer taking double the time to dry.....
I have had the same problem with my dryer for about 2 months. I bought a heater kit upgrade on eBay, , and installed it myself this past weekend. Easy to install for a do-it-yourselfer. About 6 screws to remove, lay the dryer on the back and its all right in front of you. Dryer is working like it is new again.
Jan 30, 2009 | Fisher and Paykel DEGX1 Electric Dryer
Empty water button staying on
Remove lower left filter from dryer, and wash it out under running water. Reach inside the compartment and clean any fluff and gunge you can find there.
Get a plastic bag tie or similar, and feel for and locate a small hole at the rear of compartment, poke it clear with bag tie.
If you are certain that the element and stats are o/k , and it still does not heat and the light stays on, then that indicates that the float switch is stuck or is faulty.
To access this involves stripping the dryer down, not an easy job.
Plz rate my solution.
Jan 10, 2009 | Bosch Axxis WTA 4107 Electric Dryer
Empty water light stays on
Remove lower left filter,and washout under running water, reach into the opening and clear out all fluff and gunge, get a plastic bag tie or similar, and feel for and locate small hole at rear of compartment and poke clear with plastic
Make sure the air vents are clear back and front and try again, if still showing light then probably the float switch is sticking or faulty, this involves a complete strip down of dryer to fix.
Jan 04, 2009 | Hotpoint TDC32 Electric Dryer
Indesit dryer IS70CS
sounds like the heating element or thermostat has gone in the dryer these parts can be bought from or
Aug 02, 2008 | Zanussi TC180W Electric Portable Dryer
No hot air
If you have a pilot light (small flame) you can try to re-light it by turning the knob on the gas valve to the pilot position and pushing the knob down while lighting the pilot, you may have to hold the knob down for up to 30 seconds before releasing it. The pilot should stay lit and then turn the knob to the on position. If the pilot will not stay lit or the main burner will not light it could be the gas valve or the temperature sensor.
Jun 11, 2008 | Dryers
Candy CDC266 Dryer Logo
188 people viewed this question
Top Candy Dryers Experts
Gerry Harvey
Gerry Harvey
Eddie Dalton
Eddie Dalton
Level 1 Expert
Are you a Candy Dryer Expert? Answer questions, earn points and help others
