Question about U-Line Icemaker
Takes long time to make ice then stops - U-Line Icemaker
  • 286 Answers
What is the model number of your unit? Some of the icemaker is designed to harvest when the thermostat is cycles. So every 1/2 hr on some and longer on others. If you have a BI series then make sure the thermostat is set to a warmer temperature. That way the thermostat will be satisfied.(counterclockwise). Listen for the compressor to cycle off. When that happens then the icemaker should harvest. If not then the thermostat could be bad. If its a different model then Let me know and I can try to help you thru that.
Posted on Jul 31, 2009
Water dispenser takes a long time to shut off.
Sounds like the water valve needs to be replaced. If you move your cup and it continues to pour out water valve is, leaking through
May 27, 2015 | Scotsman MDT5N40W-1J Touchfree Water...
PFSF5RKZC Icemaker stopped making ice.
Most of the time is the ice maker itself that is defective. inside ice maker is an small circuit board that freezes up, if you take ice maker out and leave it overnight out to melt any ice inside the board it may work after that.
Apr 03, 2014 | GE Refrigerators
Makes ice for 3 cycles then stops running.Can turn off then on again to make more ice for a couple more cycles.
check the cycle time for a batch of ice. should take around 15 minutes to freeze and then you will hear the harvest cycle kick in. If the harvest cycle takes 3 minutes or more that is your problem. You will need to get a hold of NICKEL SAFE ICE MACHINE CLEANER. DO NOT use CLR or any kind of cleaner other than NICKEL SAFE ICE MACHINE CLEANER. If the ice doesn't fall off of the plate in about 90 seconds either the plate is dirty or the nickel plating has come off. There is a failsafe shut down if the unit takes more than 60 minutes to freeze or more than 3 minutes to harvest 3 consecutive times. The cleaning instructions should be inside of one of the covers. If not it's available online.
Aug 15, 2013 | Manitowoc QY-0214A Self Contained Ice...
Hi have a rs21dcns samsung can any one tell me how long it take to produce ice cubes fo the first time as the manual is not clear about this, and is there any tips i should know thanks
The first time should be on the average of 20-25 minutes. If your samsung is taking longer than 30 minutes, it indicates there is a problem. Fiscally look in the ice tray and verify the water is in there. If not, check and make sure the water line to the unit is connected and the water is supplied to the line. If the water is in the ice tray, then make sure your fill lever is in the down position. This lever is designed to stop making ice when the ice bin is full. If the lever is up, it will stop making ice.
Jun 26, 2011 | Samsung RS2630SH Side by Side Refrigerator
Model #ed5ftgxkq01 ice maker stopped working
Hi
Looks like your fridge is not very old. Common problem is a clog inside the ice maker. It's a pain to do, probably easyer to get it fixed unless you have a long time to wait for a service call or live in an area without service. Anyway clog is most likely about an inch from the in take line inside the ice maker.
Take out the ice maker or turn off the freezer untill it thaw's then use a tooth pick or THIN ice pick to push the clog through to the actual freezing tray, wash out the tray and re start the ice maker.
Hope this helps.......
Aug 01, 2010 | Whirlpool Refrigerators
Ice maker not working
For the missing arm you should contact the company via your dealer. The water pipe must be clogged with ice and dirt preventing water to flow to the ice maker. If you have real patience, you can fix it but might take some time. Take some warm water and pour it slowly through the pipe in the opposite direction of water flow. The warmness of water will melt the ice and clear of the dirt. Sometimes it may take hours, but the time taken depends on the amount of ice in the pipe. Since this is a matter of just 2 months, i assume it won't take much time.
Jul 05, 2010 | Amana ABB1927DE Bottom Freezer...
Ice maker frosting up inside where door and maker meet. Takes about 2 weeks to frost up after I take it out and remove the build up. Makes ice fine. Will get so bad it stops dispensing ice. Ideas?
Your ice door is probably not shutting all the way.
There is a solenoid that operates the door that could have stopped working. Can you hear it?
The hinge on the door could be broken or the bracket it goes in could be broken. You'll have to look to see what's wrong.
Remove the dispenser cover by gently prying starting at the bottom going round and round a little at a time to prevent from breaking it. When it's off the screws will be exposed to access the other components.
Mar 11, 2010 | Refrigerators
My LG refrigerator model#26945TT does not make ice anymore. Any thoughts what could be issue?
Check the following
  • timer, which is located at the rear side of the refrigerator
  • open the freezer casing and check the thermostat
Aug 07, 2009 | U-Line Refrigerator Ice Maker
Ice maker won't stop making ice
it's time to replace the ice maker, it will not stop, the you can feel the small bar when it looks in to the of position.
Dec 10, 2008 | Kenmore Elite 22.4 cu. ft. Bottom Freezer...
U-Line Icemaker Logo
102 people viewed this question
Top U-Line Kitchen Appliances - Others Experts
Dan Webster
Dan Webster
jasbo
jasbo
john h
Are you an U-Line Kitchen Appliances - Other Expert? Answer questions, earn points and help others
