Question about Goodman CLQ36AR49 Air Conditioner
My unit is not working right everytime I turn it on the lights inside flicker and it blows the breaker
    Renaissance:
    An user who is expert in 3 categories / brands.
  • 1,810 Answers
Sounds like the compressor or the fan is burnt out
or could be as simple as a start up reley
go out side and have the wife turn on the unit look inside and see what hapens if the fan works the it's the compressor or compressor start up capasitor
Posted on Jul 31, 2009
My stove up was about to blow up!! saw some blue lights flickering inside the stove!! please help
Find the 50 amp breaker and turn it off or pull out the bottom drawer and yank the cord out. Your bake element is probably shot. Arc welding itself to oblivion. Easy repair.
If you need further help, reach me via phone at https://www.6ya.com/expert/dan_73bbd84fe1d95b61
Oct 27, 2009 | Kitchen Ranges
Central Air- Breaker flips when AC is turned on
IT SOUNDS LIKE YOU HAVE A BAD COMPRESSOR OR A DEAD SHORT SOME WHERE IN THE UNIT
Aug 31, 2009 | Dometic Rooftop RV Air Conditioner
Fan runs but blowing hot air. Thunderstorm reset some breakers. I did reset the two breakers inside the house and one unit working fine, upstairs unit fan running but blowing warm air only. Box out
Sounds like your Capacitor is bad, or you had a wire burn off compressor terminal or capacitor. Way you can check capacitor is take cover off and see if looks swollen. Make sure to turn off power before taking panel off.
Apr 25, 2009 | Heating & Cooling
Fuse constantly blows in my car.
Did your radio only work with the tail lights on when the lights did work? There is definarely a short. If you can, get an automatic circuit breaker that fits in olace of the fuse. This is a trick I used when detecting shorts. The breaker will reset every few seconds and you won't have to keep replacing fuses The lights will go on and off as the breaker trips and resets and will stop cycling when you find the problem. This way gives you time to wiggle and wait wiring and connections and even disconnect things to narrow it down.--- Good luck........ Stay focused on any new wiring in the lighting circuit including the bulbs. Anything the switch controls including the switch. The auto breaker is available at parts stores and if you can't get one from a car parts store, Truck dealers do carry them. Get one that is lower than the one it csalls for. Ie; It normally calls for a 15 amp, get a10 amp. It will cycle faster. Do not bypass the fuse for there is a risk of fire. The breaker makes it a one man job . This trick has saved me a ton of diagnostic time.
Apr 13, 2009 | 1988 Ford Taurus
Central a/c and heat not blowing not working
Could be a circuit breaker tripped. Check the electrical panel for a tripped breaker. If they check out, then call a service tech to look at the outdoor unit. Good luck
Apr 08, 2009 | Honeywell Electronic Programmable...
Fan motor comes on, however, when a/c is turned on, breaker pops
If the unit is working fine in heat mode and in fan only mode, you have a short in the wiring going to the ouside unit. If it were a fan relay, then everytime the fan came on the breaker would trip. But either way, there is a low voltage short taking place in the unit. If the compressor was bad, the indoor unit would run fine and would only blow the breakers to the ouside unit. I had a unit last summer that did the same exact thing. After I replaced the control wiring to the outside unit, everything worked like a charm. Good luck!
Apr 04, 2009 | GE Heating & Cooling
A/c unit not working. Have thermistat set on 65 and temp. in house is around 85. check the breaker box for the house and it have not tripped
You must make sure that there is power to both the inside unit and outside unit. Is the room air blower blowing? If not you have either a plugged filter, iced up coil, the access door is not quite closed or there is no power to the unit. Is the outside unit fan turning? If not, you either have no call from the thermostat, the fan is broken or the unit has no power to it. I would turn off the breaker to the inside unit and switch the breaker near the outside unit to off and let them sit idle for 5 minutes. Switch both breakers back on and chect to see if the outside unit turns on. Then check the indoor unit and see if this starts blowing. Let us know what you find.
Jul 23, 2008 | Heating & Cooling
No cooling after power out, indicator lights pattern not in manual
The Mitsubishi units have to be reset by turning off the indoor units by switching the remote or thermostat to off. Then turn off the breaker to the outside unit(s). After 30 seconds,turn on the breaker and then you can turn on the remote for cool. If no lights come on on the inside units, most likely you have blown a fuse soldered on the main PC board. At this point, call your technician. A goos tech will be able to wire in an in-line fuse holder so if it should happen again, you can easily replace the fuse. If you do see a light or two come on at the indoor unit but the outdoor unit does not start after 3 or 4 minutes, sounds like you will need to call a technician. Most likely you have a blown fuse on the main PC board of the outside unit. It is not an easy one to replace. Good Luck!
Aug 31, 2007 | Mitsubishi MSH09TW Air Conditioner
Goodman CLQ36AR49 Air Conditioner Logo
74 people viewed this question
Top Goodman Heating & Cooling Experts
Paul Carew
Tim Whalen
christian nielsen
Are you a Goodman Heating and Cooling Expert? Answer questions, earn points and help others
